Question about Mitsubishi WD-52327 52" Rear Projection HDTV-Ready Television
TV will not turn off
I recently changed the lamp on my TV, removed the display screen and cleaned the reflector mirror. I had some issues with the lamp insert and the receiving plug had to be retreived from the back of the TV. All went back together fine and the TV looks great.
However, now my TV will not tun off, either with the remote or via the front panel button, but it turns on with both. I even took off the display screen again and checked the wiring harness and front panel processor board, and all look OK.
After the above issues I had to disconnect my cable convertor box and change that out. When disconnected, the TV turned off as it should. I recently replaced that convertor box and am now having the same issues.
I have had the same configuration for 2 1/2 years with no problem until now.
Any syggestions?
Thanks.
  • Anonymous Mar 21, 2014
    A stink bug is displayed on the screen. I have removed the lamp and the stink bug is not there. There are two circular "access" panels on the back of the TV, one on the left and one on the right. Can I use these to get to where the stink bug is?
  • 42 Answers
Wow.. How is the TV plugged in? I had someone with a Samsung DLP do this but hers was plugged into the cable box that was plugged into the surround sound receiver which was plugged into a back up which was finally plugged into the wall. Feedback caused an electrical feedback causing really really odd tendencies.
Second, that connetion between panel and set has a row if pins make sure the second one is not bent because it could be on permanently or causing it to have a constant connection . It is so hard to explain this hope this helps.
Posted on Jan 24, 2008
In my ir3300 xerox in very light if any setting is there make to dark print?.... what is the setting can u help me ?plz
Check your drum. if drum is ok clean the laser unit and clean the drum unit and chraging roller.
And clean the laser scanner lamp and the Mirror.
You must alert while cleaning the mirrors(Reflectors) don't use thinner, alcohol and stain removers for cleaning scanner lamp and mirror don't do that to movements the reflectors just open the copy board glass and clean with a cotton.
Jun 26, 2016 | Canon Ir 3300 Black & White Copier
WHEN PRINTING ID CARDS THE PICTURE IS BLURRE BUT WHEN COPYING ORDINARY ORIGINAL IT IS GOOD.
Clean the Feeder glass with cleaner problem will be solved.
  1. For clear image decrease the Density.
  2. Clean the Laser Scanner and Reflectors(Mirrors).
Don't Do That
Do not use hard stain removers and alcohol while cleaning laser Scanner Lamp and Reflectors.
Also clean with a cotton.
Jun 13, 2016 | Canon Ir 3300 Black & White Copier
My mitsubishi 65in tv has a lot of small white dots on the screen what causes this?
projection tvs can display white dots from the dust that is on the reflector mirror your lamp shines the picture on before it is reflected onto the front screen of your tv, one must be very careful when cleaning this, may be worth a service man doing it for you
Mar 07, 2013 | Televison & Video
I have a 65 inch syntax brillian TV. The picture is pretty dark, and I'd like to clean the mirrors and lenses. How do I do that?
Shannon, cleaning the mirror or the lens will only drgrade the picture that's reflected onto the screen. A dark picture is most likely caused by the ~300 watt lamp aging and now needs replacement. You can confirm this for yourself by removing the lamp from behind the right hand speaker door and looking at the bulb-shape at the inside, bottom of the reflector. The bulb should be clear, with maybe a small white patch on the top of the inside of the electrod chamber. If it's a large white patch, or the chamber has any black, or even worse has a deformed chamber, the lamp only needs to be replaced.
I did the longevity testing for the 65" TV's. No other component caused the TV to 'darken' as you state....
Jun 19, 2011 | Syntax-Brillian 247T FHD 47 in. LCD TV
Mitsubishi wd 62527 has very dark picture changed
Clean the small front projection mirror. That mirror can get dust on it and will cause the projected image to appear dull and dim and cleaning that mirror will usually restore the brightness and crisp details in the image.
Oct 20, 2010 | Mitsubishi WD-62725 62" Rear Projection...
Dark, ghost-like, triangle-shaped area in upper right part of screen. Picture shows thru the area. What causes this?
I had the same problem on my 50" DLP. Today I took the light projection mechanism apart to get to the mirror tunnel (a piece about 1.5" long located between the projection bulb housing and lens housing) and, for now at least, the shadow problem has been corrected on my TV.
