Question about iRiver H340 MP3 Player
Im Screwed I plugged in a car charger for another peripheral device into my iriver thinking that it may be able to charge, the screen lit up white then went off and now my iriver h340 doesn't even turn on. Nor does it want to charge. Have i fried the battery or could it be a little bit worse?
  • 1 more comment
  • scottp57 Jan 28, 2008
    I did the same thing a few days ago. But I can faintly see a screen when I put power to it, so I think if I just replace the screen I will be Ok. I just can't find a screen anywhere. [email protected]
  • Birdy7 Apr 02, 2008
    Accidentaly plugged a different charger (with higher voltage! 9v) to my Iriver.
    Ay ay ay... it turned off, and never turned on again since. I gathered it is probably the motherboard that crashed, darn, the local tech support will charge about 200$ just for replacing the motherboard (in case that's really the problem) -Almost what the device costed me! (it's used)
    But the info on the harddrive is what's really precious on this little iriver, I wish I could at least access it!
    I wonder if I can get a replacement motherboard elsewhere, and do it myself, or find any solution that's cheaper...
    Thanks for any help!
  • Nugget1975 Apr 19, 2008
    Have exactly the same issue as you. Working
    fine one day but had a low battery, charged with a 5 volt DC not AC, and shazam.
    Got stuck on the charging screen for 20 minutes (even without an
    adaptor plugged into it), showed the "Check HDD connection" screen and
    hasn't turned on since. Devastated! Would love to know of a less expensive solution than what's already been mentioned.
I have done the same, I plugged a car charger and the screen went white and gone off since then I have not seen the screen nor I could turn it on could some one please say what I might have done to this poor player? Have I burnt it or damaged the battery? it smells as if it was burnt
SaaGHaR
Posted on Mar 07, 2008
    Sergeant:
    Champion:
  • 285 Answers
From what youve said it sounds like you've shorted the motherboard on the phone and possibly shorted out the battery to. They will need replacing im afraid.
Posted on Dec 02, 2007
SOURCE:
Have been charging it for over 24 hrs it wont turn on?
If a little lamp is lit when you plug in the charger (indicating that the device is charging), then try holding the power button down longer until something appears on the screen. If no lamp is lighting when you plug in the charger then there is something else wrong. Check it is the right power supply for the device and that you are plugging into the correct hole of the device (not the earphone connector). It also may be the charger itself is not working.
Mar 05, 2015 | Tablets & eReaders
Hi, i have a iRiver iFP-790, i was wondering, how do i charge this device?
This device has an AA battery that you must replace. Slide open the bottom red part, and swap the battery for a charged one.
You can use rechargeable batteries (available at any supermarket) and a battery charger (available at most supermarkets, otherwise look for it in electronics stores)
I don't think there is a possibility to recharge the device using the usb port.
Dec 13, 2009 | iRiver iFP-790 MP3 Player
Only charges... nothing else works on my Samsung
It should be fine to call when the phone is charging. It could be that the phone was "sleeping" as it charged and then the sudden energy draw of the phone call while it was charging screwed up the battery. I think you should take it to the shop.
Aug 23, 2009 | Samsung SGH-d807 Cellular Phone
"Black screen of death" iriver H10 6GB color
sounds like incorrect charging voltage and amperage may have fried some of your components.
Could try selling it on ebay as-is to make some money toward another unit.
You can get a top notch 20gb refurb unit from ebay sellers (like metromania) for $40-60. I have 2 refurbs and 1 built from parts from as-is units.
Mar 07, 2009 | iRiver H10 MP3 Player
My magellan 1200 will not keep a charge when i plug it in...it will not turn on cause the battery is dead...when i plug in the charger to the unit it flashes a bright white light for like a fraction of a...
I agree. I suggest you should go to a technician and try a new battery. If the new battery does not work you should speak to your manufacturer.
Thanks for using FixYa!
Oct 17, 2008 | Magellan GPS
Iriver clix 2 8gb screen broken
i can fix your no responsive
u need to open your clix (CAREFULLY)
u will see the side with the screen has an attachment on it. on the other end of the clix there is a rectangular thing that looks just like it. now carefully plug the screen back into it and snap your clix back together. plug it into any charger and PRESTO fixed screen
if it didnt work then your screen is cracked and must be sent back to the company. they do it for free though.
good luck
Mar 27, 2008 | iRiver Clix Digital Media Player
Charger
You can use a regular Apple iPod outlet plug-in wall charger, and connect your USB cable to it, which allows your iRiver to charge regularly.
don't panic!
bananaboy101
Dec 01, 2007 | iRiver H10 MP3 Player
It dosent even charge!!
Are you sure it's not charging? What makes you think it's not charging? When you plug the USB cord in (and it's attached to the charger or the PC)a screen should appear temporarily. It shows a picture of a PC with a usb cable coming out of it. Are you not even seeing that much? Remember that this is a no-name Chinese player, so don't expect iPod or iRiver quality. I didn't think mine turned on, but that's because the on/off switch was sticky and because you need to press play once or twice after it's turned on to get it to do anything. But so far, mine's working fine.
Aug 21, 2007 | Kaser Corporation Mambo Mano Digital Media...
Iriver Clix problem
yes i river has got customer support in online but i don t know how efficient it is if you had brought it from india , you better contact the vndor and ask for its warranty support man or else give a try connect the i river to another computer with windows xp (i prefer) and then install the software bundled up with your device and try to format the device via the software and then disconnect the device and power it on it will work i think
Aug 06, 2007 | iRiver Clix Digital Media Player
Will not turn on
Howdy! Same thing happens to me after only a while of having it. iRiver were of very little help but I found my solstice in selling it to some other unfortunate person. I found if you charge it for a hour and then take out the charger, remove the battery and replace it, it will go. What a pain! Perhaps the battery drains out when it sits unused for a few days.
Sep 17, 2006 | iRiver PMC-120 Digital Media Player
iRiver H340 MP3 Player Logo
102 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Ekse
Peter Dragonetti
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
