Question about Dishwashers
BOSCH DISHWASHER SGS 6312GB/13 , FD 7810
When it gets to the end of it's cycle it wont stop trying to drain. If you switch it off and leave it for a while, then turn it back on it just continues to pump rather than a short brief pump and then commencing the cycle. What could i do to remedy this?
  • 3 Answers
I had a similar prob with my Bosch SGV53E23. Turned out the cold water feed pipe at the back had a v. slow leak which was caught by the plastic moulding and channelled into the machine base. Slowly filled with water and ended up continuously running the pump - even with the door open! Fixed leaking pipe = fixed problemo.
Posted on Mar 01, 2009
  • 76 Answers
You have a leak underneath and it is switching the anti flood switch on. Tip the dish washer back at a 45 deg angle, you will probably get water teak out the back, stand it back upright and try it. although it will probably work you will need to look underneath and find where the leak is coming from, my guess is its the wash pump and will cost around 100 pound for an engineer to repair.
Posted on Dec 03, 2007
SOURCE:
My 15 yr old Bosch d/w starts at 13 min & runs to 1, doesn't gets to CL. No water in or drain out.
IF IT ENDS UP WITH WATER SHOWING AT THE END OF EVERY WASH THEN THE DRAIN PUMP IS JAMMED OR FAILED THE DISHWASHER PROG WILL JUST KEEP LOOPING BACK TRYING TO DRAIN THE WATER.
Mar 04, 2017 | Bosch Dishwashers
Have bosch sgs 6312gb it's not filling with water in machine
If it works when water is added the the over flow switch is ok
Here is the diagnostics guide Bosch dishwasher service guide
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 23, 2011 | Bosch Dishwashers
Model Free standing dishwasher SGS 5002 GB 14 yrs old. The dishwasher does not drain. The dirty water is left in the bottom at end of cycle. I have ensured outside drain is unblocked: I have cleaned all...
Please check if the drain valve is weak/faulty or does not get the votage to open during the cycle , his can be your fault . Also it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there is gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Jun 13, 2011 | Bosch Dishwashers
Dishwasher takes too long on cycle
This sounds like a heating problem. The cycle will not advance if the water is not up to the proper temperature.
Next time you run a cycle, open up the door after a few minutes. A large ball of steam should roll out of the machine. No steam = no heat = no timer movement.
The most common suspect for repair is your heating element. The fix may be a simple as a loose or broken wire leading to the element.
The element itself may also be bad. This is easily checked with a multitester. Set the tester to ohms or resistance. The element should have an actual reading. A result of zero or infinity or overlimit is not acceptable for your heating element. It should then be replaced. Good luck
Apr 20, 2010 | Bosch 24 in. SGS43E02 Exxcel Built-In...
Dishwasher wont fill.
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Sep 29, 2008 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch Dishwasher Not Draining
Im really not all that familiar with the bosch unit, but a few things i would ck. when you cancel a cycle (it should drain the water) is it humming??? does it sound as if it even trickling into the sink discharge?? do you have a disposer under your sink that this unit drains into, if so remove the clamp and look for possible obstructions right there.Honestly passed this ill have to defer to someone else sorry and good luck
Mar 10, 2008 | Bosch SHU9915UC Dishwasher
Bosch SHU9915 Does Not Drain
faulty controls..the signals are apparently getting there, but the machine is intepreting them oddly..may need a new control board behind panel
Mar 09, 2008 | Bosch SHU9950 Dishwasher
Bosch dishwasher
is all the water draining from the tub? if not the pressure switch will not reset and it will continue to try and clear it self...check drainage system.
2. pressure switch is jammed on..build up in the sensing chamber..common..or switch faulty...rarely
3. if water is in the bottom panel most have a flood switch which automatically operates the pump in case its over filling
Dec 04, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch classixx slimline dishwasher not running through cycle
fault is that there is a leak. the tray at base of dishwasher is full of water which operates a float and turns on drain pump. tilt over 45deg and water will run out and then it will work or remove bottom front panel and mop out (better). then find leak
Mar 17, 2007 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Dishwashers Logo
930 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
