Question about Manfrotto 681 Monopod
Manfrotto 681 problem
Hiya,
The head of the monopod has two mounting screws. The first, outer one, moves down to expose the smaller inner mounting screw (which fits my D70s).
Problem is that the outer mounting screw is jammed down into the frame of the pod. When I unscrewed the camara from the pod, the outer screw did not jump out again. Now its stuck and i'm afraid to use brute force and ignorance to force it out, fearing that i'll damage the threading.
What to do?
    Sergeant:
    Champion:
  • 310 Answers
Can youy turn it up side down and use gravity to you advanage?r
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Posted on Jan 01, 2008
How adjust the vertical viewing
are you just mounting a camera to the tripod itself? - you need to purchase a head as well - the head screws onto the top of the tripod, and then the camera fixes to the head, usually with a qr plate.
May 05, 2014 | Manfrotto Photography
Where do I find a Private Label Manufacturer for photography equipment and supplies?
Most of those type parts are made in China. I would look at the trade orginazations in Hong Kong to start.
Apr 30, 2014 | Manfrotto 681 Monopod
Bottom tube moves when tighten
It sounds like the tubes may be dented or bent. It won't take much of a bend to make it hard to work. Send it to: http://www.manfrottotripodparts.com/repairs.html
they can repair it for you.
Nov 29, 2013 | Manfrotto 681 Monopod
Will manfrotto tripod mvt502am fit in my MBAG80
It should..., the bag is 80cm long..., the tripod is 61cm when folded & the head is approx. 10cm tall!!!
Math says yes!!!
Jun 21, 2013 | Manfrotto Photography
Monopod is slipping
If the monopod is slipping and getting shorter as you use it, then find the clamp that is not secure. flip open the clamp lever and using a small socket wrench, turn that nut about 1/8 of a turn. Test the slippage. if is still slips give it another 1/8 turn. Do this until is is not slipping. Do not over tighten the nut or you may damage the clamp or leg tube.
If it is the head, I will need more info as to which head you have on that monopod.
Nov 03, 2012 | Manfrotto 681 Monopod
How do I release a Manfrotto 501HDV head from a tripod
Tip the tripod upside down, on the bottom plate where the head attaches there are 3 screws... they need to be loosened, and then the head will spin off.
Oct 27, 2012 | Manfrotto 503HDV Head and 351MVB2 Tripod...
Reassembling telescopic sections for a 676B monopod
Each leg lock has a leg locking lever and a screw that hold the clamp assembly tight to the leg. Unlock the leg lock lever, loosen the screw above it that holds the clamp tight to the leg. The legs should fit into each other sice each leg is slightly larger or smaller then then next one. Slide the clamps in the approprite places and tighten the screw enough to hold the clamp assembly tight, but do not over tighten it. Over tightening will damage the 679 tubes.
Dec 25, 2009 | Manfrotto 679B Monopod
Broken lower clamp
You can order parts from Manfrotto by entering 681 as the product code on this page to determine the part number. Then use their Contact Us page to tell them you want to order the part.
Dec 27, 2008 | Manfrotto 681 Monopod
I need to replace the bottom tube on my Manfrotto 681B monopod.
I have no affiliation, nor have I used them but you might try.
Spartan Photo Center, Inc.
PO Box 160642
Spartanburg, SC 29316
864-583-6835
E-mail: email@SpartanPhotoCenter.com
I assume you have contacted Bogen/Manfrotto directly. Most manufacturers will tell you where you may purchase parts.
Nov 14, 2008 | Manfrotto 681 Monopod
701RC2 going on 745B sticks
Hey SkipHall,
As in most Manfrotto tripods this tripod should have 3 set screws underneath the head mounting surface. Unscrew these set screws and you should be able to unscrew the current head off the tripod by holding the center column and turning the head counter clockwise. Installation of the new head should be the reverse. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 16, 2008 | Manfrotto 745MF3 Tripod
Manfrotto 681 Monopod Logo
267 people viewed this question
Top Manfrotto Photography Experts
Tony Parsons
Tony Parsons
Harrie
Are you a Manfrotto Photography Expert? Answer questions, earn points and help others
