Plss help!!! i cant start my windows normallyi can only open it in safe mode
    Problem Solver:
  • 10 Answers
If the problem occurs again , better re-install your operating system.
Posted on Dec 03, 2007
    Champion:
  • 209 Answers
What operating system you have? win98? win2000? or winxp? there are several reasons an operating system can not proceed due to corrupted os, hardware conflict and so on. if you are using winxp you just simply run this installer by clicking the repair instead format. with this the corrupted part of the operating system will be replaced and some drivers of your hardware which have been corrupted or unistalled will be replaced
Posted on Dec 02, 2007
SOURCE:
When i turn my pavilion dv6647cl it turns on in a second but then it turns off unexectedly.. sometimes it turns on normally..plss help me guys!
It seems that your OS has registry problem.
- Start PC in safe mode, normally Pressing F8 key when windows starts up.( Google it)
- In Safe Mode create a new user, with administrator privileges and protect it with password.
- Remove unwanted software's & programs.
- Empty the Recycle Bin.
- Download reliable program Reginout to fix OS registry properly.
- Restart your PC normally and log on to the new account created.
After performing these tips your problem will be solved.
Oct 07, 2013 | HP Pavilion dv6647cl Refurbished Notebook...
I can run laptop in safe mode with networking only at moment - on normal screen it freezes once connected to Internet - cant get any further than desktop screen - cant open anything and can't then...
When did the problem start?
What internet browser are you trying to open?
What if any changes were recently made?
have you tried system restore?
Jan 07, 2013 | Computers & Internet
CANT GET INTO ACCOUT password wont work
Resetting password & user name on Windows:b>*Start your computer
*Keep pressing "F8" as the computer starts.
*This will enter the computer in Safe Mode.
*(When the window "Advanced Boot Options" opens, choose "SafeMode" with arrow key and confirmby pressing the Enter key, then computer enters Safe Mode.
*Once you are in the Safe mode Click "Administrator" on the Windowslogin screen.
*Take note that you have set the Administrator password before, you need toinput the changed password instead of leaving "Password" field blank.
*Then click Start > Control Panel > User Accounts > Select the accountthat is locked and change the password.
**Restart computer and login into the account you just created using your newpassword.
Nov 07, 2011 | eMachines eM250-1915 Netbook
Cant activate wiindows, cant get start menu to open t
Dear User,
If you have not activated the windows in the provided days time then you have to start the system in safe mode (to enter into safe mode you should press F8 key while starting of the system) then call to Microsoft to get the registration code.
Regards,
Tech_Comp
Feb 22, 2011 | E-Machines T2682 (000002965) PC Desktop
Starts up then goes to safe mode screen cant get
Sounds like an infection. Your best bet is to start it and keep pressing F8 for safe mode. Once in there do a restore point. If that fails im sorry to say it may be a complete reinstall with a disk...Hope this helps....
Nov 17, 2009 | HP 510 Notebook
Cant acess safe mode in windows xp, just cycles startup screens
Here are some steps to use MSCONFIG to force your computer into SAFE MODE
  1. Click on Start and then Run.
  2. In the text box in the Run window, type msconfig and click OK. This will open the System Configuration Utility program.
    Note: Do not make changes in the System Configuration Utility other than those outlined here to avoid causing serious system issues. This utility controls a number of startup activities other than those involved with Safe Mode.
  3. Click on the BOOT.INI tab located at the top of the System Configuration Utility window.
  4. Check the checkbox next to /SAFEBOOT and click OK.
  5. You will then be prompted to either Restart, which will restart the PC immediately, or Exit Without Restart, which will close the window and allow you to restart the PC manually.
  6. After the restart, the PC will automatically boot into Windows XP Safe Mode.
    Note: Windows XP will continue to boot into Safe Mode until the System Configuration Utility is configured to again boot normally.
  7. When your work in Safe Mode is complete, click on Start and then Run. Type msconfig in the text box and click OK.
    This will again open the System Configuration Utility program.
  8. Choose the Normal Startup radio button and click OK.
  9. You will then be prompted to either Restart, which will restart the PC immediately, or Exit Without Restart, which will close the window and allow you to restart the PC manually.
  10. After the restart, the PC will boot into Windows XP normally and will continue to do so.
    These instructions were written by About.com
    http://pcsupport.about.com/od/tipstricks/ht/smsysconfig.htm
May 24, 2009 | Microsoft Windows XP Media Center Edition...
Want to Do a Restore
Try starting your computer in safe mode and do a virus scan once in safe mode. While in safe mode Windows only loads the basic devices to run your computer and usually viruses are not loaded untill windows starts in regular mode. Don't panic once you are in safe mode and your screen looks all grainy, this is normal.
  1. Restart your computer and press F8 as soon as you turn it on.
  2. Click the "safe mode with networking" option
  3. Update your antivirus
  4. Do a full system scan
  5. Restart your computer and hope for the best.
If that doesn't work, than reinstall windows.
If you need further assistance, let me know.
Jan 05, 2009 | Acer Aspire 3680 Laptop
Windows will not open up
try to get into safe mode (press the f8 key at the bios screen, before it starts to enter windows) inside safe mode, go to control panel/system/device manager, and look for and repair any hardware defices denoted with an exclimation point ,caution sign or red x.
