Question about Compaq Presario 5000 PC Desktop
Compaq Presario 5000 Laptop
When I turn it on, it beeps a few time & the power light stay on but nothing else happens. F10 bios attempts does nothing. Should I replace the HD?
  • 31 Answers
Before you get too excited with buying a hard drive
Go Take a look at what the beep code means
And possibly it is as simple as reseating ram or something
http://www.bioscentral.com/beepcodes/compaqbeep.htm
Hope this helps you
Posted on Dec 02, 2007
When i switch on my compaq presario V2000 laptop it beeps three times and then freezes giving me the option to press f1 or f10 but when i press f1 or f10 it still doesn't work and is still frozen
Hi....
Actually beep sound indicates hardware error or BIOS error.
Don't press F10 while starting.
Let your laptop to start wait for 10min....
If it will not starts..........
Press F1(BIOS Settings for some pc F2 is Bois Setting)
If it will load BIOS.......... then your BIOS is OK
Then you need to change hard disk...
If not you need to change BIOS hardware(IF you i will tell you the way restore BIOS but it's very difficult task.It needs a trained person.)
Thank you have a nice day............
Feb 06, 2011 | HP Compaq Presario V2000 Notebook
Whenever I turn my Compaq on, the power button light comes on, the wireless button light comes on and the light beside the caps lock and pg up key flashes on and off however nothing is happening on screen....
deads'ville.
my old PC CQ60-220us, thanks for full number !!!
what os? VISTA?
those are called flash codes and have meaning!
the screen never once shows TEXT or HP /Compaq logos. right?
nothing to me means just the the TEXT IS GONE
"hit ESC to enter setup" or F2,F10,,etc....
carbon14 dated by me at 2008, ? (MY HP has F1 info page shows day made, a BIOS page F1) The year mATTERS.
steps below. for dead pc. means screen dead, and BIOS keys dead.
  1. take the battery main out, they short, remove it ;after all you can run like that for ever on the line pack, a fact. so do so now.
  2. does it power on, seems yes, does it stay on? (heard and seen)
  3. does the fan blow< spin and not packed solid in lint?
  4. use flash light pointed at screen , turn PC on the use the flashlight see data now? yes, bad black lamps CCFL, ask
  5. beep codes or caps lock flash codes,? write them down and tell the helper what the are? its code. like Morse code.
  6. there are more tests. does the CD eject button work?
my wild guess, (unseen by me) is the CCFL lamps are dead.
the LCD on this PC has lamps for the back lamp that all burn out
at 20k hours of usage. (short lived, if used constantly)
other tests are: ask
  • boot from free linux disk see of screen works?
  • replace coin cell battery they usually don't last 10 years. 7 max.
  • power pack bad and is weak, some fail weak
  • keep in mind black screen failures have many causes.
  • bad power, bad screen, shorts inside the pc, bad RAM.
  • also the GPU chips in 2008 were bad, defective, solder ball failures. making the screen dead or very odd.
here is a black screen page.
http://pcdied.com/black-screen.html#Laptop
HP is the best maker of PC.s (not custom made as I do)
but has best docs.
but they do have 1 weakness, BIOS docs and Beep/blink codes
horrible support there, due to changing the rules 20 times. or more.
HP also modified the BIOS to their needs, making generic lookups
on say Award BIOS useless.. ouch.
The older the PC the worse this gets, books covering that.
Sep 10, 2017 | Compaq Presario CQ60-220US PC Laptop
My PC won't start? every time i start it the fan just spins fast and loud and nothing happens, the screen doesn't show. this happened when i took the PC apart. it a Compaq presario sr1610nx
Initially test the monitor in another pc, if display available use the monitor in Compaq presario sr1610nx. Load to BIOS by restarting and tapping F1, if the display available, the computer is ok. restart and tap F8, if the advanced boot option screen comes up, the software is ok.
Restart the computer and tap F10 and proceed with a destructive recovery to reload the operating system on the computer
May 07, 2010 | Compaq Presario 5000 PC Desktop
Compaq presario 5000 desktop won't boot!
oh that means you have a power failure so you have to take it for a repair
Sep 24, 2009 | Compaq Presario 5000 PC Desktop
When attempting to start, laptop will not boot. I have tried all the different combinations for accessing the BIOS, but nothing happens. The hard drive light does not blink. I even tried a brand new hard...
if you cant hear the hard drive clicking or ticking, it sounds like theres no power going to it. you might be able to strip it down and see a wire or connector off.
Aug 21, 2009 | HP Compaq Presario CQ50-110US Laptop
Compaq Presario 5000 won't turn on
hi,
The machine is getting the power but no display.This seems a RAM or motherboard issue.
1.Press and release NUM Lock after turning on and if it is responding this is a RAM issue and if not then the mainboard issue but before all refix the RAM once.
Thank You.
May 30, 2009 | HP Compaq Presario SR1830NX PC Desktop
How do I restore my Compaq Presario computer to factory settings without the disc as I can't find it!
You first find a Windows installation disk valid for the licence sticker on computer, then download drivers from HP website.
Here driver page for Presario 5000 series :
Compaq Presario 5000 Desktop PC series - Download drivers
Apr 17, 2009 | Compaq Presario 5000 PC Desktop
Can't get pass COMPAQ page
Try to go into the bios settings and restore default settings. It could be a bad setting in you bios thats causing it. If thats not the case it could be bad ram. Are there any beep codes during this process? *Beep codes are beeps that happen when you turn on your computer and there is an error, Most mother boards use them.
Oct 01, 2008 | Compaq Presario 5000 PC Desktop
COMPAQ PRESARIO V-6000 LAPTOP WILL NOT TURN ON
try to start the computer and right after that press the delete key several times as it try's see if u can get into the system bios if so change everything to a default level make sure you pres the f10 to save all info and try to reboot if this doesnot work please let me know good luck
Jul 13, 2008 | Compaq Presario 5000 PC Desktop
Compaq presario will not come on
Hit F-8 and start in Safe Mode, do you have the back up cd's, let me know
Aloha
Kahuna
May 29, 2008 | Compaq Presario M2000 Notebook
Compaq Presario 5000 PC Desktop Logo
436 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
