Question about Philips 26PF5320 26 in. LCD Television
Wrong remote for tv
I got a tv given to me a philips 61cm lcd HD ready and i can't get channels as can;t tune in the remote is not right one ..how do and if get the right will this tv work
    President:
  • 4,402 Answers
Have to purchase a compatible remote
Posted on Dec 03, 2007
SOURCE:
Hi, I live in a flat in London with a shared rooftop aerial (no idea of spec). I have a Sony KDL-46X2000. The built-in freeview tuner doesn't seem to recieve any HD channels. Is the built-in tuner the...
Make sure you have a good connection from antenna to TV. Check antenna and cable and cable connection to TV. Select DIGITAL button on TV remote when wanting HD channels. Remember HD channels are always digital. Also, any given TV station may not be broadcasting in HD at a given time. They can broadcast in digital but in standard definition sometimes. Your TV has a built-in DVB-T tuner. Try executing a channel scan to pick up all available channels. On-screen menus go to Digital Setup, then Digital Tuning, you can auto-tune or manual tune channels. The TV should take a few min. to scan thru available channels and store the channels its finds. Check with anyone in your area to see if they get HD channels (it is possible to be outside of the range of some TV stations) Your TV is a 2006 model and should still be compatible with local digital TV broadcasts but keep in mind digital signals could change in the near future (DVB-T2) and you may need a tuner/converter box to make the TV compatible.
May 01, 2011 | Sony Bravia KDL-46X2000 46 in. HD-Ready...
I would like to find the hd channel on my tv model le32r8
After tune in any chanel.Check ur tv remote display button on the remote control.Any tv channels play in 1080i modes are in HD channels.
Aug 17, 2010 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Trying to find a port for sound input on Philips DVI LCD TV.
If it is two-channel sound, the 'line' inputs should be color-coded as red (right) and white (left).
Feb 22, 2009 | Philips 23PF5320 23 in. HD-Ready LCD...
Philips LCD 17PF8946/37 TV not working
The good news is that the "No Input Signal" message means that your TV is not broken. If you are trying to watch cable, then you have simply turned the TV to the wrong input channel. If your cable comes into the Philips using a coaxial cable wire, use the Philips remote to change the channel to Ch.3 or 4 - whichever channel you normally watch cable on. Make sure the cable box is turned on if you have a cable box. If the cable box connects to the TV using another type of wire, use the Ch+/- on the Philips remote and go through all the AV channels until you find the right one. Good luck! Let me know if you need additional help.
-Tha Mp3 Doctor
Dec 30, 2008 | Philips 17PF8946 17 in. HDTV-Ready LCD...
Philips LCD TV wont change aspect ratio
In your philips menu there is an option to turn of your auto aspec ratio to OFF then using your sky remote go to services, 4 then picture and ensure that this is set to 16:9
Job done
Cheers
Little Dish Fitter
Dec 24, 2008 | Philips 32PF7321 32 in. HDTV-Ready LCD...
Green line problem
I had the same problem when we hooked up an hd satellite box. It's a simple solution using the Philips remote that came with your tv. The dial in the center of the remote with up down left right control will move the picture left or right up or down by holding the direction you want to go. Make sure to stand in front of tv.
Oct 28, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
PHILIPS 32PF7331/12 LCD TV
Press tv on sky remote then press help ,channel list appears . goto tv set use onset channel change button to scroll to hd channel .press volume up button onset to select.
Sep 28, 2008 | Philips 26PF5320 26 in. LCD Television
Multiple issues with tv
Pressing i+ button (bottom left on the original remote) for 5+ seconds worked for me...
Feb 21, 2008 | Philips 32PF5320 32 in. HD-Ready LCD...
Philips 26PF5320 26 in. LCD Television Logo
139 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
