Question about Radio Communications
Cw feedback every time that i try to monitor cw i get terable feedback i have opchinal fm board fitted
Your a pirate. I cannot answer your question!
Posted on Jan 04, 2008
Error message E1 on tempo 632t treadmill - what is it and how can I fix it ?
Hi There,
Tempo....check this lower control board for a small potentiometer or little square cube with a screwdriver slot in the top. Adjust this pot CW to 3/4 full turn and retry. Check feedback sensor(s). Does the belt move and then error and stop, or never start? These lower boards do fail and you can contact jatinah@rocketmail.com for more help if needed. Good Luck
Apr 11, 2017 | Exercise & Fitness
Horizon Fitness Treadmill new motor starts but cuts out in less than 5 seconds
Sounds like a faulty motor starter if equipped or motor it self faulty.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 06, 2016 | Horizon Fitness Exercise & Fitness
Try to hook up cw key but it keeps beeping
I cannot say for sure with that particular model, however I did have a radio that would do the same thing, and found that the wiring was shorting out at the terminal end causing the cw key to key itself multiple times. you might check that, or make sure that the wiring is correct for that particular radio.
Feb 21, 2013 | Alinco Dx-Sr8T 1.9 - 29Mhz Ssb/Cw/Am/Fm...
Hi How to fix.....? No picture on screen any one can help me..........? mainboard P5LD2-FM/2
First, see what led up to the picture not appearing.
Did the computer suddenly go off, or was it playing up for a while beforehand?
I have this board and it has generally been trouble free, although from time to time it will not show a picture and needs rebooting.
If you can, try this on a different monitor to see if the monitor is at fault first
  • Check that you are getting power to the board. That the PSU is switched on and is giving the green led light.
  • Next, do the fans on the board spin up? Is the CPU fan working?
  • Is there a light on the power button and is there a light on the board led?
  • Is the graphics card (if fitted) tight in the slot and if you are using the onboard graphics, is the VGA lead firmly connected?
  • Can you boot into safe mode (F8)? Or is this a problem even if that is tried?
  • Physically inspect the motherboard, can you see any signs of blowing or bulging capacitors, or any other burned components?
  • Next check the RAM, remove and replace one stick at a time.
  • Did you install any windows updates recently? Or updates to the graphics driver? If so, re-install the graphics driver as soon as you get a working screen.
After that, or if you are getting no power to the board / power but no action from fans, suspect a component failure on the board. if the board checks out, check the CPU heatsink after 10 minutes of it being switched on, it should be warm, if it is not, the CPU may have failed
Jul 21, 2011 | ASUS P5LD2 Motherboard
Feedback through fm radio
try using a seperate ant for ur radios
Jul 20, 2010 | Radio Communications
What kind of capacitor does a samsung 906bw lcd monitor use? I saw two bad capacitor at the power supply both are 10v 1000uf (105 degrees C)
There capacitors would most likely be electrolytic type. They are polarized capacitors and used for filtering DC voltage supply to remove the ripply and smooth the DC power.
If you cannot get a 10 volt capacitor then you can use a higher voltage type provided it can fit on the circuit board.
Mar 29, 2010 | Samsung 906BW LCD Monitor
Wat ar FM,AM,USB,LSB.CW. On a CB radio
FM - Freq. Modulation
AM - Audio Modulation
USB - Upper Side Band
LSB- Lower Side Band
CW- Morris Code
Nov 27, 2009 | Ranger Communications RCI-6900F-25 CB...
Ghost images and vertical lines on new FPD1775W monitor
You going to need a new logic board inside witch controls the signals from your video board on your computer. that is the only fix there is that i know of and I been around the block a few times with gateway.
thanks please do leave postive rating and feedback Thanks
Oct 09, 2009 | Gateway FPD1775W Monitor
How to find hidden menu on yeasu 857d
Note: The following was taken from a web site as follows:
http://www.kb2ljj.com/data/yaesu/ft-857.htm
WARNING: changing these will reset all the memories.
I want to warn you do not change these values unless you are sure of what you are doing. To get them turn transceiver off. Press and hold the A,B,C keys; while holding them in, press and hold in the [PWR] switch for 1/2 second to turn the tranceiver On. Now let go of all keys. Attention, for menu NO-017. Input voltage 13.8V = 138 to calibre voltmeter.
Press F key to finish.