It would be difficult to describe in detail without photos of how to remove the mirror tunnel. Briefly, once the lower rear cover is removed, it involves completely removing the entire assembly of the projection bulb and lens, along with disconnecting 3 or 4 cable connections. This assembly is held in place with 3 large screws around the projection lens housing in the lower center of the TV. After it's completely removed from the TV, removing smaller screws will break down the component parts. Once you locate the color wheel (about 2" in dia.) between the bulb and lens, the mirror tunnel is directly adjacent to it.
Handle it all with care, and I strongly suggest that you immediately cover the protruding projection lens will a lens cleaner cloth (held by rubber band) so it doesn't get scratched or smudged while you're working on the assembly. This will all make more sense after you get into it. Just remember where everything goes, both cables and screws!
My four mirrors had indeed shifted into a flatter parallelogram than it should be. On my set the metal tunnel casing is molded so that it doesn't allow for the mirrors to be in the shape of a rectangle; it requires a parallelogram shape. The mis-shapened tunnel caused a small portion of the metal mirror housing (on the lamp end) to protrude into the interior of the tunnel, hence the shadow on the screen.
To re-shape the mirrors I gently inserted a nylon cable tie--with a sharpened leading edge--into the tiny gap behind the mirror that had shifted. In doing so the mirrors shifted back to the proper positions and stayed there when I removed the cable tie. (Be very gentle with the mirrors and do not insert anything into the tunnel!)
It's not clear why this (now restored and larger) gap behind that one mirror even exists, but to ensure the the mirrors don't shift again, I inserted and left in a length of cable tie (which is near perfect in thickness and width) in the gap. Time will tell whether heat will deform it.
Perhaps a similar-size strip of metal would be better but I didn't have one. And I would not use any kind of glue or adhesive on these mirrors (as others have suggested); with their small size and the need to keep them crystal clear there is just too much potential to royally mess them up.
After putting it all back together and testing, the shadow is gone. Hope this helps and works for others!
Nov 25, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
Cleaning the bulbs and mirror on my Mitsubishi 55" WS-55313 TV.
You should re-consider having a tech do that for you. The access is by removing the screen assmbly which are somewhat fragile. If you want to give it a try, pull the speaker grill off, it comes off just from pulling it, there should be five screws across the bottom of the screen assy, remove those, there is also an access door on the front of the set with four screws, that has to be removed to unplug the cable that goes to the screen sensors. The screen assy has to be lifted straight up an inch or two and then you can pull it forward away from the set.
As far as cleaning the mirror and lenses, you can't get to the face of the tubes so it's the top of the lenses that you clean, just use a soft lint free cloth (cloth baby diaper) and wipe the dust off the lenses, you can slightly dampen the cloth with water if necessary, same type of cloth on the mirror and you can use a glass cleaner on it just don't press too hard on the mirror.
Jan 31, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WD-62527 replacement lamp install and brightness low
as i previously posted, my picture was dim, muddy looking after replacing lamp with osram lamp. i fixed mine by taking the screen off and cleaning the small mirror. it had a thick layer of dust on it, cleaned with a microfiber cloth. no water, no glass cleaners. i also used a very fine new small paint brush and dusted the projector lens which also had a dust film. brightness, contrast and clarity returned!
Dec 23, 2008 | Mitsubishi WD-62725 62" Rear Projection...
DARKEND SCREEN SONY KDF-E55A20
How long has it been since you last changed the lamp and did you use an original Sony Lamp? It sounds like the lamp is going bad.Pull it out and examine the reflector. If it is all cloudy, it is time to replace the lamp. The reflector on the new lamp will be shiny like a mirror. Please be sure to rate this solution. Thanks!
Nov 08, 2008 | Televison & Video
Hitachi rear projection lcd lp500 series
It is likely the projection lamp is weak, causing the picture to cycle on and off. Take the lamp out and examine the reflector. If it is dull and cloudy, it's time to replace the lamp. A new lamp will have a reflector that is shiny and looks like a mirror. Be sure to rate this solution. Thanks!
Nov 08, 2008 | Hitachi 60V500 60" Rear Projection...
Mitsubishi WD-52327 52" Rear Projection HDTV-Ready Television Logo
49 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