Dec 29, 2008 | eMachines T5274 Desktop PC
I forgot my administrator password
safe mode will open windows with minimal amount of drivers, but will still require a password. Safe mode with command prompt will open in a simulated dos mode, and you can type "explorer" at the command prompt to open the gui and get to the start menu. buty this may not help.
i have sucessfully removed administrator password from windows by taking the hard drive out and installing it in another system as a secondary hard drive. i then manually deleted the "sam" file from windows/system32.
you can also reset the password by reinstalling windows or performing a second, parallel, installaation of windows (identical OS) on the same drive, and then deleting the second installation.
May 17, 2008 | Dell Dimension 2400 PC Desktop
Open Questions:
1855:536:5666+TWC Roadrunner Mail contact NumberTWC Roadrunner Mail Customer Service Phone NumberTWC Roadrunner Mail Customer Service Phone NumberGPSQTOA SOLVE1855:536:5666+TWC Roadrunner Mail Number SOLVE1855:536:5666+TWC Roadrunner Mail Number SOLVE1855:536:5666+TWC Roadrunner Mail Number SOLVE1855:536:5666+TWC Roadrunner Mail Number SOLVE1855:536:5666+TWC Roadrunner Mail Number SOLVE1855:536:5666+TWC Roadrunner Mail Number SOLVE1855:536:5666+TWC Roadrunner Mail Number SOLVE1855:536:5666+TWC Roadrunner Mail Number SOLVE1855:536:5666+TWC Roadrunner Mail Number SOLVE1855:536:5666+TWC Roadrunner Mail Number SOLVE1855:536:5666+TWC Roadrunner Mail Number SOLVE1855:536:5666+TWC Roadrunner Mail Number SOLVE1855:536:5666+TWC Roadrunner Mail NumberTWC Roadrunner Mail TWC Roadrunner Mail Phone NumberTWC Roadrunner Mail TWC Roadrunner Mail Contact NumberTWC Roadrunner Mail TWC Roadrunner Mail Support NumberTWC Roadrunner Mail TWC Roadrunner Mail HelplineTWC Roadrunner Mail TWC Roadrunner Mail Tech SupportTWC Roadrunner Mail TWC Roadrunner Mail Customer SupportTWC Roadrunner Mail TWC Roadrunner Mail Customer SupportTWC Roadrunner Mail TWC Roadrunner Mail Toll Free NumberTWC Roadrunner Mail TWC Roadrunner Mail Technical Support NumberTWC Roadrunner Mail TWC Roadrunner Mail Service Phone NumberTWC Roadrunner Mail TWC Roadrunner Mail Phone NumberTWC Roadrunner Mail TWC Roadrunner Mail supportTWC Roadrunner Mail TWC Roadrunner Mail customer serviceTWC Roadrunner Mail TWC Roadrunner Mail Support NumberTWC Roadrunner Mail TWC Roadrunner Mail Customer Service Number contact Microsoft TWC Roadrunner Mail supportTWC Roadrunner Mail TWC Roadrunner Mail Tech Support Phone.
Aug 19, 2019 | Microsoft Computers & Internet
#@ {1855*536*5666} USA+TWC Roadrunner Customer SupportTWC Roadrunner Mail Phone NumberTWC Roadrunner Mail Phone NumberTXJUPPP SOLVE1855:536:5666+TWC Roadrunner Mail Number SOLVE1855:536:5666+TWC Roadrunner Mail Number SOLVE1855:536:5666+TWC Roadrunner Mail Number SOLVE1855:536:5666+TWC Roadrunner Mail Number SOLVE1855:536:5666+TWC Roadrunner Mail Number SOLVE1855:536:5666+TWC Roadrunner Mail Number SOLVE1855:536:5666+TWC Roadrunner Mail Number SOLVE1855:536:5666+TWC Roadrunner Mail Number SOLVE1855:536:5666+TWC Roadrunner Mail Number SOLVE1855:536:5666+TWC Roadrunner Mail Number SOLVE1855:536:5666+TWC Roadrunner Mail Number SOLVE1855:536:5666+TWC Roadrunner Mail Number SOLVE1855:536:5666+TWC Roadrunner Mail NumberTWC Roadrunner Mail TWC Roadrunner Mail Phone NumberTWC Roadrunner Mail TWC Roadrunner Mail Contact NumberTWC Roadrunner Mail TWC Roadrunner Mail Support NumberTWC Roadrunner Mail TWC Roadrunner Mail HelplineTWC Roadrunner Mail TWC Roadrunner Mail Tech SupportTWC Roadrunner Mail TWC Roadrunner Mail Customer SupportTWC Roadrunner Mail TWC Roadrunner Mail Customer SupportTWC Roadrunner Mail TWC Roadrunner Mail Toll Free NumberTWC Roadrunner Mail TWC Roadrunner Mail Technical Support NumberTWC Roadrunner Mail TWC Roadrunner Mail Service Phone NumberTWC Roadrunner Mail TWC Roadrunner Mail Phone NumberTWC Roadrunner Mail TWC Roadrunner Mail supportTWC Roadrunner Mail TWC Roadrunner Mail customer serviceTWC Roadrunner Mail TWC Roadrunner Mail Support NumberTWC Roadrunner Mail TWC Roadrunner Mail Customer Service Number contact Microsoft TWC Roadrunner Mail supportTWC Roadrunner Mail TWC Roadrunner Mail Tech Support Phone.
Computers & Internet Logo
29 people viewed this question
Ekse
Alun Cox
