Question about Dell E193FP 19" Flat Panel LCD Monitor
Remove stand Please advise how to remove entire stand. I have unscrewed the legs, but there remains a piece connected to the monitor that hangs down about 2 or 3 inches.
  • Anonymous Dec 20, 2007
    I also have the same problem. I need to re-pack my screen as I am moving and although I managed to remove the round base I cannot manage to remove the stand. With this on it won't fit in its original box.
    Please help!
  • 46 Answers
There should be 4 screws on the back. Take these screws out and the base will tilt up and come off. Watch this video and it will show you. http://www.lcdrepair.us/Installation.html The E172fpb video
Posted on Jun 21, 2008
  • 749 Answers
We need picture of it, if your not talking about the swivel base.
Posted on Dec 05, 2007
How to attach kick stand spring on 2006 street glide
With the full weight of the motorcycle resting on the jiffy or side stand when it is placed in the full forward and down position it will lock into this position when the bike is leaned over the left side. If it is not in the fully down and forward position and on a flat/level and firm/solid surface when it is leaned over to the left side the bike may fall down.
To Remove the Jiffy Stand
WWAARRNNININGG
Block and support the motorcycle under frame to be sure that it is securely upright and level and so that the jiffy stand can be moved throughout its full range of travel and so that it will not fall down or onto the repair person when the jiffy stand is removed.
Then move the jiffy stand to the retracted i.e. up position and remove the ****** nut and leg stop from the threaded end of the jiffy stand leg and then move the jiffy stand leg to the full forward position which is the full down position and grasp the end of the jiffy stand spring as close to the frame tube as possible, and then twist and turn the end with needle nose pliers to unhook it from the frame hole. THEN remove the jiffy stand leg from its bracket, inspect the entire jiffy stand assembly for worn or damaged parts and replace them as found necessary.
To Install the Jiffy Stand
First lubricate the jiffy stand leg with an Aerosol Anti-Seize Lubricant but only in the area of the jiffy stand leg part that rotates within the bracket. THEN insert the threaded end of the jiffy stand up through the bottom of the bracket and with the jiffy stand in the full forward position, partially install the spring end into the frame hole and with a rap to the spring with a rubber mallet fully seat it in its hole. Be careful to insert the end of the spring into the hole at the front of the jiffy stand leg piece in front of the jiffy stand leg piece weldment because if it is inserted from the rear of the hole in the leg piece the coil of the spring will interfere with and rub on the leg piece when the jiffy stand is used and if it is installed incorrectly over time it will wear and the motorcycle could fall over due to this wear. THEN while holding the jiffy stand leg at the full forward position, install the leg stop over the threaded end with the stamped side down, install the ****** nut and tighten it to 43-53 ft-lbs which is 58-72 Nm. NOW verify that the longer side of the leg stop faces towards the rear of the motorcycle, extend and retract the jiffy stand leg several times to verify that it operates properly, freely moving to both the full up and the full down positions with no spring or other interference or contact and verify that the rubber stop is correctly in place on the jiffy stand prong because without the rubber stop correctly in place the stand will make improper contact with the lower frame tube when the jiffy stand is retracted and will then likely chip and/or nick the powder coat. AND, of course if the rubber stop is deteriorated or missing. Replace it with a new one. FINALLY carefully remove the support blocking from beneath the motorcycle frame and let the motorcycle rest on the fully extended jiffy stand leg.
Sep 15, 2014 | Motorcycles
How to remove the monitor stand on acer s242hl?
For the S242HL
1. Unscrew the screws from the plastic base and remove this. You are now seeing the metal part of the base.
2. Lay the screen glass down, on a flat surface. If you crouch down and look into the area the metal piece is inserted, you will see a plastic 'tab' that is locking the metal piece in place. Wedge something to lift the plastic tab, so that you can pull the metal piece out. You can use quite some force to lift the plastic and then the metal bit just slides out.
I've just done this so I know it works.
Apr 28, 2014 | Acer Computers & Internet
How do you replace a Harley Road King kickstand spring
WWAARRNNININGG
Then move the jiffy stand to the retracted i.e. up position and remove the flange nut and leg stop from the threaded end of the jiffy stand leg and then move the jiffy stand leg to the full forward position which is the full down position and grasp the end of the jiffy stand spring as close to the frame tube as possible, and then twist and turn the end with needle nose pliers to unhook it from the frame hole. THEN remove the jiffy stand leg from its bracket, inspect the entire jiffy stand assembly for worn or damaged parts and replace them as found necessary.
First lubricate the jiffy stand leg with an Aerosol Anti-Seize Lubricant but only in the area of the jiffy stand leg part that rotates within the bracket. THEN insert the threaded end of the jiffy stand up through the bottom of the bracket and with the jiffy stand in the full forward position, partially install the spring end into the frame hole and with a rap to the spring with a rubber mallet fully seat it in its hole. Be careful to insert the end of the spring into the hole at the front of the jiffy stand leg piece in front of the jiffy stand leg piece weldment because if it is inserted from the rear of the hole in the leg piece the coil of the spring will interfere with and rub on the leg piece when the jiffy stand is used and if it is installed incorrectly over time it will wear and the motorcycle could fall over due to this wear. THEN while holding the jiffy stand leg at the full forward position, install the leg stop over the threaded end with the stamped side down, install the flange nut and tighten it to 43-53 ft-lbs which is 58-72 Nm. NOW verify that the longer side of the leg stop faces towards the rear of the motorcycle, extend and retract the jiffy stand leg several times to verify that it operates properly, freely moving to both the full up and the full down positions with no spring or other interference or contact and verify that the rubber stop is correctly in place on the jiffy stand prong because without the rubber stop correctly in place the stand will make improper contact with the lower frame tube when the jiffy stand is retracted and will then likely chip and/or nick the powder coat. AND, of course if the rubber stop is deteriorated or missing. Replace it with a new one. FINALLY carefully remove the support blocking from beneath the motorcycle frame and let the motorcycle rest on the fully extended jiffy stand leg.
