Question about Frigidaire FGF378AC Gas Kitchen Range
Stove smoke and fumes
When I turn on the stove I receive a odor of fume also the stove begins to smoke
FRIGIDARE 30" GAS RANGE
MODEL # FGFL67DBG
  • 833 Answers
Bebbie,
You didn't say exactly what it smells like but I assume it is not the smell of gas. This sounds like spillage of food into an area of the stove and the subsequent heating of it. Depending on which burner (or the oven) is involved, you're going to have to chase this down and clean it. Since there is minimal chance that this is electrical in nature, your other concern is a partially plugged burner caused by the mess.
Some notes: Be sure that any flame you do see has a predominantly blue appearance. If it is predominantly yellow, there is dirt which is restricting the air supply. This can cause carbon monoxide which is deadly.
Posted on Dec 03, 2007
  • 22 Answers
In addition to what Bob Said, you may have some object or thing in contact with a hot part of your oven that you can't see. You will need a flashlight, rubber gloves and a cleaning solution such as dish soap and water.
First, turn off the gas supply and disconnect the plug from the power outlet. Then pull your range away from the wall and inspect in on all sides. Does there appear to be a lingering smell in one are? If so, check it out. Remove the pull-out warming drawer (see owner's manual for location of release latch) from the bottom and look inside. Is there anything there? Remove the oven door (see your manual) and inspect the oven area. Look at the surfaces (wall and cabinets) next to your range. Do they show any signs or scorching, or do they have a film or grease on them? If so, clean them off. you may have to give the stove top a complete cleaning. Be careful when cleaning the area around the igniters so as not to damage them. Look at the openings in the back of the range to see if they are blocked.
Look at the openings at the top rear of the stove next to the control panel. Are there any signs of fumes around the openings? If there are, it may indicate a possible problem with the wiring and it should be checked out.
Posted on Dec 04, 2007
Gas fumes from maytag range
"The professional gas installer has been here several times to check the. Gas lines." Ask the professional gas installer to do a leakage test and inspect for a cracked gas line.
Jul 29, 2017 | Maytag 30" Self-Cleaning Slide-In Gas...
Code comes of for leak evac the shop ran smoke and could not find a leak I got a new gas cap, I don't smell gas help?
Make sure the computer has been reset since changing the cap. Autozone, etc. will scan for free.
The smoke test should have caught the problem provided the shop looked at the gas tank too. There can be a problem in the electric solenoid valving for the canister which can be concealing a leak beyond the solenoid valving. If the solenoid is closing off the flow, then it can also close off the leak.
As for smelling gas, its the fumes which flow in these hoses, not raw gas. If the Vacuum system draws the fumes in, or if the leak is rearward, there is less of a chance of smelling the fumes. Rushing air from driving will dissipate many fumes.
Dec 23, 2013 | 2000 Ford Focus
1999 jeep smelling gas fumes and blows out black smoke.
burning very rich, is the check engine light lit?
Sep 08, 2012 | Jeep Cherokee Cars & Trucks
The oven leaks gas fumes into the house and will "blow up" if not opened every 30 minutes. it forgotten and left on for an hour, it may blow out from under. This oven was converted from natural...
incorrect conversion- valves to large - gas should not leak at all- should only FLOW when in use- TURN OFF GAS TO STOVE- EXTREME FIRE HAZARD
May 10, 2011 | Jade Ovens
Smelling fumes out the exaust tail pipe
would you please describe the fumes like raw gas fumes oil smell smells rich etc and color of the exhuast fume and if real smokey extra smoke
Sep 14, 2010 | 1993 Buick Roadmaster
Ventless gas log odor
kINDLY HELP WITH a description of this odor. If it is setting off your smoke alarm the flame or combustion is not complete or thorough.Are these new loggs or previously used without problem?Is the flue open on the chimney? The venting is apparently very poor if at all and the house is fulling with fumes. Turn the gas off, Open up the house to clear the air and check the flue, making sure it is open. Be safe.Ned
Oct 07, 2009 | Heating & Cooling
Burning smell during drying cycle, coming from the inside back left grate. The grate appears discolored.
Usually when a gas dryer overheats it's because of a defective cycling thermostat or a clogged vent system. Clean any lint from the internal and external ductwork, and/or replace the cycling thermostat . If you don't clean out the lint trap frequently, your dryer may have small lint fires inside the cabinet. The smell from these fires can leave a strong odor in the clothes drum.
Also, if there are any solvents, paints, lacquers, etc. in use in the house, your dryer may alter and/or amplify the fumes to an odor unlike the natural fumes given by the solvent, paint, etc.
Here's what to do:
  • First, clean all of the lint from the inside cabinet and ductwork of your dryer.
  • Have a qualified appliance repair technician inspect the dryer for damage caused by any lint fire.
  • Move all containers of flammable liquids at least 50 feet away from the dryer. Gas dryers have a large flame when operating properly and can ignite the fumes of any flammable liquid or gas.
  • Then, try to clear the odor, by running a couple of loads of old rags or towels.
Jul 11, 2009 | Whirlpool WGD6200S Gas Dryer
Exhuast smell(odor)
J,
If your Laser 56 is giving off fumes it is probably coming from the igniter gasket and the igniter guide gasket. The igniter gasket has broken and needs to be replaced with the new style. The new style cost about $12. The guide gasket is the fiber gasket around the hole the igniter goes in. It has seperated and all you have to do is smash it back together. If you have high temp silicone or furnace cement, you can use either to seal the crack. Any toyotomi dealer can get you the new igniter gasket # 17185580.
Good luck,
Tom Hawkins
hawkins111@gci.net
Feb 28, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Gas fumes
chech the fuel pressure regulator,its black incolor and has a vacuum line to it.It will be in the fuel rail.start the van and pull off the vacuun line, if fuel comes out its bad.
Feb 01, 2009 | 1999 Oldsmobile Alero
Door inside and metal vent area smells strongly of fumes
Did you find an answer toyour question?
My microwave smells also of petrol in the same areas.
Jun 05, 2008 | GE JVM1653 Microwave Oven
Frigidaire FGF378AC Gas Kitchen Range Logo
1,177 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
