Question about Dell (228GN) Computer Speakers
Computer speakers My computer speakers are hooked up to the back of the tower case to the audio out line properly but they still won't turn on
    Problem Solver:
  • 15 Answers
Is you motherboard an integrated one?
If yes which make
If you have a sound card, please specify the make?
Then only the probable solution will come up
Posted on Dec 04, 2007
    Problem Solver:
  • 16 Answers
Hey ro512
try this;
1.) re-install the proper audio driver on your computer
2.) check the setting on the control panel of your audio devices, and make sure that it is not muted..
3.) touch the audio plug which is the bbplug of you speaker system, and you heard a scraching sounds
4. ) after all you find the solution of the problem...
regards
  • 70 Answers
Hi... Is the any error message while you play sound like driver problem? if yes install proper sound driver...
check the mannual and connect the speakers correctly...
Posted on Dec 03, 2007
Need to install proper sound drivers
SOURCE:
My speaker jack broke off inside my audio input in the back of the computer. I want to use the thermaltake case's front usb and audio out/mic in jacks, but they don't seem to get power or work. My drivers...
> Have you removed the broken jack from the rear end of the pc ?
> Are you trying to use the audio ports on the front panel ?
> if you are trying to use the audio port on the front panel you will first need to remove the piece of the broken jack stuck in the rear port - cos you can take an audio out line either from the front OR the rear any one
Oct 22, 2013 | Thermaltake Mid-Tower VL10001W2Z Element G...
How do i hook up logitech speakers #z313 to my desktop i need a diagram
Phone jack on woofer goes into computer tower (should be color coded green) and power cable on woofer plugs into 120VAC. Speaker phone jack plugs into back of woofer. The speaker cable has an on-off switch and volume control as well as a phone jack for your headset.
Nov 14, 2012 | Logitech SPEAKER SYSTEM Z313 PC Multimedia...
How to double check speaker hook up on asus desktop computer
maybe they have the volume muted. Check to make sure the volume is not muted and that the speakers are plugged into the light green port in the back of the computer.
Make sure the volume on the physical speakers are turned on and turned up. And make sure the volume in the Audio Sound Properties it turned up and not muted.
If you see the speaker megaphone at the bottom right near the time click on it to adjust the properties.
You can click Start/Control Panel and look for Sound or Audio properties.
May 02, 2012 | ASUS Computers & Internet
Speakers are hooked up but no sound
May 02, 2012 | ASUS Essentio Desktop with Intel Pentium...
I don't know how to install my logictech Z523 speakers; they are hooked up but no sound and not installed; computer doesn't recognize them and my fiance threw out the instructions so I don't know how or...
Your "line in" from speakers should be plugged into the green (output) port on the back of your tower or the headphone jack on laptop. You will need to hook the 9 pin connector from the right speaker to the subwoofer. The yellow line from left speaker plugs into port labled "subwoofer" on subwoofer. Plug your power cord from speaker system into an outlet. Turn them on, adjust volume. There is no software for this product.
Mar 24, 2011 | Logitech Audio Players & Recorders
Hooked up New Hp comp (tower only) to slightly new HP2007 monitor but there is no sound.Could you give me an idea of what I missed?
Make sure the audio cable supplied with the monitor is connected correctly. Make sure it is connected to the green (speaker out) jack at the back of tower and the same green (audio in) jack on the monitor. Also make sure the volume on both your PC and monitor is turned up and not muted
Dec 03, 2010 | HP W2007 LCD Monitor
How do I hook up my logitech speekers
If you're running a tower, you jack it into the speaker or audio output on the back of the unit. If you're using a laptop, you run the speakers by plugging the 1/4" stereo plug into the headphone/audio output jack on the front or side of the computer.
You have to make sure you're hooking up the input to the Logitech speakers- refer to your manual for details, or read the fine markings on the speaker power supply and audio input jacks.
Good luck, and hope this helps.
Oct 21, 2010 | Office Equipment & Supplies
My speakers seem to be stuck on a very low volume
I have speaker problem no sound but I know its there because when I turn on volume can hear it turn on it was working before my computer is hooked up to magicjack for my telephone different area code then where I live and the other day when I picked up reciver to make a call could hear my speakers on my phone assastance asap PLEASE
THANKS
Marie
Jun 02, 2009 | Logitech X-240 Computer Speakers
Starlogic monitor speakers don't work
do you have a cable hooked into the audio port on the back of the monitor? this will go to the audio out on the back of the desktop box. let me know
Jan 26, 2009 | Star Logic 17" LCD Monitor
127 people viewed this question
Top Dell Audio Players & Recorders Experts
Ekse
Marvin
Marvin
Steve Mason
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