CAUTION
Jun 03, 2011 | 2006 Harley Davidson FLHRCI Road King...
I have a 42 in. Vizio Galleria and need to remove table top stand so I can wall mount. How do I remove base stand?
1. Unplug all of the cables and cords from your GV42L FHDTV10A.
2. Place the GV42L FHDTV10A face down on a soft and flat surface (blanket, foam, cloth, etc) to prevent any damage to the TV.
3. Pull the stand cover off by squeezing the sides to release the retaining plastic tabs.
(This is probably the trickiest part to find this, just feel around and don't be too rough with the plastic)
4. Remove the four (4) screws (screw's specs: M4, 0.7 Pitch, 15mm long) so that the stand base can be removed.
5. Gently remove the stand base
6. Now, the GV42L FHDTV10A can fit securely to a mount (sold separately) by utilizing the mounting holes in the center of the back panel of the TV. Please make sure to read the instructions of your specific mount to properly hang the GV42L FHDTV10A
Mar 13, 2011 | Vizio Gallevia GV42LF 42 in. LCD...
Need to remove the bottom attached to tv to mount tv to wall
Firstly, before you unscrew anything, lay the screen face down on a mat on a table/desk with the stand hanging off the edge of the table. This will ensure nothing moves without you wanting it to.
There's four screws to remove, two from each leg. Two of them are above where the mains plug goes in, and two above the computer display input socket. Stand should slide out once these have been removed.
Jan 05, 2011 | LG 42LC2D 42 in. LCD HDTV
The monitor comes on to desktop then goes blank, and flashes, if I tap or tilt the monitor it will come back , but then go blank again
You have a bad connection on the signal input to the screen.
This is probably the input socket on the monitor, but try a different cable first. If that does not help then it is the socket on the monitor.
You will need to disassemble the monitor to check solder joints on the video in socket.
If you are not comfortable with that process then it has to be a repair centre.
I may be able to offer further advice if you want to tackle it youself.
Mar 06, 2010 | Dell E151FP 15" Flat Panel LCD Monitor
How do you remove base from tv
if its like my p50dhm just remove 6-8(each leg) screws on back located at legs of stand pretty obvious....stand will try to hang-up plus must come off equal on each side or will bind
Feb 07, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
Acer monitor AL1916W question
Stand on your head ??? put the stand on the other end ??
Jus kidding ? Is it a monitor that offers a rotate screen feature ??
Did you buy it used ? almost sounds like the screen is in upside down which is possible but a bit tricky to do.
Sep 25, 2008 | Acer AL1916W 19" LCD Monitor
AOC lm929 monitor
AOC LM929 or Envision EN-7100 removal instructions:
DANGER!!! UNPLUG and allow the monitor to discharge before servicing.
with a small flat head screwdriver, insert into the edge and pop open the small plastic
pieces that surround where the stand connects to the monitor. put plastic pieces aside.
lay monitor on soft flat surface front side DOWN. with a phillips head screwdriver,
remove 4 screws in the center that hold on the stand. put stand and screws aside.
lay monitor on soft flat surface front side UP. insert flat head screwdriver into the
side edge of the grey plastic and turn screw driver so the plastic surrounding the
screen edge pops up exposing an area surrounding the screen. put plastic rectangle
piece aside.
slide out plastic buttons piece from the side and put aside.
with a phillips head screwdriver, remove 8 screws (4 on top and 4 on bottom) that hold
the screen assembly to the back housing. now lift screen assembly out of the plastic
housing. put back plastic housing and screws aside AND lay the monitor screen with the
FRONT side down on a flat soft surface.
with a phillips head screwdriver, remove 2 screws that hold on the metal electronics
cover. slide the cover down and remove. put the cover and screws aside.
USE CAUTION!!! Some components may still contain a charge.
check fuse... whatever...
Aug 29, 2008 | Computers & Internet
No display
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Cause of power going off: There is a bad 1000uF, 16V cap on the power supply board.
Solution: Replace cap. Radio Shack sells a 1000uF, 35V cap for $2. This will work.
Why did the cap go bad? The cap is too close to a heat sink and over heated.
What does this cap do? This cap sends a signal to an IC which keeps the monitor 'on' after the power switch is pushed. When the cap is weak, AC ripple voltage is applied to the IC and it sends a signal to shut the monitor off.
Opening the Monitor: These monitors are difficult to open.
The two plastic pieces snap together and must be pried apart with a flat screw driver.
After removing the stand, you need to insert a flat screw driver at the bottom of the screen where two slots are located. Then work the screw driver around until the two plastic pieces are separated.
Remove the cover plate and unscrew the push button circuit board.
Unplug the monitor cords from the driver board and remove the screen.
Unscrew the mounting screws from the power supply board and remove.
You will need to pinch the plastic support in the middle of the board to remove.
Cap Replacement:
Cap is located near a copper heat sink and the value will be on the side of the cap. It will be bulged up on the top. You will see burn marks on the board surrounding the cap. Unsolder the cap.
Install the new cap and solder. Make sure you connect + of the cap to + marked on the board.
Be careful not to solder across joints.
Keep leads long so you can bend the cap as far away from the heat sink as possible.
Reassemble monitor and turn on.
This should solve the problem.
Mar 18, 2006 | Neovo E-19A 19" LCD Monitor
Dell E193FP 19" Flat Panel LCD Monitor Logo
133 people viewed this question
Alun Cox
