Question about Samsung LN-R328W 32 in. HD-Ready LCD Television
Samsung Le32r51bd Whenever i turn the volume up or down pixalated bars come across the screen. This seems to be getting worse,it is now happening when i watch dvds ? Please help.
  • not amused Dec 11, 2007
    my problems on my le32r51bd started on the xbox360 red green blue input with a small line white line about 6 inchs down on the right hand side, that then cleared up . But i found for no reason when i turned the tv on one morning the menu wasnt visable anymore although you could see it was still there behind a load of horizontal white lines that cover the menu and do not flicker like the ones that now cover the whole screen on all inputs, but you get a glimps of a clear pic when changing inputs, the problem always seems worse when the tv is turned on and get about 80% better over the course of about 3 hours, but there is no change to the menu and is still not visable.. im very disapointed by this product as ive taken excellent care of it and it seem to of started to play up just after the 1 year warrenty.. hope you can help , if you have any auto electrical problems please email me id be happy to help.
    all the best from not a happy chap
MY SAMSUNG WITH THIS PROBLEM WAS DIAGNOSED WITH THE MOTHER BOARD NEEDING TO BE CHANGED, IT TURNS OUT SAMSUNG DO NOT MAKE THIS TV OR PARTS FOR IT ANY MORE, EVEN THOUGH IT WAS ONLY 1YR OLD,
AFTER 5 MONTHS THEY HAVE AGREEDED TO GIVE ME A FREE REPLACEMENT, AS THEY ARE LEGALY OBLIGED TO MAKE PARTS FOR 7 YEARS, AT LEAST THAT IS WHAT I WAS TOLD . SO FINGERS CROSSED YOU CAN DO THE SAME .
ALL THE BEST STU
Posted on May 20, 2008
I have been having the same problem. It started as constant white dots obscuring the menu but as you hardly use the menu I left it. Then I had a row of white dots 5 dots high all the way across the screen about two thirds of the way up. This only happened on Ext1 and Ext 2. I tried 3 different Scart and A/V cables in ALL the possible connections in the back and still I got the dots. This has gradually got worse and I now have a screen full of flashing dots. With it being out of Warranty (18 month old) I have been referred to a company to repair it.
Estimated cost £263.37 inc VAT  Diagnosis: Needs a new PCB board Time to fix: 1 week
I shall update once I know more/final cost, on Wednesday.
In future I shall be taking the extended warranty out. :o(
Posted on May 19, 2008
SOURCE:
Does anyone know what the solution is for my problem. We have a 42" Samsung Plasma TV.It is PN42A450P1D. It seems to have a mind of its on. It shuts itself off whenever. It seems to be taking Long
Go to Samsung.com, navigate to firmware update. Follow the directions for downloading for your model. Start with doing the update first then get back to us.
Mar 05, 2013 | Samsung Televison & Video
When I go over bumps or am turning I hear a clunking noise on my front right side. It seems to slowly get worse. It seems like it happens whenever the weight of the car is transferred. If I make a turn...
The first thing that pops into my head is a bad ball joint or a broken sway bar link, bad sway bar bushing, or a missing bushing in the link itself.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Oct 02, 2010 | Chevrolet Cavalier Cars & Trucks
Green bar on left side and green pixalation
The Main bd has possibly failed along with P-Logic bd. Have a trained Samsung tech troubleshoot the set.
Jul 17, 2009 | Samsung HP-S4253 Television
Colored dotted lines across the screen
If you understand the components of a computer pretty well, open the case and remove and reseat the graphics card into the slot.
Does it seem to only do it after so long, for example turn the computer of for a few hours, and it wont happen when its first turned on, but then a few moments later it starts after its warmed up?
If this does not resolve the issue, you may be experiencing graphic artifacts which can occur when a gpu is overheating due to a poor cooler. Check to make sure the heatsink is touching the gpu.
Artifacts: http://www.playtool.com/pages/artifacts/badgpu.jpg
Apr 20, 2009 | XFX GeForce 6200 Graphic Card
I have a philips Matchline tv (29pt6361/79r) the tv works fine except it automatically turns the volume down without any buttons on the remote or tv being pushed
well depends on how far it turns the volume down as to what the cause is and if the volume bar on screen display comes on when the vol. goes down. if it just goes down a little you probably have the "smart sound" setting turned on in the audio menu turn it off and see if prob. goes away. if the vol. bar comes on the screen whenever the vol. goes down the you most likely have a bad button on your front panel and it doesn't have to be the vol. down button. it you think it is the button it would need solder work to be changed most likely shop job.
Mar 08, 2008 | Televison & Video
Stripes on my Samsung Monitor
The contrast may be to high.
Adjust the brightness and contrast to make it go away but still readable.
if that does not help the FL (backlight) is going and the unit will need to be replaced.
Sorry.
Jan 02, 2008 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Volume starts out at full
If you read the owners manual careful it tells you something about setting the volume at start up buy setting the volume to desired level then push in and hold a few seonds the volume knob and that volume should be reached every time you start your vehicle.
Oct 12, 2007 | Dual XDVD8181 Car Video Player
Image distortion
Might be a loose connection to your screen and motherboard.
I have the somewhat same issue with my Dell Inspiron 15, It's a touch-screen laptop and whenever you jerk the screen it'll either Freeze in like colored bars, or it will change colors. Both of which are annoying.
If anything, it may be a loose connection.
Sep 04, 2017 | Acer AL1914B (Black) 19 in. Flat Panel LCD...
Samsung LN-R328W 32 in. HD-Ready LCD Television Logo
306 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
