Question about Acer TravelMate TM3012WTMi (LXTAT06045) PC Notebook
USB Midi Controller
Hi. I have purchased an M-Audio Keystation 61es Midi Keyboard for use with my laptop. Its a plug and play midi device and works seamlessly with all Windows Xp based computers. However it doesnt seem to be working with this perticuler model of Acer Laptop (TM3102WTMi) I have tried it on 3 laptops and i am having a similar problem. Windows detects the USB device...and installs the drivers withouht any problem. However, none of the softwares (FL Studio, Reason, ACID) seem to recognize an installed Midi Keyboard. On the other hand...all other PC's i have tried it on dont have this problem. All softwares detect the device instantly. I have recovered the latop to its original factory settings. The problem still persists to continue. Please advise
  • 383 Answers
The 'Add New Hardware Wizard' and force it to install the non-certified M-Audio drivers that were supposedly installed when running the M-Audio installer. (Skip internet search, and browse to M-Audio folder in Program files, it will eventually find them.) There are two M-Audio USB drivers that need to be 'forced' via New Hardware Wizard. But Windows thinks its drivers are a better match and even though 'device is working properly' it doesn't get recognized in your software. replaced them with the 2 USB ones from M-Audio, DAW finally recognized the keyboard. I even went through regedit to clean up all the M-Audio stuff so I could get a fresh install.
Good Luck you can do this /Have a great Sunday and a safe one.
Posted on Dec 02, 2007
SOURCE:
Factory reset
Playing around with the Transposition have we? I would read the manual first. Specially the "Advanced" bit.
Nov 04, 2013 | M-Audio Keystation 61es USB MIDI...
I have an M-Audio Keystation 61es. Lately I've had random loss of power through the USB2.0 cable. The cable still powers my other M-Audio products, so the issue is the Keystation. It is possible...
I have the 88 key ones and powering via the USB is marginal... IF you have a place for an adapter, use one, as the computer USB is limited to 1/2 amp and OFTEN they limit at a little less and then the keystation is not reliable...
Aug 30, 2011 | M-Audio Keystation 61es USB MIDI...
I recently purchased the Keystation 88es and I have installed the Able Live Lite 6 on my computer. I have installed the USB MIDI series 5.0.1 from the M-Audio website. I have plugged in the usb port as...
First step is to download Midi Monitor http://www.snoize.com/MIDIMonitor/
just to make sure you're actually getting midi over USB into the computer. This is a great utility that I use all the time for troubleshooting midi data issues.
Feb 28, 2011 | M-Audio M Audio Keystation 88es 88 Key USB...
Keystation 61 key won't play
Most of these use conductive rubber pills that are pressed onto circuit board traces by the keys.
Clean the board AND the pills with 99% isoprophyl alcohol and QTips.
May 31, 2010 | M-Audio M Audio Keystation 88es 88 Key USB...
M-audio 88es, I plug into my laptop using windows xp and no sound
You have to install software to connect the device to the General MIDI input. This rquires a driver for the 88ES.
Mar 08, 2010 | M-Audio M Audio Keystation 88es 88 Key USB...
The piano wizard software won't recognize keyboard
you should go to your  utilities --> audio midi setup and make sure your system is recognising your midi device. Play around with your midi settings, see if you can get something going.
Otherwise the problem maybe with the software clashing with Leopard. Double check on the manufactures website that their software is compatible with 10.5.6, or they may have an update for you.
Thirdly you could check if you keyboard is working correctly by opening garage band and making a new software instrument track, press record and see if you get any thing.
Good Luck hope this helps.
Mar 22, 2009 | Wizard Publishing Piano Wizard PREMIER...
Oxygen 8 Recognized but not working in OSX
i read somewhere, and it worked for me, at least in logic, that when i plugged it into a usb powered hub, it showed up in the audio/midi setup as a keystation and logic accepted its input..... when i had it plugged into the cpu direct (w/o hub) it was useless.... hope this helps....
Dec 18, 2008 | M-Audio OXYGEN 8 USB Controller
M-Audio keystation 49e stopped working
JA user_offline.gif vbmenu_register("postmenu_31136", true); M-Audio Tech Support Join Date: Jun 2008 Location: Irwindale, CA Posts: 5,033 icon1.gif "I asked our repairs department and they said the problem is either the main board or the velocity board. You can order both boards from our repairs department and return the one that is not needed. The main board goes for $20 and the velocity board for $14. 626-610-2529, Mon - Fri, 9am - 5pm Pacific Time."
I just found this in the M-Audio forums. I've just called the number and left a message at M-Audio requesting a callback. I'm really hoping that tech support will have a solution for whatever is causing this malfuntion. . . I'll post here again when the parts come.
Aug 16, 2008 | M-Audio Keystation 49E 49-Key Entry-Level...
Problem with "M-Audio 49e keystation"
Buy a Mac, Then you won't have that problem.
Oct 21, 2007 | M-Audio M AUDIO RADIUM USB KEYBOARD...
Acer TravelMate TM3012WTMi (LXTAT06045) PC Notebook Logo
209 people viewed this question
Ekse
Alun Cox
