Question about Canon CLC 1000 Color Copier
CANON CLC1000 I have canon clc 1000 and there is an error E020PLEASE HELPE THANKS ALAA
  • Anonymous Mar 27, 2009
    Helow
    I have error (E 350) I know this is (ECO) board but how I can cleard
    for the canon clc 1000
    Thakn you.
Hi, the error code of all canon clc series, have this type:
E xxx-xxxx
this are an specific trouble and with this code complete, we can sugest any solution, how our partner has wrote, the problem are localize in the toner supply section, but we need more info about the error code, please be more specific, and all can help you to fix this problem, good luck, budy.
Posted on Dec 21, 2007
  • Canon Master
  • 1,113 Answers
E020 refers to incorrect operation of toner moter, jammed up toner hopper or motor stuffed.... If toner hopper is overfull, the toner motor worm gear splits as a result of the hopper becoming packed tight. If the hopper is 1/2 full or less, the worm gear splits under normal use.
add toner only when the toner light is lit, right away, and replace toner motor.
After verifying that the toner hopper is working properly, check that the web solenoid is activating. Clean the web solenoid and ensure free action. This has been known to clear an E020.
After verifying that all is well with the toner hopper unit, consider the DC controller.
Posted on Dec 02, 2007
Canon CLC 1000 error code E075 - 0004 please help me get rid of it
[Phenomenon]
Error code E075
[Cause]
Because of the factors listed below, some problems may occur in the controls to prevent the transfer belt
shifting to one side due to malfunctions of the swing motor assembly and in such a case error code E075 gets
displayed.
1) Sliding fault of the part A in the Fig.1
2) Deformation of the sheet metal of the swing motor assembly
[Factory measures]
1) The resinous material has been added, as shown in the Fig. 2, to improve sliding.
2) The reinforcing sheet metal has been added, as shown in the Fig. 2, to prevent deformation of the sheet
metal of the swing motor assembly.
When the error code E075 gets displayed, run checks as described in the Service Bulletin CLC1000-005
(CAUSE OF PROBLEMS BROUGHT ABOUT BY ERRORS OF THE TRANSFER BELT
MECHANISM). If the error code E075 still gets displayed even after running the checks, replace the old
swing motor assembly with the new type by, following the instructions on removing the transfer belt swing
motor assembly described on page 4-50 of the Service Manual.
Affected machines
NFH01171 and later
PFH00044 and later
QFH00129 and later
RFH00079 and later
SFH00221 and later
TFH00127 and later
UFH00657 and later
Jun 11, 2010 | Canon CLC 1000 Color Copier
Hi i am gettin E061 0423 error on the canon clc1000, what is the problem, and how can i turn this copier on service mode. tanks a lot
try "*” (Additional Functions) button, then immediately pressing “2” and “8” together, followed by the “*” again. This is known affectionately as the “star-twenty-eight-star” among Canon service techs.
Apr 03, 2010 | Canon CLC 1000 Color Copier
Hi i am getting E061 0127 on canon clc1000, what is this error means? thanks
Basicly the code means that one of the 4 drums is not charging correctly. You may have to change the post charge wires and or one of the drums
Apr 02, 2010 | Canon CLC 1000 Color Copier
I need to get the drum for clc1000 Tambour code 1355A002(AA) F43-4801-700 and the Developing
Dear sir; please contact with me at 973-533-6778 I can get it for you. HAVE A HAPPY HOLIDAY !!!
Dec 17, 2008 | Canon CLC 1000 Color Copier
Whate can i do plz ??
your transfer bed and sheet change the transfer sheet also clean the whole bed
Sep 05, 2008 | Canon CLC 1000 Color Copier
Error code E350-0000 on canon clc 1000
the connection between eco-id pcb and reader controller is faulty, canon do not make reader controller anymore
Sep 03, 2008 | Canon CLC 1000 Color Copier
HOW TO CLEAR ERROR E350-0000
Did you recently clear RCON and tried to due a CCD adjust? The problem could be the that the left side glass retainer changed or mared or has a doc feeder been added or removed. There is a bar code on the under side of it. The part number for the 1000/3100 is FF5-4662-020, the 2400 FF5-8802-000
Jan 25, 2008 | Canon CLC 1000 Color Copier
Error E073-0004
You need to call a copier technician, first and foremost.
This error code indicates that there is a problem with the transfer drawer connector inside of your copier. You've probably blown a fuse, like the FU903 on the DC fuse board.
There is nothing you can do if you aren't a copier technician. Call one right away; the technician can probably fix this in about ten minutes.
Dec 05, 2007 | Canon CLC 1000 Color Copier
E073-0004
Answered elsewhere, but answering here too:
Canon CLC 1000 Color Copier Logo
237 people viewed this question
old marine
old marine
