Question about HP ScanJet 3200C Flatbed Scanner
HP Scan Jet 3200C scanning problem
After scanning the work by HP ScanJet 3200C flat Bed scanner yellow stripe appears all along the work scanned.If the work is in BW its Ok but if I need colour work how to remove it.
  • 4 more comments
  • delta8 Sep 02, 2008
    My scanner also shows yellow in the scaned item, but sometimes the intire area is slashed completly with yellow. Ican switch to black & white nad the yellow goes away. I read about unplugging the power cord from the power strip and plugged it into a wall receptical. No fix! Same problem!
    Carl Christian
    Katy, TX
  • gopaljee_gup Sep 08, 2008
    yell ssstripe along the both sides have been experienced but after pushing the inputs leads the width of yellow strips gets narrow .
  • Anonymous Sep 29, 2008
    the same thing happens with my scanner, but mine doesn´t show only 1 line, they are like 5 and different colors
  • Anonymous Mar 18, 2014
    All software for 4600 HP Scanjet has been installed. When a scan is made, a black vertical line with a gray vertical line is what appears. The scanned object is seen faded on one side of the scan.
  • Anonymous Mar 24, 2014
    the scanner does not scan slides
  • Anonymous Mar 28, 2014
    win 7 driver for hp scanner 3200c
  • 181 Answers
I would say the most likely cause of the issue is either that the scanner is no longer functioning or that it is experiencing power issues. Make sure that the scanner is plugged in directly to the wall and not into a surge protector or a power strip. The scanner does not share power well and pulls it in large amounts - when it can't get it it throws little power fits and sometimes will not turn on at all. Try another wall outlet and see if you can get it to power on and do a scan without the yellow strip showing up.
Posted on Feb 28, 2008
Rcfa4122eu driver xp
OK , if you are looking for installing driver , it sample way just
write " hp scan jet 3200c driver
HP ScanJet 3200C
Mar 09, 2013 | HP ScanJet 3200C Flatbed Scanner
Green light at front keeps flashing. wont scan
Hi, this might help you:
try to download the drivers and other software from hp.com or some other site and try to reinstall everything.
if you can't find them then search something like: 'hp scanjet 3200c drivers' on google or other....
I hope this is useful, and greets.
Oct 20, 2009 | HP ScanJet 3200C Flatbed Scanner
Unable to scan using HP Scanjet 3200C in Win XP Pro
Hi Shantala,
HP advises that, on some systems, the scanner hardware may get into an error state that will keep the scanning software from finding the 3200c ScanJet. If your scanner still isn't found after installing this driver and software update, please follow the directions below:
  1. Unplug the power cable from the 3200c ScanJet.
  2. Unplug the parallel cable(s) from the 3200c ScanJet.
  3. Shut down the PC and wait for ten seconds.
  4. Plug in the power cable to the 3200c ScanJet.
  5. Plug in the parallel cable(s) to the 3200c ScanJet.
  6. Power your PC on.
If you still have the problem, uninstall the driver from device manager, and download and run this .exe file version of the driver instead.. and if necessary, repeat the above steps..
ftp://ftp.hp.com/pub/softlib/software4/sj648/sj-1436-3/sj648en.exe
Hope this helps
Chris (ziraffa)
Dec 22, 2008 | HP ScanJet 3200C Flatbed Scanner
Windows Vista Driver for HP Scanjet 3200C
Help me I need vista 32 bit driver for my hp scanjet 3200c.
Thank you
Oct 24, 2008 | HP ScanJet 3200C Flatbed Scanner
Software for HP Scanjet 3200C, OS = WinXP
try this link with HP , they dont have the scanjet 3200c listed anymore , but try the software for the scanjet 3400c , it should work for your scanner , hope it helps AJ
May 22, 2008 | HP ScanJet 3200C Flatbed Scanner
Problem in scanned work
The Reflective Mirror Set in the scanner were subjected to dust. Clean the Mirrors (wipe the Dust with a soft hair 1 inch Brush. Do it under an Expert's Supervision
Dec 02, 2007 | HP ScanJet 3200C Flatbed Scanner
HP ScanJet 3200C Flatbed Scanner Logo
556 people viewed this question
Clive
Clive
