Siemens 24 in. SE64A630GB Built-In Dishwasher
Problem for Siemens 24 in. SE64A630GB Built-In Dishwasher
Water does not completely drain on Kenmore Elite.
By hef858 on Aug 19, 2009
The pump makes sounds like it has gravel in it. I have inspected the internal filter and it is clear. Problem seems to be in the pump. Pump does not completely drain the system.
Repairman thought it might be a bearing going bad in the motor.
Solution #1
posted on Aug 19, 2009
Not Rated)
PCmania
Rank: Wiz
Rating: 83%, 264 votes
Hi..
If your machine does not drain you need to check this
  • Inspect the drain hose for kinks
  • Test the timer control
  • Test the lid switch (some models)
  • Inspect the water pump
  • Inspect the drive belt (belt drive only)
  • Inspect the motor coupler
Before testing the lid switch, unplug the washer or shut off the power at the fuse box or breaker panel to avoid an electrical shock hazard.
Regards
PCmania
Was this helpful?
Yes
No
Popular Solutions for Siemens 24 in. SE64A630GB
Questions and Unsolved Problems for Siemens 24 in. SE64A630GB
Do you recommend Siemens 24 in. SE64A630GB Built-In Dishwasher?
Answer
Answer
Cycle not finishing. Not sure if it did final heating water as it was late at night. Pump sounds... (More)
Answer
hi, we have a bosch about 8 years old. it just stopped mid cycle and will not drain.
Answer
machine fills with water does not drain and yet the filters are clean, in place securely
Answer
Hi I am looking for a manual or info on how to care for this dishwasher. It came with a house we... (More)
Answer
my dishwasher was working fine until today it wont drain the water completely and the water supply... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Siemens 24 in. SE64A630GB...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 3922
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
