Question about Toshiba D-VR600
Craig dvd player problem
Craig dvd player: the standby light is on and no matter what we do wont turn off. tried every button and even unplugged and pullred the fuze.
what do i do. i cant find the manual
I cannot turn mine off either. I can't eject the videotape that is in it. No button will do anything. I have tried eject, tried the off button on both the remote and on the device itself. I have made sure it is set on VCR and not DVD. Help!
  • 749 Answers
Unplug the unit for a while. then turn it on
Posted on Dec 02, 2007
SOURCE:
ICraig Tower Stereo system will not turn on from standby
sometimes the system can get a little "rusty" after inactivity. The most common simple solution is to unplug it then plug it back in
Jan 01, 2014 | Craig Tower Speaker System For iPod,...
MY MEMOREX DVD PLAYER suddenly WONT TURN ON?
Unplug power cord, wait 30 sec. Plug back in. Worked 4 me
Mar 20, 2011 | Memorex MVD2042 DVD Player
Unit on standby mode only, the dvd rack didnt open when open button was pressed.
Turn off and unplug at mains Plug back in and turn on press standby button so power light come son. If pressing open button on player (rather than remote) doesn't work it may be a disk that is not sitting properly in the tray. You could try sliding a very thin blade (preferably something with an insulated handle!) gently in the top of the tray to press the disk downwards whilst gently prising under front edge of the tray with a small screwdriver. If you can manage to press the open button at the same time as doing both these things it may help.
If that fails to solve the problem it may be a broken drive belt or worn cogs in the tray operating mechanism. DVD players are so cheap these days that repair is seldom worth the expense.
Feb 23, 2011 | Philips DVP642 DVD Player
My little colby dvd player wont open or close and it wont turn off. if it would open, i would try to reset the remote..yes, i have plugged and unplugged and have it plugged directly into tv???
I assume you've tried plugging into a wall socket instead of TV?
Probably won't work, but push and hold power button on unit 10 seconds then release, for that matter try all buttons. Not uncommon problem, usually you have to UNPLUG unit, disassemble to remove DVD and discard unit if cheap enough.
Sep 26, 2009 | Televison & Video
Jvc rx-dv31 standby light comes on, but wont turn on, just clicks then turns off
sorry but this is an electronic malfuction or failure , it will need repair
leave it unplugged to prevent further dammage untill you can take it to your local electronic repair shop
electech
Oct 27, 2008 | JVC RX-DV31 DVD Player
DISC STUCK
It should not matter if it is a DVD or CD, because the CRAIG CVD327 palys both. It must be some other problem. Also, use the button and not the remote.
Sep 24, 2008 | Craig 731398403288
did you ever find out what was wrong...mine is doing it too...
if so, please write to me. Kathy [email protected]
Dec 02, 2007 | Televison & Video
DVD player stuck in standby mode
Bad caps in the power supply is causing this. C17 (10v,470uf), C17,c14 (10v,1000uf) and C18 (10v,470uf). Replace with same capacitance values but 25 volt rating 85 C. Just fixed mine half hour ago works great.
May 27, 2007 | Onkyo DV-CP500 Multi-disc DVD Player
Toshiba D-VR600 Logo
112 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