Function Setting in my radio
============================================================= Adjust-No Function Setting Mode Frequency ============================================================= NO-001 HF1-RXG 118 CW 1.800.00 NO-002 HF2-RXG 91 CW 7.068.19 NO-003 HF3-RXG 133 CW 21.225.13 NO-004 50M-RXG 106 CW 50.000.00 NO-005 VHF-RXG 77 CW 145.437.50 NO-006 UHF-RXG 103 CW 438.900.00 NO-007 SSB-S9 61 CW 21.225.13 NO-008 SSB-FS 54 CW 21.225.13 NO-009 FM-S1 68 FM 145.437.50 NO-010 FM-FS 99 FM 145.437.50 NO-011 DISC-L 50 FM 145.437.50 NO-012 DISC-H 79 FM 145.437.50 NO-013 FM-TH1 100 FM 145.437.50 NO-014 FM-TH2 100 FM 145.437.50 NO-015 FM-TI1 10 FM 145.437.50 NO-016 FM-TI2 10 FM 145.437.50 NO-017 VCC 138 FM 145.437.50 NO-018 HF1-IC 83 CW 1.800.00 NO-019 HF2-IC 80 CW 7.068.19 NO-020 HF3-IC 87 CW 21.225.13 NO-021 50M-IC 84 CW 50.000.00 NO-022 VHF-IC 72 CW 145.437.50 NO-023 UHF-IC 74 CW 438.900.00 NO-024 HF1-PO-MAX 165 CW 1.800.00 NO-025 HF1-PO-MID2 105 CW 1.800.00 NO-026 HF1-PO-MID1 31 CW 1.800.00 NO-027 HF1-PO-MIN 13 CW 1.800.00 NO-028 HF2-PO-MAX 159 CW 7.068.19 NO-029 HF2-PO-MID2 102 CW 7.068.19 NO-030 HF2-PO-MID1 29 CW 7.068.19 NO-031 HF2-PO-MIN 11 CW 7.068.19 NO-032 HF3-PO-MAX 158 CW 21.225.13 NO-033 HF3-PO-MID2 101 CW 21.225.13 NO-034 HF3-PO-MID1 29 CW 21.225.13 NO-035 HF3-PO-MIN 11 CW 21.225.13 NO-036 50M-PO-MAX 145 CW 50.000.00 NO-037 50M-PO-MID2 92 CW 50.000.00 NO-038 50M-PO-MID1 47 CW 50.000.00 NO-039 50M-PO-MIN 8 CW 50.000.00 NO-040 VHF-PO-MAX 87 CW 145.437.50 NO-041 VHF-PO-MID 43 CW 145.437.50 NO-042 VHF-PO-MIN 7 CW 145.437.50 NO-043 UHF-PO-MAX 112 CW 438.900.00 NO-044 UHF-PO-MIN 16 CW 438.900.00 NO-045 HF1-TXG 48 USB 1.800.00 NO-046 HF2-TXG 38 USB 7.068.19 NO-047 HF3-TXG 43 USB 21.225.13 NO-048 50M-TXG 40 USB 50.000.00 NO-049 VHF-TXG 47 USB 145.437.50 NO-050 UHF-TXG 49 USB 438.900.00 NO-051 ALC1-M 203 USB 21.225.13 NO-052 ALC-M 85 USB 21.225.13 NO-053 HF1-REV-ALC 61 CW 1.800.00 NO-054 HF2-REV-ALC 56 CW 7.068.19 NO-055 HF3-REV-ALC 50 CW 21.225.13 NO-056 50M-REV-ALC 47 CW 50.000.00 NO-057 VHF-REV-ALC 62 CW 145.437.50 NO-058 UHF-REV-ALC 57 CW 438.900.00 NO-059 CW-CAR-LEVEL 144 CW 21.225.13 NO-060 AM-CAR-LEVEL 125 AM 21.225.13 NO-061 DEV-W 216 FM 145.437.50 NO-062 DEV-N 110 FM 145.437.50 NO-063 MOD-MTR 200 FM 145.437.50 NO-064 DTMF-DEV 10 FM 145.437.50 NO-065 CTCSS-DEV 233 FM 145.437.50 NO-066 DCS-DEV 168 FM 145.437.50 NO-067 LSB-CAR-POINT -7 LSB 21.225.13 NO-068 USB-CAR-POINT +5 USB 21.225.13 NO-069 VSWR2 at 10W 17 CW 14.257.90 NO-070 VSWR3 at 10W 42 CW 14.257.90 NO-071 ATAS-TEST LSB 14.257.90 NO-072 AMTR-TEST LSB 14.257.90 NO-073 HTEMP-THRESHOLD 38 LSB 14.257.90 NO-074 FTEMP-THRESHOLD 102 LSB 14.257.90 Hope thia helped........kevin KC8IDG
Oct 21, 2008 | Radio Communications
Radio Communications Logo
88 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
