Question about Gaggia Coffee In White, White MDF Grinder&Coffee Bar Base
Re setting Hi How do you reset the amount of coffee flow on a Gaggia, overfills the cups?ThanksNigel
    Problem Solver:
  • 5 Answers
There is no way to do this. One controls flow by the pressure of the tamp, and fineness of the grind. 2.25 ounces or espresso in 20 seconds from 14 grams of coffee.
Posted on Dec 18, 2007
SOURCE:
When I press the espresso button instead of esspreso makes a long coffe .I must ad I descaled it yesterday .
You may have accidentally changed the amount setting for your espresso shot when resetting the descale counter.
If you lost the manual you can find one here.
http://www.gaggia-usa.com/support_docs/Gaggia_Brera_Quickstart_Guide.pdf
On page 11 (with the printed number 31) you find how to change these settings:
• Place a cup under the dispensing spout.
• Hold the "espresso size" button pressed for 5 seconds to enter the programming mode; the "coffee" icon will blink quickly and the coffee will start to be brewed; the icon will flash during the whole coffee brewing cycle.
• Press the same "espresso size" button again when the amount of coffee in the cup reaches the desired level.
At this point the button "espresso size" is programmed; each time it is pressed and released, the machine will brew the same amount of coffee that was just programmed.
The same operation can be repeated for the "Lungo size" button.
Jun 15, 2015 | Gaggia Brera Coffee Maker
Gaggia Titanium - the button for a small coffee has stopped working. Can I do anything to fix it?
Hi Try reprogramming the machine. Push and hold the button for the coffee you want, but hold it all the way through the process. Don't release the button until you get the amount of coffee you want for that button, then release the button. That should get you the same amount next time. You can do this for each coffee button. If that didn't fix it you might have a bad flow meter.
Jun 23, 2011 | Gaggia Titanium Espresso Machine
I get lots of watered down coffee. It brews 3/4 cup but it is so watered down. We have descaled etc. I want a thick expresso like taste. This is on a large cup setting Help?>
HI
When you run a lot of water through just a little coffee it gets water down. Try making 2 meduim cups instead. When they make espresso its 1 tablespoon to 1 oz of water. Your running 6 oz of water through the same amount of coffee, and its going to be weak. Program you buttons for 2 shots to fill your cup and it will be pretty strong.
Jan 25, 2011 | Gaggia Syncrony Espresso Machine
When we push the option Large Coffee instead of giving us a large cup it gives us a small cup and strong. We push the small coffee and also get a small cup. What can we do to fix it?
HI
It needs to be reprogramed. If some one holds a coffee button down to long it will reset itself back to small coffee.
If that doesn't fix it, then you might need a new flow meter.
Jan 13, 2011 | Saeco Vienna Digital Coffee Maker,...
Coffee seems stronger than normal.....maybe problem with water flow??
If you are getting the same amount of coffee with the same button there is nothing wrong with the flow. You could have changed you grind setting or your dosseing amount. Have you cleaned you brew unit?
Mar 06, 2010 | Gaggia Syncrony Espresso Machine
No coffe in the cup
Hi
I would say you have a stripped thumb screw. It is in the top left side of the brew unit and holds the filter screen in. If it is stripped there will be water or coffee in the pocket on top left of the brew unit.
Dec 26, 2009 | Gaggia Syncrony Compact Coffee...
Too little volume
Hi
Nov 23, 2009 | Gaggia Syncrony Espresso Machine
? Am I trying to use coffee ground TOO FINE
On my Gaggia Machine I use an Gaggia MDF Grinder on 8 or 9 setting for the best flow. I only use as low as 4 with my Presso Manual Machine
Nov 05, 2008 | Gaggia Classic Espresso Machine
Try to make a cup of water, if you only can get a half cup then the flowmeter has to be replaced.
Jun 22, 2008 | Gaggia Syncrony Logic 74884 Espresso...
Ventilate problem
Can you make a cup of water or there will only comes a half cup?
If you only get a half cup then you have to replace the flow meter in the machine.
Apr 27, 2008 | Gaggia Syncrony Compact Coffee...
Gaggia Coffee In White, White MDF Grinder&Coffee Bar Base Logo
176 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ekse
Marvin
Marvin
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
