Question about Linksys Wireless-N WRT150N Router
3rd party firmware broke my router!
I have a linksys WRT150N, and I installed some 3rd party firmware(dd-wrt) to try to make it act as a wireless bridge. It failed to work, so I'm attempting to upload the linksys original firmware which I downloaded off the linksys site. However, the dd-wrt firmware refuses to let me upload the linksys image. Any ideas?
  • skyslash7388 Dec 04, 2007
    I downloaded the correct firmware, but because the dd-wrt firmware came out after the linksys firmware, it refuses to back up
  • Anonymous Mar 15, 2014
    dd-wrt
    Problem Solver:
  • 15 Answers
Did you check whether you have downloaded the correct firmware for your linksys???
Posted on Dec 04, 2007
  • roshan376 Dec 04, 2007
    1. DD-WRT is partially supported on this router. 2. Since the
    available memory is too small nothing usable can be accomplished by
    upgrading the firmware. 3. work is going on on several fronts to get
    DD-WRT micro edition compatible with this router. 4. A lot
    documentation is available to install a USB port as well as a serial
    console on this hardware. The FCC ID for this particular router is FCC
    ID: K7SF5D7234A I decided to go ahead despite the fact that the router
    is partially supported by DD-WRT, You can easily recover from a bad
    flash by making sure the firmware is available to the router during
    startup. As stated on most sites I was able to flash the router
    successfully and got WLAN working but LAN ports were not working
    properly. Some of the sites that I found useful were
    1. haxxed.com : Custom firmware for Belkin routers with 2MB Flash
    2. F5D7230-4 v2000 firmware : Original firmware for the Belkin F5d7230-4 v2000 router.
    3. TFTP server : TFTP server used to upload the firmware onto the router.
When I setup the unit as a repeater, after rebooting it freezes and looses the connection. I have tried several times and aloways get the same results. e-mail w6opi@razzolink.com
This normally has to do with wireless encryption. If you use WPA encryption disable it and enable WEP or, for the time being, no encryption. Then retry.
Most routers do not support repeaters while using WPA wireless encryption. It is a known fact. Only way around that, is to install 3rd party firmware if your router supports it, such as Tomato or DD-WRT (my favorite).
More info about tomato: http://www.polarcloud.com/tomato
More info about DD-WRT: http://www.dd-wrt.com/site/index
Best of luck,
Mar 06, 2011 | Encore ENHWIN3 Wireless Router
Linksys WRT160N Connection Issues.
Sadly, this router has horrible reviews and is known for this problem:
http://www.newegg.com/Product/ProductReview.aspx?Item=N82E16833124277
Can you return it for another model?
Can you getLinksys to replace it?
the best one is the LINKSYS WRT54GL, but if you are stuck with the one you have...
If you have tried all these things and you are very brave (or don't care if you need to buy another router) why not try flashing it with an after market O/S?
1) http://www.coderetard.com/2008/05/30/install-dd-wrt-firmware-on-linksys-wrt150n-wrt160n-wireless-routers/
2) http://www.dd-wrt.com/phpBB2/viewtopic.php?t=32576&highlight=wrt160n
Oct 13, 2009 | Linksys WRT160N Wireless Router
Connection Drops . wrt150n disconnecting
This is a firmware issue with the newer Linksys routers, and most people are having the same issue. Don't expect a stable firmware release from the manufacturer any time soon.
Instead, if you want to fix the problem properly, head on over to www.dd-wrt.com and install their firmware. I did this in a last ditch effort before throwing out my router, and now the router hasn't acted up for more than 10 days.
Be sure to follow the instructions when flashing firmware, several of the steps are critical to not "bricking" your router. As usual, make sure you are on a WIRED connection, as flashing from a wireless connection is guaranteed to kill your router. When flashing dd-wrt's firmware, you must also first flash a "mini" or "micro" version before flashing the full version.
Jun 07, 2009 | Linksys Wireless-N WRT150N Router
Configure wrt54g2
IF you mean "File Sharing" as in your own network of PC's on your network, then all you need to do is turn off sharing option within windows. Your router will not set sharing your folders, drives, printers, etc.
Check your windows setting in "Networks", then "Sharing" and set the appropriate options for your needs.
Hope that helps.
RJ
Apr 15, 2009 | Linksys Wireless-G WRT54G Router
Linksys N router drops signal
Its not dropping you because of the spectrums, it works on line of sight. If you are in a basement and your router is upstairs it has to go thru a floor and the strength is weakened. Go into your router and increase the signal strength. But you have to mod your firmware.
Here is a link to update your firmware.
Jan 24, 2009 | Linksys Wireless-N WRT150N Router
Wrt150n dd-wrt firmware slow loading pages
First off thanks for using fixya.com
Second, I too am a dd-wrt user and found a similar problem when using dd-wrt with my IPCOP. You may want to go into the "Security" section of your dd-wrt and disable any fire walling or access-restrictions. Since you are already running zonealarm. Or remove zonealarm if you plan to use dd-wrt as your firewall.
Running multiple firewalls will slow down your network/Internet traffic.
Hope this helps you out.
Jei
Dec 15, 2008 | Linksys Wireless-N WRT150N Router
Linksys Wireless-N WRT150N Router Logo
681 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
