Question about Video Cameras
Using Camcorders in Sub-Zero temperatures
Hi There,
Can you tell me if it is ok to use my camcorder/ camera in sub zero temperatures? Also are there any tips you can give me to stop my equipment from shattering due to the cold?
    Problem Solver:
  • 7 Answers
For operating temperature, check with the manufacturer's specs, usually near the end of the fact-filled manual. Even if it says 0-40 degrees, Most units will run OK below zero, but may have condensation problems when brought into a warm room.
Which of your equipment has shattered when cold? Did you drop it? Attach a wrist strap and use it or run a shoulder strap around your neck to keep your equipment from shattering due to the drop. ;-)
Posted on Jan 08, 2008
Lick my balls.
Posted on Dec 09, 2007
Sub zero 632
3C on the fridge side
-18C on the freezer side
Sub-zero repair in Orange County, CA
Jan 30, 2010 | Sub-Zero 632 / S
My Sub Zero 642 is freezing my fruits and vegetables. I have not changed the temperature settings. What's up? I did unplug the unit to reset it but it keeps having the same problem.
Usually a bad thermostat, but it can be a freon system problem, or a problem with your evaporator fan motor. These are problems that a good Sub Zero technician needs to repair, especially if you have a system problem, since a system problem is under a 6 to 12 year warrantee. Make sure that the company you call is a Sub-Zero warrantee company. Good Luck, Appliance Specialists
Jan 19, 2010 | Sub-Zero 642
Sub-Zero PRO48 fridge - Error Code 40 and EC91
Here are the most common Sub-Zero error codes:
Sub-Zero Error Code EC40: Freezer will not stop running
Sub-Zero Error Code EC50: Refrigerator runs too much
Sub-Zero Error Code EC24: Defroster is not heating enough
Sub-Zero Error Code EC 06: Evaporator thermistor reads inconsistent temperatures
Sub-Zero Error Code EC20: Defrost Bi-Metal Operation is faulty
Larry Rogers
http://sparkleappliance.com/ca/sub-zero-refrigerator-repair-los-angeles
Nov 08, 2009 | Sub-Zero PRO 48 Side by Side Refrigerator
Top shelf of old sub-zero refigerator 60 degrees, bottom shelf OK
u may have a defrost problem it would be worth paying for the service call if something simple like defrost or a fan would still be more than 200 but worth it
Mar 18, 2009 | Sub-Zero Bottom Freezer Refrigerator
Sub zero fridge doesnt turn off
If your temperatures are OK, then you have a bad thermostat control.
Feb 22, 2009 | Sub-Zero 650 / O Bottom Freezer...
We have a 5 year old side by side sub zero fridge/freezer (largest size)
check whether the temprature is set properly in the freezer on proper level.
Sep 27, 2008 | Sub-Zero 685/S Stainless Steel Side by...
Correct temperature for freezer & fridge
fridge should be about +4degC and freezer about -18degC
Sep 25, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero temperture fluctuation
Just posted this elsewhere and it sounds like the same problem:
As you probably know, the recommended temperature range is between 35-45 F so if your control will not allow you to set this, the sensor or associated regulator has failed.
This seems to be an issue with Sub-Zero.
Aug 02, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub Zero refrigerator
Its trying to tell you to call someone to clean the condensor.....nice feature! Sub-zero refrigs are very sensitive and will run too much and even possibly start icing in Refrig compartment.
Oct 09, 2007 | Refrigerators
Video Cameras Logo
74 people viewed this question
Top Video Cameras Experts
Marvin
Marvin
Are you a Video Camera Expert? Answer questions, earn points and help others
