Question about Jabra BT250 Consumer Headset
Problem charging the device
I received a set of the jabra headsets and discovered that the indicator light doesn't stay on while charging. It flashes on for a split second once piece is inserted...and after unit is left alone for a time to charge, the unit won't power on. Now i dont understand the problem is the charger or the headset.
  • tiggerpl Dec 28, 2007
    I have same problem.
    Desided to return device to seller.
    Problem Solver:
  • 16 Answers
This has been answered on this site try this link
http://www.fixya.com/support/t190081-jabra_bt250v_indicator_light_doesnt
Posted on Jan 07, 2010
I can not get the headset to turn on.
If I read everything correctly in the manual I believe the light only stays on when the device is in the pairing mode. If the light flashes every second, the headset is on a call, if the light flashed every three seconds, it is in standby mode.
Standby mode: is when the Jabra BT160 is passively waiting for a call. When you 'end' a call on your mobile phone, the headset goes into standby mode.
Make sure your phone is bluetooth equipped.
You must first successfully pair the headset with your phone. The manual shows you how.....
1. Put the headset in pairing mode Make sure that the headset is on. Press the answer/end button and press the volume up (+) button at the same time, until a solid blue light comes on.
2. Set your Bluetooth phone to 'discover' the Jabra BT160 Follow your phone's instruction guide. This usually involves going to a 'setup,' 'connect' or 'Bluetooth' menu on your phone and selecting the option to 'discover' or 'add' a Bluetooth device.
3. Your phone will find the Jabra BT160 Your phone then asks if you want to pair with it. Accept by pressing 'Yes' or 'OK' on the phone and confirm with the passkey or PIN3 = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
Go here for a copy of the owners manual....
http://www.mainresource.com/PDFs/GNBT160User.pdf
Hope this helps.....
Jan 27, 2018 | Jabra BT160 Wireless Headset
How do I pair my jabra easygo to my I phone 4s?
Detailed instructions can be found by downloading the user manual from the Jabra support page.
PAIRING IT WITH YOUR PHONE1 Put the headset in pairing mode- When you turn on your Jabra EASYGO for the first time, theheadset will automatically start up in pairing mode, i.e., it isdiscoverable for your phone. When the headset is in pairingmode the Bluetooth status indication on the StatusDisplay isflashing.2 Set your Bluetooth phone to discover the EASYGO- On your iPhone 4s, go to settings>General>Bluetooth and make sure Bluetooth is turned on.3 Your phone will find the Jabra EASYGO- Your phone will find the headset under name Jabra EASYGO.Your phone then asks if you want to pair with the headset.Accept by pressing Yes or OK on the phone. You may beasked to confirm with a passkey or PIN. Then use 0000(4 zeros). Your phone will confirm when pairing is completeand the Bluetooth status indication on the StatusDisplay willshift from flashing light to steady light and the headset voiceguidance will say connected.
Manual pairing modeIf you wish to use the headset with a different phone, or if thepairing process was interrupted, you can manually set the headsetto pairing mode.Make sure the headset is on. Press and hold the answer/end buttonfor approximately 5 seconds until the Bluetooth icon turns froma steady light to a flashing light. Then repeat steps 2 and 3 in theabove pairing guide.Connecting with your phonePairing is only needed the first time a headset and phone areused together. When the headset and phone have been pairedonce, they will automatically connect when the headset is on andBluetooth is activated on the phone. The headset can be usedwhen it is connected to the phone. If the devices are paired, butdo not immediately connect, tap the answer/end button. Whenyour headset is connected the Bluetooth connection icon in theSTATUSDISPLAY WILL BE CONSTANT ON FOR 3 SECONDS andthe headset voice guidance will say connected.
Feb 19, 2012 | iPhone Apps
How do I acitivate it
Charge your headset
Charge the headset's battery fully before using the headset for the first time.
1 Put the headset in the supplied charging case and close the cover.
2 Plug the travel adapter into the case's charging socket.
Put your headset in pairing mode
1 Ensure that the headset is off (see Turn headset on/off below).
2 Press and hold the Multi-Function button until the indicator light turns on in blue (approximately 8 seconds).
Turn on Bluetooth on your phone and pair with headset
1 Set your Bluetooth phone to discover the headset by following your phone's guide.
Typically, the steps involve going to the Settings, Connection, or Bluetooth menu on your phone and then selecting the option to discover Bluetooth devices. Your phone will find the Samsung WEP200
headset.
