Question about HP ScanJet 3200C Flatbed Scanner
Problem in scanned work
After scanning by HP scan jEt 3200C flatbed scanner yellow stripes appears all along the work. How to solve the problem
  • cartooncat Dec 05, 2007
    Yellow stripes show up on scan and on color printing copies from HP Photosmart All in one 2610. HP support not helpful at all - telling me to clean the cartridges, put in new ones, then trying to sell me a new product. Have cleaned cartridges and glass, unplugged and plugged in printer. Problem started after I replaced the blank ink cartridge and the printer alignment failed. It aligned again after I replaced the color cartridge which was low but then the yellow streaks on the scans and on the paper got even more intense.
The Reflective Mirror Set in the scanner were subjected to dust. Clean the Mirrors (wipe the Dust with a soft hair 1 inch Brush. Do it under an Expert's Supervision
Posted on Dec 03, 2007
SOURCE:
Rcfa4122eu driver xp
OK , if you are looking for installing driver , it sample way just
write " hp scan jet 3200c driver
HP ScanJet 3200C
Mar 09, 2013 | HP ScanJet 3200C Flatbed Scanner
Unable to scan using HP Scanjet 3200C in Win XP Pro
Hi Shantala,
HP advises that, on some systems, the scanner hardware may get into an error state that will keep the scanning software from finding the 3200c ScanJet. If your scanner still isn't found after installing this driver and software update, please follow the directions below:
  1. Unplug the power cable from the 3200c ScanJet.
  2. Unplug the parallel cable(s) from the 3200c ScanJet.
  3. Shut down the PC and wait for ten seconds.
  4. Plug in the power cable to the 3200c ScanJet.
  5. Plug in the parallel cable(s) to the 3200c ScanJet.
  6. Power your PC on.
If you still have the problem, uninstall the driver from device manager, and download and run this .exe file version of the driver instead.. and if necessary, repeat the above steps..
ftp://ftp.hp.com/pub/softlib/software4/sj648/sj-1436-3/sj648en.exe
Hope this helps
Chris (ziraffa)
Dec 22, 2008 | HP ScanJet 3200C Flatbed Scanner
A yellow line appears on all of my scans. How can solve this?
Check the glass of the scanner. It may have some stain over it.
Dec 13, 2008 | HP Scanjet 4470c Flatbed Scanner
Windows Vista Driver for HP Scanjet 3200C
Help me I need vista 32 bit driver for my hp scanjet 3200c.
Thank you
Oct 24, 2008 | HP ScanJet 3200C Flatbed Scanner
Green/yellow colour
Just Clean the both inner mirror with clean cottorn dry cloth and also clean the lamp tube of the scanner.
and u should always clean the scanner regularly. so it will be working fine.
Aug 27, 2008 | HP ScanJet 3200C Flatbed Scanner
Software for HP Scanjet 3200C, OS = WinXP
try this link with HP , they dont have the scanjet 3200c listed anymore , but try the software for the scanjet 3400c , it should work for your scanner , hope it helps AJ
May 22, 2008 | HP ScanJet 3200C Flatbed Scanner
HP Scan Jet 3200C scanning problem
I would say the most likely cause of the issue is either that the scanner is no longer functioning or that it is experiencing power issues. Make sure that the scanner is plugged in directly to the wall and not into a surge protector or a power strip. The scanner does not share power well and pulls it in large amounts - when it can't get it it throws little power fits and sometimes will not turn on at all. Try another wall outlet and see if you can get it to power on and do a scan without the yellow strip showing up.
Dec 02, 2007 | HP ScanJet 3200C Flatbed Scanner
HP ScanJet 3200C Flatbed Scanner Logo
169 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
