Question about Frigidaire GLTF2940ES Front Load Washer
Frigidaire washer won't spin, belt seems to be ok. What else can I look for ?, Thank you. e-mail , OSUOWNSFOOTBALL@YAHOO.COM
  • 4 more comments
  • Anonymous Apr 06, 2008
    Washer does everything but final spin. It will spin without clothes in it but not with clothes in it??
  • Anonymous Apr 09, 2008
    need motor control board
  • Anonymous May 04, 2008
    it just does not spin
  • norm ander May 05, 2008
    won't wash .stopped during a wash cycle . now won't wash . water still in bottom of agitater.took off back panel, belt and motor looks ok . HELP
    doesn't wash. stop during wash . motor and belt seem ok
  • eagleball1 May 06, 2008
    No final spin Electrolux says it's a relay . Local repair person says door lock. How could it be door lock when machine works to just before final spin?
I have a whirpool glass top electric stove that keeps blinking LOCK. I can hit cancel and it goes away but when u hit the bake symbol on the touch pad it appears again help
Posted on Apr 04, 2008
    President:
  • 1,294 Answers
Check your outlet filters, clean out. The machine will not spin if the filter is blocked. Also check your inlet into the machine. Clean screens on both ends of the pipes. Refit carefully. If you have manual, check for filter cleaning.
Posted on Dec 02, 2007
Why frigidair washer machine agitate not spinning
Thank you for your post, friend!
I understand that your Frigidaire washer is not spinning. Some possibilities to why it is not spinning could be the belt, motor, pulley, control panel or drum. Since it could be any one of these underlying issues I would recommend having a professional come out to properly diagnose and repair your appliance. -Matt
Aug 30, 2014 | Frigidaire Washing Machines
Washer won't spin unless I give the belt a little push to get it to start moving. The belt looks warn and has a small crack in it. Is the belt the only problem or is there something else I need to...
Sounds to me that the belt defiently needs to be replaced since it is cracked and streched.
Hate to tell ya wait and see but replace the belt for sure and see what happens,but to check a little further if the pulley that tightens the belt(idler pulley) is not missing a chunk of plastic and it spins free when flung with your finger i would say its ok, also you can check the spring on idler pulley by pushing it in and as long as it returns to where it was quickly its ok and just the belt is needed
Hope this helps and if it does please give me 4 thumbs up
Gene
Jul 29, 2011 | Frigidaire FWS833A Top Load Washer
The tub does not turn in the rinse/spin cycle but the motor is running.
Hello Jwwood,
Your Frigidaire GLTF2940F washer is not moving when it is washing clothes. This is because the belt is broke you can locate the belt on RepairClinic.com. Before you order the belt you need to findout the length as there are many different lengths and styles. In order to get to the belt you need to remove the back of the unit. If it is broke as I beleive measure and post back to this thread or go to the following link find the proper size and order. LInk - http://www.repairclinic.com/Frigidaire-Washing-Machine-Belt-Parts
Thank you for choosing FixYa.com
Mar 06, 2011 | Frigidaire GLTF2940F Front Load Washer
My washer squeals during spin cycle model frigidaire fex831cso. Sometimes it does it on the highest speed it reaches other times at slow speeds. One thing that is constant is... once it starts squealing...
The belt on my was the culpret. The washer belt has a spring loaded idler. Unplug power and move the idler off of the belt and use a spring hook or longnose vice grips to pull spring out of slot and into the next slot closser to you. There are 5 slotts. Push idler back by hand and put belt back on it. Your done. The transmission just spins as a unit in spin cycle, it does sit on top of a bearing,but that didn't seem to be the problem. If the belt tension doesn't fix it, put some grease and oil in the bearing or replace it.
Eventually you will need a new belt so order one now.
Jan 27, 2010 | Frigidaire FEX831CS Top Load Stacked...
Fridgidaire Washer burning belt!! Help
http://www.applianceaid.com/frigwestwasher.html#burnt-belt
look on this site for more aid, it may not be your exact model but has advise on burning belts
Nov 10, 2008 | Frigidaire CWS3600AS Top Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
404 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