2 Select Samsung WEP200.
3 When the phone asks if you want to pair with it, confirm by selecting Yes or OK.
4 Enter the headset passkey or PIN, 0000.
Your phone and headset are now paired and ready to make and receive calls.
1 Place the headset over your ear.
2 On your phone, make a call to the number you want.
3 If your phone and headset are successfully paired, you will hear ringing on the headset
After you have successfully paired your phone and headset, you do not need to repeat these initial setup steps each time you use the headset.
To turn the headset on
Press and hold the Multi-Function button for4 seconds until you see 4 blue flashes on the indicator light, then release.You will hear a tone and see the indicator light flashes while the power is on.
To turn the headset off
Press and hold the Multi-Function button for 4 seconds until you see 2 blue flashes on the
indicator light, then release.You will hear series of 2 tones and see the indicator light stops flashing.
http://ars.samsung.com/customer/DownloadAnsTempl?AT_ID=70171&SEQ_NO=2
Jun 07, 2011 | Samsung Bluetooth?® WEP200 Headset...
I have it pair to my I phone ----but I lost my manual what are the buttons for?
Follow the instructions mentioned below to resolve the issue:
  • Charge the headset
  • Charge your Jabra VBT185Z until the solid LED turns off
  • (approximately 2 hours)
  • Turning the headset On and Off
  • Press the answer/end button until you see a burst of flashes on the
  • indicator light (LED) to turn your headset on or off.
Headset Pairing Readiness Instructions:
1. Fully charge headset for two hours.
2. The headset will automatically go into pairing mode if no device has
been previously paired.
3. Set your mobile phone to 'discover Jabra VBT185Z'.
4. Enter passkey or PIN = 0000 (4 zeros), then press Yes or OK.
For online pairing assistance visit www.verizonwireless.com/bluetooth.
Hope the above steps allows you to resolve the issue. Please revert back for any further clarification.
Regards
Anand
May 10, 2011 | Jabra VBT185Z Bluetooth Headset
I want to connect my Jabra 0te3 blutooth headset to my laptop fujitsu P3010 in win 7 but my bluetooth is not finding jabra. how can i pair it.
1) Ensure that your Jabra headset is turned completely off. Press the tap button on the headset until it ceases flashing and the light goes off.
2) Hold down the tap button to power your Jabra headset back on. Keep holding the power button until the lit power indicator cycles past flashing mode and becomes solid.
3) Release the power button.
4) Navigate through your cell phone "Settings" menu and ensure your "Bluetooth" or "Hands-free" section is set to the "On" or "Active" mode.
5) Choose "Search for new devices" or "Find new devices" on your phone's Bluetooth or hands-free menu.
6) Place the Jabra headset close to your phone to ensure it can be discovered by your cell phone.
7) Select a "Connect" or "Pair" option once the Jabra headset name displays on your cell phone.
8) Enter the default passcode by entering "0000" on your cell phone keypad.
9) Ensure that the Jabra headset has been paired. Look for the Bluetooth icon in the upper portion of your cell phone screen. Make a call to verify that audio is being routed through the Jabra headset.
Dec 22, 2010 | Computers & Internet
My Jabra headset won't pair with my phone--my phone can't "discover" the headset. The headset is charged and when it is turned on, it blinks three times in a row
Assuming you're talking about the Jabra BT2050 headset press and hold the center (round) button for at least 10 seconds; light will stay solid entering the pairing mode. Follow instructions on your phone.
Dec 14, 2009 | Jabra BT2050 Bluetooth Headset
Cant find a manual jabra bt4051 bluetooth
abra burst onto the audio microtechnology scene in the early 1980s, gaining initial attention for its Macintosh EarPHONE telephony products. Jabra's cell phonemag-glass_10x10.gif Bluetooth headsets have also garnered wide acclaim for their sleek aesthetics and compact form. Jabra Bluetooth headsets can be connected or "paired" with virtually any cell phone by using a few simple steps.
  1. Ensure that your Jabra headset is turned completely off. Press the tap button on the headset until it ceases flashing and the light goes off.
