Question about Soltek SL-85DRC Motherboard
Mstr2kx Need update bios for this motherboard. I live in Ucraine. Help!
    Scholar:
  • 58 Answers
This is a tough one. It looks like they have let their website go down hill. Try calling them. Here are the numbers they have listed.
Rotterdam, The Netherlands
Tel 31-(0)10-245-7492 Fax 31-(0)10-245-7493
Taipei-Hsien, Taiwan
Tel +886 2-2642-9060 Fax +886 2-2642-9065
Posted on Dec 03, 2007
SOURCE:
Just got a brand new gigabyte motherboard,when i shutdown the pc it wont reboot. when the power switch is pressed nothing happens no fans,led, nothing. the board is a ga-990fxa-ud3,cpu- amd phenomII...
Hi Orville,
Your problem is all about your motherboard you need to updated to BIOS firmware to solve your problem.
Go to the gigabyte website then go to your motherboard page and download and updated to the latest firmware for your bios.
Steps in flashing BIOS
How to Reflash Motherboard BIOS About updating BIOS... The whole BIOS updating procedure should be treated with extreme caution. If you do not encounter any system instability or bugs with the current BIOS version, we suggest that you keep it. If you determine to flash BIOS, you are taking a personal risk of BIOS flash failure. Please contact your supplier or our distributors/resellers for further remedy in case system crashes unfortunately because of BIOS flash failure. Before you begin... 1. Please make sure the BIOS version you want to flash matches your motherboard model. 2. If your BIOS is flash protected, please do not enable BIOS Flash Protection under Advanced CMOS Setup (AMI BIOS) or Advanced BIOS Features (AWARD BIOS) in BIOS menu. 3. Never interrupt when you BIOS is being updated. 4. Because BIOS flashing is potentially risky, if you do not encounter problems using the current version of BIOS, it is recommended that you not flash the BIOS. To flash the BIOS, do it with caution. Inadequate BIOS flashing may result in system malfunction. Three BIOS Flash Utilities... We provide three BIOS flash utilities at our website. Below are the overviews. 1 : flashbios_qflash.gif A BIOS flash utility embedded in Flash ROM. Not all motherboards have the Q-Flash, please use @BIOS or DOS flash utility to update BIOS if your motherboard does not have Q-Flash. Features-- With this utility, you only have to stay in the BIOS menu when you want to update BIOS. No need to enter DOS or O.S. mode. Caution-- Make sure you have a functional floppy disk with the correct BIOS version for your motherboard. UEFI - Download PDF User Guide pdf.gif Download PDF User Guide pdf.gif 2 : flashbios_atbios.gif A Windows-based BIOS live update utility. Features-- @BIOS helps you search for, download, and then update the latest BIOS in Windows operating system. Caution-- Make sure your O.S. environment is stable. UEFI - Download PDF User Guide pdf.gif Download PDF User Guide pdf.gif 3 : DOS Flash utility Features-- The flash utility is a combination of AMI and AWARD BIOS flash utility. You can use it with both AMI and AWARD BIOS. Caution-- Make sure you have a functional DOS boot disk with the correct BIOS version for your motherboard.
I hope my solution may help you.
Thanks for using Fixya...;-)
Sep 18, 2013 | Gigabyte Computers & Internet
No image computer after BIOS update
try to get the old bios and put it again
Feb 05, 2018 | Intel Motherboard
I looking for microstar ms 7211 bios
You can find the BIOS update here:
http://www.msi.com/service/download/
Click on "Live update" and it will auto detect your MS7211.
Mar 07, 2011 | Computers & Internet
BIOS update on MSI KT6 Delta (MS-6590 v2 5.0)
You should be able to get it from here.
http://www.motherboard.cz/driver/msi.htm
Apr 26, 2010 | MSI Microstar KT6 Delta (MS-6590)...
Bios update
If updates are available, you can always get them from the motherboard manufacturer's website.
Why do you think you need an update? If something goes wrong like a power cut, or computer problem, your motherboard will be scrap. Doing bios updates is very risky and should only be undertaken if absolutely neccessary.
Regards
sir andrew
Nov 25, 2009 | Computers & Internet
Upgrade for mbd ms-7357
Click here for live update page for auto recognition of your motherboard to inform of bios and driver updates
Sep 09, 2008 | MSI G33M-FI Core 2 Quad/ Intel G33/...
848P neo ls
Hi hartterc, there is a bios update for the onboard integrated LAN card. The update, Set "Onboard LAN Boot ROM" to Enabled in BIOS. Bios Version 6.2 Date; 9-02-2006 File size 380KB.
Please allow MSI to run the (Live Update) program on you're system. If you allow this to run you will not need to download & flash you're bios.
That is what MSI states! Click on the link below for Live Updt.
http://global.msi.com.tw/index.php?func=downloadindex
You're mother board 848P Neo-V main web site.
http://global.msi.com.tw/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=582
Good Luck!
If you need help with something else, please post you're question here.
Mike
May 20, 2008 | MSI 848P Neo-V Motherboard
Bios update
Can you check the network or lan setting maybe because of the update the configuration is changes. try to re install the lan driver from your cdrom motherboard driver.
Apr 22, 2008 | Intel Motherboard
System reboots when acpi turned off
Hi martinkp, what you need is the update from windows. Leave you're acpi enabled withing the bios. Check windows update. Windows will update (windows software for the acpi). Rule of thumb concerning windows update. Check the dates of the updates & install in order, oldest to newest. This should fix you're system from shutting down. There will be no reason to turn off acpi after updating.
Mike
Apr 06, 2008 | MSI K9VGM-V Motherboard
Open Questions:
See all Soltek SL-85DRC Motherboard Questions
Soltek SL-85DRC Motherboard Logo
119 people viewed this question
Top Soltek Computers & Internet Experts
Ekse
Paul Bade
Steven Wander
Steven Wander
Are you a Soltek Computer and Internet Expert? Answer questions, earn points and help others
