Question about Dryers
Thermostat wiring diagram for creda t622cw
Just replaced thermostats and cannot remember which wires go where
    New Friend:
    Problem Solver:
Creda dryer t622cw need help on where two orange wires go 1 brown blue and 1blue on thermostates
Posted on Jul 16, 2011
    Champion:
  • 249 Answers
Thermostat is a switch you should know by the leanth of the wires you can't blow any thing, in other words if its not one way, it is the other.just make sure its disconnected from mains Eire good luck!
Posted on Dec 03, 2007
  • 76 Answers
I assum there are four wires, you really cant get them wrong as they are all Neutral wires so it won't go of bang, it just may not heat as it should, I would connect them as you think it should and try them.
SOURCE:
Installed a rth6350 now no power
The RTH6350 is a battery-powered thermostat. Did you correctly install the AA batteries? Press down and pull the battery holder away from the thermostat on the right hand side. Try new batteries. Did you remember to secure the C wire with a wire nut and push it back into the wall. It should not be connected to the thermostat.
If you connected the C wire, you may have damaged the thermostat by providing too much current. Honeywell has the documentation for the RTH6350 on the product page: http://yourhome.honeywell.com/home/Products/Thermostats/5-2-Day-Programmable/RTH6350D.htm . The installation guide is here: https://customer.honeywell.com/request.cfm?form=69-2416ES . See page 23 and subsequent pages for the wiring diagrams.
I hope this helps.
Oct 11, 2014 | Honeywell RTH6350 5-2 Programmable...
Wiring diagram for smeg thermostat
Good Afternoon Friend,
I understand that you are looking for the wiring diagram, to replace the thermostat, in your Smeg appliance. The wiring diagrams are typically not accessible to the public. I suggest contacting the manufacturer, as they might have access to that wiring diagram for your appliance. Hope this is helpful.
-Best Regards-
WP
May 13, 2014 | Frigidaire FRS3R5EMB Side by Side...
I am trying to change Lennox to Honeywell
Just remember what wires went to which terminal. Usually color coded, red =R, white = W, etc, Shouldn't be too hard. Let me know if you run into a problem.
Jan 02, 2010 | Honeywell Electronic Programmable...
My creda t622cw dryer had no heat so I have replaced the thermostats, but when I tried it there is heat but the heating element gets very hot and turns red, is this normal or do I need to replace this as...
The fact that the element gets red hot, shows that there is nothing wrong with the element, it will get red, more so if you tried it without a cover or panel over it, as normally the fan blows the air over the element, make sure the drive belt is o/k, and the drum is turning.
Please rate my solution.
Thanks.
Nov 13, 2009 | Frigidaire Electric Dryer
My creda tunble dryer model 37324 is working but
If you plan to try to repair the problem yourself, then the first thing you want to do is unplug the dryer from the electric.
Remove the back of the machine and try to locate the air tube going from the blower to the drum. Normally inside the air tube you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the saftey of overheat from the machine.
Good Luck,
Hope this helps
Oct 17, 2009 | Dryers
Tumble dryer wont dry
hi do you have any blockages in the vent system (lint) can you hear the fan running and are the filters clean.did you put it back together correctly.hope this helps.
Mar 05, 2008 | Dryers
Dryers Logo
1,561 people viewed this question
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