  2. Step 2 Hold down the tap button to power your Jabra headset back on. Keep holding the power button until the lit power indicator cycles past flashing mode and becomes solid.
  3. Step 3 Release the power button.
  4. Step 4 Navigate through your cell phone "Settings" menu and ensure your "Bluetoothmag-glass_10x10.gif" or "Hands-free" section is set to the "On" or "Active" mode.
  5. Step 5 Elect to "Search for new devices" or "Find new devices" on your phone's Bluetooth or hands-free menu.
  6. Step 6 Place the Jabra headset close to your phone to ensure it can be discovered by your cell phone.
  7. Step 7 Select a "Connect" or "Pair" option once the Jabra headset name is discovered and displays on your cell phone.
  8. Step 8 Enter the default passcode by entering "0000" on your cell phone keypad.
  9. Step 9 Ensure that the Jabra headset has been paired. Look for the Bluetooth icon in the upper portion of your cell phone screen. Make a call to verify that audio is being routed through the Jabra headset.
Nov 12, 2009 | Cell Phones
An old headset I had would flash blue and orange when it was in discover mode, ( so the cell phone would find it to pair it up). This jabra I have will not go there. My cell phone just says cannot find...
Hello friend,
First, make sure that your headset is charged and then press and hold the "Answer/end" button until that the light becomes blue solid. at this time you can do a search on your phone to discover bluetooth devices.
Here is the link to download the user manual for more information:
http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT350/Documents/BT350_UM_NA_EN_491.pdf
if the device doesn't light on at all, you may need to try with another charger because in this the device is not charged at all.
Best Regards,
Oct 30, 2009 | Jabra BT350 Bluetooth Headset Headset
Jabra red light of death
seeing the red light tells you that the jabra isn't fried or shorted and that there is life but there is a problem, the red light isn't blue when it should be. so have you read the directions your ear piece came with when you first bought it?... hold the on button until you see the blue light stays on.(blue light will flash fast then slow then come to a complete stop and stay on) once blue light stays on that should mean you can now find the ear piece on your cell phone to link up. if problem still isn't fixed then you might as well buy a new one.
Aug 04, 2009 | Jabra BT350 Bluetooth Headset Headset
Jabra bt250v Indicator light doesn't remain on...
i have just repaired my bt250 with this problem, i hadn't used it for around 2 years and when i put it on charge just got i flash of blue led. the fix was to "jumpstart it" the headset needs to se some sort of battery voltage to start the charging process, i stripped mine right down but that was just to fiddley. IF YOU DO THIS IT WILL BE ENTIRLEY AT YOUR OWN RISK AND I TAKE NO RESPONSIBILITY IF YOU TRASH YOUR OTHERWISE USELESS HEADSET. ok all you need to do is very carefully remove back cover (undo 1 screw and ease it apart). be very carefull as there are delicate wires inside. lift the inner part out slowly and you will see the battery.it has some orange tape around the end and there is a small circuit board attached to it with a small red wire and a small black wire. look at the battery and you will see under the orange tape there are to larger tags.these are the main battery terminals, peel back the orange tape just until the tags are slightly exposed. now you need to solder a wire to each of them and DON'T TOUCH THEM TOGETHER. on the battery it says which tag is + and which is - make sure you mark your wires or get red and black ones. now i used the lead from the charger. look at it . it has a hole in the center of the pin that is the + so put the + wire in there. if you are not sure use a volt meter. now touch the - wire to the outer metal of the connector that is the - point on the charger connector. hold this for around 2 mins but no more. as the out put of the connector is 6.2v and the battery is only 3.7v the battery will get warm. if the battery is getting too hot in under 2 mins then take of charge. when you have done that and taken off the connector i recommend to use a volt meter and just put it on the battery wires you soldered on to check battery voltage. as long as it reads you should be ok. de solder your wires from the tags and rebuild headset then try and charge it. this worked for me. i am no electronics expert i just like to mess with broken stuff so i know it seems a bit dodgy to connect like this but i had nothing to lose and it worked.
Aug 30, 2007 | Jabra BT250 Consumer Headset
Jabra BT250 Consumer Headset Logo
133 people viewed this question
Top Jabra Radio Communications Experts
Jerry Greenberg
Jerry Greenberg
Mohammad Nawaid...
Level 1 Expert
Michial Gueffroy
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
