Question about Sony Cyber-Shot DSC-H1 Digital Camera
Please help with Sony DSC-H1 problem
I have been unable to get Power indicator light & LCD screen will not come on. I have fully charged batteries in the camera & the red light at the back right hand side of the screen stays on only brief seconds. I am desperate. Please tell me what the problem is or what steps I should take.
Regards,
Dee Kincke
[email protected]
  • Gulls Apr 09, 2008
    When I close the battery cover the little red light in the bottom right hand corner flashes briefly but the camera wont turn on. I tried new batteries, fresh batteries & I tried holding the power button for 30 seconds. Please help I love my camera.
  • Anonymous Jun 22, 2008
    I also have trouble turning on my camera with new battery or just charged ones. The power light by the battery compartment blinks for a sec then off and it just wont turn on. I haven't dropped it or anything, I have taken great care of my camera. please help
It is the main power supply. It was going to cost us $400.00 to fix. Really sucks the camera ROCKS.
Posted on May 01, 2008
Someone told me to try this:
take the batteries out, press and hold the power button for about 30 seconds, let the camera sit for a few minutes without batteries, then place new "good" batteries in it.Good luck
Posted on Dec 17, 2007
SOURCE:
Sony cybershot DSC H1 LCD blank screen constantly
It is most likely the same issue, complain and ask them to fix it, as you will not have the hardware or programs to fix it yourself.
Jan 03, 2012 | Sony Cyber-Shot DSC-H1 Digital Camera
The batteries in my DSC H1 camera only last about 10 % as long as they used to. New batteries don't solve the problem. Can the camera be fixed? Larry
I would suggest trying a different type of battery. If you're using AA batteries, often alkaline ones don't work. Try lithium or even rechargable AAs. If it's a rechargable lithium type (a square battery) try charging the battery fully and then using it completely to refresh the lithium cells. Try cleaning the contacts (silver pieces where the battery touches the camera) with a soft cloth as they can easily get corroded. Generally battery failure is not to do with the camera itself.
Jul 24, 2010 | Sony Cyber-Shot DSC-H1 Digital Camera
My screen is broken on my Sony DSC - H1. Can it be repaired and is it worth repairing to replacing
Required LCD for DS-H1 is available in Part Store for $85 under following part number..
875322936... ACX336AK-3
Click Part Store for price details and lcd image.
Thanks.
Jan 13, 2010 | Sony Cyber-Shot DSC-H1 Digital Camera
Sony DSC-W5 camera and the LCD screen is blank (white)
Remove the Battery pack from the Camera then press and hold the power button for 30 seconds.
Next, reinsert the Battery pack in the Camera and try to turn it ON. Make sure that the Battery pack is fully charged. If the LCD remains white then the LCD screen needs to be serviced or replaced.
Nov 25, 2009 | Sony Cyber-Shot DSC-W5 Digital Camera
What's wrong with my sony cyber-shot DSC-T70 because i haven't done anything yet the screen is totally black, but still it functions, I really can't see any figure on the screen. Please advice... rj
Please make sure that the battery is fully charged and try to increase the LCD brightness by touching the DISP button on the screen. Check if you are able to access the Menu. If yes, then, please Initialize the camera under Main settings 1 Menu. If you are not able to access the menu, you may have to power reset the camera by removing the battery and press n hold the power button for 1 minute continuously. After that leave the button and insert the battery and check if it helps. If the issue still persists, your camera will require service.
Sep 27, 2009 | Sony Cyber-shot DSC-T70 Digital Camera
Loosing power randomly
how old are the batteries and how many times they were charged without being fully drained can cause a short life for the battery. Try a new battery-fully charging it properly, but dont charge it again till it goes off by itself completely. If you have a wall charger, plug your phone in. If it stays on that way, check your 'power save' settings. That can also make your camera shut off. Try these steps first and see if it changes the 'battery' from being empty to full and stays on. hope this helps
Aug 24, 2009 | Sony Cyber-shot DSC-W170 Digital Camera
Sony Cyber-Shot DSC-H1 Digital camera that will not hold a battery charge
All rechargeable batteries got exhausted after 100s of charges or after a certain period. It need replacement. if my suggestion proves useful please rate my solution.
Mar 26, 2008 | Sony Cyber-Shot DSC-H1 Digital Camera
Recharge of flash
Sony H1 camera has a delay to recharge the flash and I hope that you know that as you are using it for the last three years. If the time delay is a new issue check the MAH of the battery to ensure that it will be above 2200 at least. If the MAH is below 2200 it is natural that the time delay will be more to recharge the flash. If my solution proves good please rate it. Regards.
Mar 06, 2008 | Sony Cyber-Shot DSC-H1 Digital Camera
Power inicator on DSC-H1
sound like a electronic problem, i would suggest to take in for service.
Dec 02, 2007 | Sony Cyber-Shot DSC-H1 Digital Camera
Sony Cyber-shot DSC-U10 low battery indication.
possible short circuit that is draining battery at a speed. get your camera tested at some good repair shop,
Jul 02, 2006 | Sony Cyber-Shot DSC-U10 Digital Camera
Sony Cyber-Shot DSC-H1 Digital Camera Logo
147 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
