Toolbar how i move my toolbar from verticaly to horizontaly?
Right click on it, make sure "lock taskbar' is unchecked, then simply drag to the side of your screen...
Posted on Dec 02, 2007
SOURCE:
Screen on side
You can use the desktop toolbar on your computer to help you navigate around your computer, gaining access to programs and files. You may have previously moved the toolbar to the side of your desktop intentionally or accidentally. You can move the toolbar back to its original position at the bottom of the screen and lock it in place to prevent it from being accidentally moved in the future.
Right-click on the toolbar at the side of your desktop with your mouse. Locate the "Lock the toolbar" option in the drop-down menu. If it has a tick next to it, this means it is secured in place. Left-click on the button with your mouse to unlock the toolbar. Left-click on the toolbar, and drag it to the bottom of the screen. Right-click on the toolbar, and select "Lock the toolbar" to fix the toolbar in place at the bottom of the screen. Hope this helps.
Dec 08, 2012 | Google Toolbar
Hello, I am removing an inoperative fuel pump from the tank of a 1995 850 Volvo Turbo. I got the large ring nut loose. Now I am having trouble with the two fuel lines. My question is do they come off by...
Not familar with your car but it may be you
need a fuel line release tool.
If you have plastic around the end of the hoses
they will have to be pushed in with the correct to
to release them
Jun 09, 2011 | 1995 Volvo 850
Battery operated mouse is not moving horizontal or verticaly
Try putting a piece of white paper under the mouse. Glass is often a problem as is the colour black for the mouse's sensor to see.
Mar 05, 2011 | Dell Wireless Keyboard Optical Mouse w0147
I have a pc3500g motherboard and need to know where to plug wires
Dear... Mr.A. Ganesh
From Chennai(India)
pin configurations are printed in the mother board.watch carefully .it may be just few inches away from the front panel connector.
Even u cant find it...
you dont worry about it.You just assemble the
Cpu ,SMPS
then switch on the main .
then short a moment( 1second ) at any two pins which is in the front panel connector ( using tester/sqrew driver);continiously cheak like this one by one pair of pin(Verticaly and Horizontaly).
when you short the corrrect pin,then system on.so you can find it like this.then connect the power button easily.
I am 5 years Experienced Engineer. Mother Board should not get any problem doing like this.
Thank you
Feb 12, 2010 | Computers & Internet
Toyota corolla. 5 years old. At built up speed of about 100-120 km per hour, a vibration of the entire car occurs, like driving over marbles. mainly at the rear. also pungent odour occurs resembling smell...
try to tyre/wheel balancing after you check up joint, tieroad and bearing by lift up car then shake the wheel verticaly and horizontaly so rotate to see it work properly.
Aug 31, 2009 | 2004 Toyota Corolla
Toolbar in my internet explorer is almost gone
Are you missing the Internet Explorer toolbar that displays the File, Edit, and View menus? If so, you might have moved the Yahoo! Toolbar, or some other toolbar over the IE menu, or you might have gone into fullscreen mode accidentally.
First, make sure you aren't in fullscreen mode. If you are, you'll only see the navigation bar with the Forward, Back, and other buttons at the top of your screen. If that's the case:
  1. Press the F11 key on your keyboard.
  2. The other toolbars in IE should appear.
You can press F11 as many times as necessary to toggle between normal and fullscreen mode in IE.
If that doesn't solve the problem, you might have accidentally moved one of your other toolbars over the main toolbar. Try the following:
  1. Directly to the left of the Y!, you should see a thin vertical bar.
  2. Click this bar with the left mouse button and drag the toolbar straight down.
  3. Your main IE toolbar should now be visible.
Once your toolbars are how you want them, you can right-click the IE toolbar and select "Lock the Toolbars" to keep them from moving accidentally in the future.
If you're still having problems with your Internet Explorer toolbars, you might need to visit Microsoft's Internet Explorer support website.
Jul 09, 2009 | HP Hewlett Packard Officejet J5780 Laser...
SCROLLING ON THE TOUCH PAD EDGE HORIZONTALY AND VERTICALY NOT WORKING
Solution, try updating or reinstalling the driver for your touchpad.
May 02, 2009 | Computers & Internet
Razer copperhead problem
I have something like you've all described with mine occasionally, normally, turning the mouse over and rubbing the laser surround with my finger vigorously is enough to clean off the crud that seems to be causing the problem..
I've never had any software problems or anything with mine..
Feb 18, 2008 | Razer RZ01050300 Mouse
Westinghouse LCD monitor
flicker to which side, horizontaly or verticaly. does it compress from both side or all side. only flicker from sides or from the center also??????????
provide proper information for solution
Feb 08, 2008 | Gateway FPD2275W LCD Monitor
Projection tv
How bad are the color? are they like three separate colors. If the colors are real bad all of a sudden, you may need a Pair if STK ICs.
Best regards
Circuitcity
Nov 03, 2007 | Sony KP-51HW40 51" Rear Projection...
Open Questions:
Computers & Internet Logo
Ekse
Alun Cox
