Question about Indesit W 123 Front Load Washer
Wont Start i've just loaded up as usual but i've notice the 4,6,9 delay timer lights are constantly on, even after switching off & resetting. At the moment the machine has been like this all week as i;ve left it to see if it will start on its on.
    President:
  • 1,294 Answers
Turn the dial to the off position. Press "stop" & "cancel" together for 10 secs or more, the thing shd clear.
Posted on Dec 02, 2007
  • prem mathew Dec 04, 2007
    Try "end of cycle" button for over 3 seconds
SOURCE:
How wire 8 pin 240 volts FUJI ST3PR repeating timer
Timer specs show AC220 with range 24-380VAC
R suffix means on-delay timer... but the appearance looks like repeat cycle
It appears that 240V power is connected to terminals 2 and 8
Switch terminals are 4-6 and 4-5
Terminal 4 toggles back and forth between 5 and 6
And terminal 5 toggles on-and-off separately
Some timers require constant voltage on terminals 2 and 8, some require momentary voltage to start the cycle
Some wiring tips following link:
http://waterheatertimer.org/How-to-wire-AH3-3-timer.html
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Feb 21, 2015 | Hardware & Accessories
Just bought my house and the porch light is controlled by Intermatic timer. Just noticed today that my porch is light is on constant. Replaced the battery in the timer. I was able to set the time and...
Don't forget to reset timer after replacing battery:
Copy following link to identify timer and download manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
If timer does not function after reset, then buy new timer
EJ500 is rated incandescent bulbs only
Gene
h
Oct 05, 2013 | Intermatic Inc. EJ500C Digital Wall Switch...
I am having trouble wiring a 120V time delay relay. Any help would be greatly appreciated.
You have 120Volt 8-pin off-delay timer.
When you put power to terminals 2 and 7, test which other pins are energized.
120Volt Black Hot wire usually goes to terminal 7 and Neutral white wire goes to terminal 2.
As general rule the other terminals are dry and receive no voltage when timer is energized at terminals 7 and 2.
This means you must add a jumper wire from your Hot wire on terminal 7 to the Com terminal 8. This action will energize both Com terminal 8 and NC terminal 5. So test if 5 and 8 have continuity when timer is off. And test if both are powered when Com terminal is energized.
Then when timer activates, NC terminal 5 will no longer receive power from Come terminal, and NO terminal 6 receives power instead.
Copy following link for general illustrations that may apply to your timer and application:
http://waterheatertimer.org/How-to-wire-pin-timers.html
Aug 04, 2012 | Hardware & Accessories
To palaboy: when you talk about a switch on the left most terminals, you mean with this switch im enable the timer???
Question is not clear.
You posted about Dayton on-delay timer?
This timer has two contacts, and wires similar to a light switch.
Connect 120V power to terminal 1
Connect wire going to load to terminal 3
Maximum Load is 1 amp so this timer should be wire to a contactor/relay and not directly to Load.
If you have Dayton off-delay timer, open following link for wiring diagram, and to see examples of contactors:
http://waterheatertimer.org/How-to-wire-Dayton-Off-Delay-Timer.html
If you have a different timer, then add a comment with clear description of timer or in-focus photo of timer posted on Flickr
Jul 11, 2011 | Amperite Dayton Solid State Timer On Delay...
My b2300 bread maker wont start on the 15 min delay after i push the start button .......why? i hate this machine and wont recommend one to anyone.......love my old sunbeam machine which just broke down...
Addressing Power-up/Start-up Issues:
1. Unplug the breadmaker.
2. Confirm the power source you're accessing is live using a blender, toaster, etc.
3. Plug the breadmaker in.
4. Confirm the breadmaker is receiving power:
    1. Some models have a built-in off/on switch. Turn it to the ON position.
    2. Some models make an audible tone when plugged in.
    3. Some models have a colored light and/or a lighted display screen that lights up.
    4. Some models require you press the Select button down until the unit powers up.
    5. Some models require you press the Start button down until the unit powers up.
    6. Some models require you press the Select button first to select a mode, then press the Start button.
3. No, you were not able to confirm that your breadmaker is receiving power? Sorry to hear that. Attempt to have the breadmaker serviced by a small appliance repair facility or discard it.
4. Yes, you have confirmed that your breadmaker is receiving power? Fantastic! Now reboot the breadmaker's electronics by pressing down continuously on the Start button until you notice a visible and/or audible confirmation, usually within 5 to 10 seconds. Beware: Some models require you press the Select button first to select a mode, then press and hold the Start button to reboot the system.
That should fix it. Hope this helps!
Special Note: Often the + and - Timer Delay buttons are pressed by mistake, delaying Start by up to 12 hours. If you suspect the Timer Delay feature has been engaged accidentally, you'll need to reboot the breadmaker's electronics. You can do this by pressing down on the Start button continuously until you notice a visible and/or audible confirmation, usually within 5 to 10 seconds. Beware: Some models require you press the Select button first to select a mode, then press and hold the Start button to reboot the system.
Jun 19, 2011 | Black & Decker B2300 Bread Machine
I have been using a Sunbeam Model 5891 Breadmaker for over a year without trouble. Today I loaded the machine like always and selected the settings I usually set and hit go. Nothing happened. The lights...
The Sunbeam 5891 is a disposable type for there are no user-servicable parts.
Here's more:
3. No, you were not able to confirm that your breadmaker is receiving power? Sorry to hear that. Attempt to have the breadmaker serviced by a small appliance repair facility or simply discard it.
Jun 17, 2011 | Sunbeam 5891 Bread Maker
It has stopped-no current at all. Plugs seem to be OK.
Jun 16, 2011 | Breadman Kitchen Appliances - Others
I have an Oster Bread Machine model 5839. The display and timer work but nothing else does.
All breadmaker use a belt and pulley system. If your breadmaker powers-up but the mixer won't turn when it's supposed to, your belt is probably broken. You
Jun 15, 2011 | Oster Kitchen Appliances - Others
I've installed a intermatic t101p201 which has a heater delay circuit - but can't get power to the heater through the delay switch when i turn the switch manually on - i haven't checked yet to...
Check that your pool heater supports optional fireman's switch
Black wires on firemans switch connect to pool heater. Power to fireman switch comes from pool equipment and not the timer.
If pool equipment does not support fireman, then cap off the wires.
Fireman switch turns off heater 15-20 minutes before turning off pump.
The purpose is so pool equipment lasts longer.
You can buy the fireman's switch separately, but if this is new timer, then switch is probably good.
Open following link to identify fireman's switch and related parts for the timer:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#fireman
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 30, 2011 | Intermatic HEATER DELAY SHUT OFF SWITCH...
Canon Powershot s1 is delay
Once you've set the self-timer, start it by pressing the shutter release button as usual.
Jun 09, 2009 | Canon PowerShot S1 IS Digital Camera
Indesit W 123 Front Load Washer Logo
191 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
