Solution #1
posted on Dec 02, 2007
try hitting F8 when the laptop starts booting- choose safemode and see if it works and you can get into safe mode- if so it's probably a driver issue or spyware. If not- you probably need to reload the operating system. Hope this helps- if not IM me and I'll see what else will help.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To:
HP (EK423AA) 300 GB Hard Drive
HP Axiom 60GB for HP Pavillion n5xxx and XHxxx series (AXH2060) Hard Drive
Acer (91.AB033.041) 73 GB Hard Drive
Buffalo Technology (HD-HB250U2) 250 GB Hard Drive
Compaq (349239B21) 250 GB Hard Drive
Fujitsu Siemens (MAX3036NC-20PK) (MAX3036NC20PK) Hard Drive
IBM (IBM60GB) 60 GB Hard Drive
Can you Help with these Hard Drives problems?
SanDisk 2GB Cruzer Micro USB Flash Drive...
Flashdrive
Flashdrive
This query does not relate to... Answer This...
LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Will not turn on
Will not turn on
My power cord is plugged in,... Answer This...
Kingston (DTIU3/2GB) 2 GB USB Hard Drive
kingston micro sd with adapter
how do i put music into the... Answer This...
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB...
Seagate FreeAgent Pro -...
Seagate FreeAgent Pro -... Answer This...
Seagate FreeAgent Go 80 GB USB 2.0 Hard...
usb hard disk no detected
my usb hdd 80GB segate not... Answer This...
Repair Service
Find Hard Drive Repairman Near You:
