Question about Coby DVD-207 Portable DVD Player
Displays "wrong disc" after trying to load
No matter what disc I try to play it will attempt to load then display "wrong disc. I have try dirty to clean to new DVD- and + R as well as CD-R. How can I possibly remedy the discrepancy.
  • 1 more comment
  • DeniseWeber Dec 04, 2007
    I have the same problem. Doesn't anyone have a solution?
  • Anonymous Jun 17, 2008
    I USE LIBRARY RENTALS. ALSO HAVE A FEW BOOK CLUB ITEMS.
    TV SCREEN FLIPS, LIKE VERTICAL HOLD. IT IS AN OLDER PIP PANASONIC TUBE TV. UP UNTIL ABOUT 3 WEEKS AGO IT WAS PLAYING FINE. I TOOK 2 DISCS BACK TO LIBRARY FOR CLEANING.
    SAME PROBLEM. TOOK IT TO RADIO SHACK WHERE IT WAS HOOKED TO HDTV NO PROBLEM.
    MM
  • wesamsyria Sep 19, 2008
    i have coby tf7333 all cd" s work only when but any dvd i have (wrong disc)
    could u pls tell me what i should to do
My coby dvd player have no sound alone but have sound with headset how can i get it to work with just the volume i have dvd 73337tft
Posted on Dec 23, 2007
    Sergeant:
    Champion:
  • 362 Answers
I have found several of these that have had that problem and the ones i repaired had the same problem the power had failed to the laser eye. it was a different fix for each but that was the basic answer you can take it apart if its not under warrenty and look at the power board look for burnt resistors they turn black, or darker brown spots on the board. one did have the motor that controlled the eye bad the eye would not move.
Posted on Dec 10, 2007
After reading toc of my Marant zcd5003 the display is "error" seeking help to find out the cause
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
follow the steps and fix it.
God bless you
May 27, 2013 | Marantz CD5003 CD Player
My LG RH397D will not play a disk. It gives a navigation error.
Does not play disc
    See the diagram attached.and if the problem persist. Lube the plastic parts with small grease or vaseline very carefully
Feb 09, 2013 | Televison & Video
DVD display says "Wrong disc" no matter which disc
Leave dvd player on for a lengthy time to dry up condensation, may take a few weeks?
Dec 01, 2010 | Norcent Technologies DP313 DVD Player
My Daewoo DVG-5000N does not load the DVD correctly. It tries to spin it up and stops again while displaying that it is "loading". After a while it displays "no disc".
No disc error is usually caused by dirty optical lens or a faulty lens. Turn it off, unplug it, then try cleaning it with a very soft dry cloth and then try playing a cd which has no scratches.
The blue color part, that's called optical lens. It looks like a glass but its not a glass, its a plastic cap for the laser to go thru to read the discs. Never apply any wet solutions on it. Just use a soft dry cloth to rub off the dirt on it.
Jan 16, 2010 | Daewoo Televison & Video
Dvd wont play says wrong disc
If this happen with all disks , then the lens are dirty or faulty.
Try cleaning the lens with a cleaner DVD. If that is not enough, then the player must be taken apart to clean lens with isopropyl alcohol and cotton, or to replace the lens pickup.
Before attempting repair call manufacturer or retailer to check warranty status.
Sep 10, 2009 | Yahoo Diamond Vision DVDC803-04 DVD Player
2005 chevy colorado cd problem
Try resetting the radio, turn the radio off and disconnect the battery for 30 seconds. Make sure the RADIO IS OFF OR YOUR GOING TO BE ASKED TO ENTER THE RADIO CODE TO HAVE THE RADIO ACTIVE AGAIN. After the battery has be reconnected, turn on the radio and reset your clock and stations. Your CD plays should be working again too. Good luck and hope this helps.
Jun 15, 2009 | 2005 Chevrolet Colorado
Denon DCM 5000 error code
The disc is loaded upside-down in the disc rack or the disc is dirty or scratched, try another disc and make sure the top side (label side with printing) is facing towards the back of the rack, away from you. The bottom or data side should face out towards the front of the rack. If that does not work then your laser picups inside may need cleaning. Make sure your disc is clean and now scratches.
Feb 08, 2009 | Denon DCM-5001 100-Disc CD Changer
After loading every disc displayes "wrong disc'
are they bootleg dvd's? if not try getting a lense cleaner because wrong disc means it's reading your dvd's as .mov files which only play on quicktime in a computer. if it reads your cleaner as wrong disk too then get yourself a refund cuz it has a motherboard malfunction.
Dec 02, 2007 | Cyberhome CH-DVD 300 DVD Player
Samsung 3650 dvd/vcr player loading problem
Sorry, no suggestion other than don't buy Samsung. That's my conclusion after owning the same model. It worked fine for a while, but now won't load any DVD... usually. Sometimes it will play one, but more often it won't. Mine tries to load ("Loading") for a long time, I hear the DVD spinning, then ultimately the screen displays "This disc cannot be played" or something to that effect.
Nov 25, 2007 | Televison & Video
Hangs/ "wrong disc display"
yea take your DVD player to a repairman your micro could be your problem.good luck.
Apr 06, 2007 | Coby TFDVD7050 Portable DVD Player with...
Coby DVD-207 Portable DVD Player Logo
319 people viewed this question
Top Coby Televison & Video Experts
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
