2004 Honda Valkyrie Rune Logo
Posted on Aug 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tips on servicing 2004 rune ,oil change ect - 2004 Honda Valkyrie Rune
Anonymous
Level 3:
President:
  • Master 1,167 Answers
  • Posted on Aug 20, 2009
Anonymous
Master
Level 3:
President:
Answers
1167
Questions
Helped
474521
Points
3522
Hi mate there arent any tips for servicing except buying descent oil like silkolene race oil 4 t descent stuff the oil filter just unwindes and then you just wind the new one on and the air filter you just unscrew the bolts or screws holding it in place and take it out and replace with new filter thats about it good luck
Oil runing from right side on exhaust. new seal ?
please be more specific ? make model ect
tip
Resetting the change oil,low tire,low oil ect. on 2004 impala
With the radio off. turn the key to the on position. press and hold the chanel knob in tell the info comes on in the station window. press the #1 to find the one you are looking for. press the station knob again( you will here a beep). Press #1 again and find exit and press the chanel knob again and it is reset.
on Mar 14, 2009 • 2004 Chevrolet Impala
What is the oil capacity on a honda Valkyrie Rune 2005 bike?
I have a 2004 Rune, I changed oil last year with Mobile 1 Synthetic 5-30W. The bike is running great. Added 4 quarts.
2helpful
What service is reccommended for 2004 jetta with 28,000 miles. synthetic oil changed at 25,400. miles
Nothing. Assuming you are doing a 5000 mi interval for oil changes, drive happy until 30,000. At that point do the oil, drain water seperator (diesel only) ck washer fluid, ck brakes (mine lasted until 140, 000 mi), depending on your schedule- rotate and balance tires, and check battery. VW also suggests to pop off the timing belt cover and ck for cracks, fluid leaks ect.
Your big service comes at 40,000 mi. Oh, and if you want to take it to a professional shop, save the money and aggravation and go to a local v-dub, or foreign car specialist. Avoid the STEALership at all costs.... this is from a former dealer tech...
What is the oil capacity for a 2005 honda rune?
3/4 of a 5 lb bag of brown rice should do it. Run better on Uncle Ben Instant
2004 Pontiac Grand Prix all warnings when starting the car
check all fuses and wires make sure everything tight.
14helpful
4answers
How much tranny oil do you put in 2005 CRF250R after oil change?
You'lll need to put .7 liters of oil on your bike. When you changed the filter, you'll need to add .8 liters of oil.
Hope this helps! i'd appreciate a rating!
-levibit-
1helpful
2answers
Timing belt
Timing belts are suppose to be changed every 60,000 miles.
Top Honda Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
Mike Cairns
Mike Cairns
Are you a Honda Expert? Answer questions, earn points and help others
