Question about Health & Beauty
Andis master clippers
My leveler on the side of the machine is lose. How do I tighten it up so it doesn't move while I am cutting hair.
  • datricanmach Apr 27, 2009
    bro i have the same problem canu plz tellme wat u did to fix it ? if u found a solutioon mi email is datricanmacho @aim.if u or ne one kow just put subject to andis master problem! thx in advance
Yeah bro.....just take off the top blade off the slider. Then you will see four screws on the slider, just tighten up each screw. The tighter you want the leveler, the harder you screw, be careful because they are easy to strip....that it, good as new....
Posted on Jul 11, 2009
Andis master clippers lose power
Oil the blades and then adjust them. You will need to add oil while grooming from time to time and then clean & oil them again when finished.
Sep 23, 2012 | Andis Improved Master Clipper/Trimmer...
My adjuster on my clippers wont stay still, everytime i cut on the clipper the adjuster on the side wiggles and moves to the do i fix this
Take the upper blade off of the clipper, there will be four (4) screws which secure the adjustable part of the lever to the clipper. You can tighten these screws and that will control how much resistance you get when adjusting the lever.
Feb 21, 2011 | Andis 01690 Hair Trimmer
I need to take apart my andis master clipper to see what part i need to order i need the manual take apart the clipper
Stop, Their no manual on how to take your Andis Master apart. The Andis Master has small parts that you can lose. The adjustment on this clipper are not easy to do. I
Feb 11, 2011 | Andis Master 01557 Hair Trimmer
When i cut hair my andis master clipper seems to get stuck while cutting hair causing me to take longer with the fade how do i go about fixing it to where it doesnt get stuck in hair & by the way im...
mcdevito75 here, Sounds like the blades need to be sharpened, refer to the shavers brand name plus .com for blade replacement or replace the shaver.
Jun 19, 2010 | Andis 01690 Hair Trimmer
My level adjuster is loose. When I go to cut it moves. How do I fix it?
Remove the stationary blade from the clipper by removing the two Phillips screws. When you lift it away you will see the plate that slides when you move the lever. Beside it are 4 smaller Phillips screws, two on either side. Tighten these very, very slightly. Repeat, very slightly until you achieve a stiffer lever action taht is comfortable to you. Replace the stationary blade with a drop of oil and properly align it. You're ready to go.
Apr 09, 2010 | Andis Master 01557 Hair Trimmer
Misses hair when cutting
You probably need a new blade drive, which is easily replaced yourself, if you are so inclined.
Apr 20, 2009 | Andis 01690 Hair Trimmer
My GTO model Andis clippers blade is not properly do I adjust it?
The problem with Andis clippers is that you are not told how to get the most effective job out of you're clippers,i can attest to that because i've repaired and adjusted hundreds of them,every user wants a crisp cut,nothing less, you want find the answer to that in the instructions,so you're encouraged to send the clipper back to Andis company,i did that once just to see if they really understand their own tool,the clipper cut no better upon it's return,it was then that i discoverer the ultimate solution,blades has to be precise,only then will you get a crisp cut,for any type of hair ,so before you get rid of blades,remember 85% of the time the problem is with the adjustment of the blade.
Dec 17, 2008 | Andis 01690 Hair Trimmer
Turn the clipper on and with a screwdriver turn the screw on the side all the way clockwise. Next slowly turn the screw back the opposite direction until the clippers are running at a normal sound level. If this does not work you will need to send the unit in for an internal adjustment. Please call the Andis customer service department at 1-800-558-9441 for further instruction.
Thank you for choosing Andis.
Sep 13, 2008 | Andis 01690 Hair Trimmer
Health & Beauty Logo
909 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
Are you a Health and Beauty Expert? Answer questions, earn points and help others
