Question about Brother MFC-210C All-In-One Printer
Printer connection can not find the port yp connect the printer
  • 832 Answers
You have to open the scanner as you would do to change the ink carts. the usb connector is opposite to the ink cartridges INSIDE the printer. The cable has to be let thru the channel which can be quite well be good seen.
Posted on Dec 02, 2007
SOURCE:
My samsung YP-U4 mp3 player worked fine on friday, i plugged it onto the usb port and it charged. The next day, i plugged it onto the usb port and it doesn't charges, and the player doesn't recognize the...
Download the latest driver software from the Samsung website with the link below and install it on your PC. Click on downloads > Software.
If that doesn't fix the problem, try connecting it to other USB ports as the one you tried could be faulty or some USB ports do not provide enough power for the device to get connected.
http://www.samsung.com/my/support/detail/supportPrdDetail.do?menu=SP00&prd_ia_cd=&prd_mdl_cd=YP-U4AB/XME&prd_mdl_name=YP-U4AB&srchword=YP-U4
Mar 04, 2011 | Audio Players & Recorders
Yp-k3 where can i buy a usb port
Do you mean the cable to connect to your computer's USB port? You can purchase a wall charger that has a USB port. You can also purchase a cigarette lighter plug with USB port to operate/charge your player in your car.
Mar 20, 2010 | Samsung YP-K3 MP3 Player
How do I charge Samsung MP3 player Yp-U3 Samsung YP-U3 MP3 USB port not connected to the computer
The player needs to be charged via the USB connnection on your PC. If it doesnt fit, try the USB ports on the back. If its not working/not charging, please test the MP3 player on another PC.
Jan 21, 2009 | Samsung YP-U3 MP3 Player
My yp-u3 wont connect
no reconoce el dispositivo
Nov 06, 2008 | Samsung YP-U3 MP3 Player
MP3 can't work normally
With the YP-u3 connected to the USB port and internet connected, start Samsung Media Studio software, you should get notification of a firmware update to download which fixed the recognition problem for me
Sep 13, 2008 | Samsung YP-U3 MP3 Player
USB connection problem
my YP-U3 player will not connect via my USB port. When plugged in to a port that connects my digital camera normally it first says on screen "USB Connecting" then changes after 2 to 3 seconds to "disconnected - Charging". it has fully charged and no change. I have checked the hold switch is disengaged. the media studio software is installed ok and the portable devices functions are greyed out. I cannot find the device on my pc. I am running Windows XP SP2. I will be returning it to the store where it was purchased very soon if i cannot find a solution. I notice there are a lot of people who have posted similar problems that have not recieved solutions.ya i have th same problem im using window xp 2
Aug 30, 2008 | Samsung YP-U3 MP3 Player
Samsung YP-K5JAB
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware.
Wizard
Jun 10, 2008 | Samsung YP-K5JAB MP3 Player
YP-U2J - Need download - Didn't come with CD
In case you have a problem to connect your Samsung YP-U2J Mp3 player, you should update Firmware to get it working. The new Firmware may be downloaded from Samsung.com.
CLICK Here to Download : Firmware Update
In case u have WMP 11 and player not working, this error is common after installing Windows Media Player 11
Here is the instruction:
  1. Download the YP-U2J Updater
  2. Remove Mp3 player if you already connected to the USB port
  3. Run the program (You should see something like: Please connect the device)
  4. Hold down the Play button and connect the Mp3 Player to USB port (Hold down the play button while you connect the device, you should see a message (normally after 8 seconds) like: Initializing on YP-U2J Updater program screen)
  5. After you hear the Windows chime "new device found" or the message "Initializing" on YP-U2J Updater, you can now remove your hand from play button.
  6. Check the Format Data Area checkbox (By clicking the yes button, you will lose all of your data in your Mp3 player)
  7. Click the "yes" button
  8. Finally, click on the Start button (takes less than a minute). DO NOT REMOVE YOUR DEVICE
  9. IMPORTANT: After updating the firmware, you MUST disconnect the Mp3 player and turn it on. You will see a 20% message for about 50 seconds and it will be restarted automatically.
Update: Please keep in mind that if you sync your Mp3 player with a computer that has a Windows Media Player 9 or 10, you should do these steps again
Jan 27, 2008 | Samsung YP-U2X Digital Media Player
Connection to my computer
UMS mode allows the Z5 to interface to the computer as if it were a removable hard drive. You can then use Windows File Explorer to manage the files in the Z5.
To get into UMS mode, connect the Z5 to the USB port while simultaneously holding down the "return" button (the top of the square keypad) while connecting. This will put the player into UMS mode for that connection period only.
If you upgrade to the new firmware, you have the option of making it always connect in UMS mode.
The steps to install the latest firmware are:
(1) Download version 2.37 or newest of the Z5 firmware http://www.samsung.com.
(2) Unzip it to get the file named "Z5Update.dat".
(3) Disconnect the Z5 from the USB port.
(4) Reconnect the Z5 to the USB port while simultaneously holding down the "return" button (the top of the square keypad) while connecting. This will put the player into UMS mode for that connection period only.
(5) Open a File Explorer window, and find the YP-Z5 device.
(6) At this point, make sure the Z5 is fully charged and has at least 30MBytes of free space.
(7) Copy the file "Z5Update.dat" to the root directory of the YP-Z5 device.
(8) Now disconnect the Z5 from the USB port.
(9) The Z5 will display the option to upgrade to the new software, or to cancel.
(10) Select "Upgrade". This will power off the Z5.
(11) Connect the USB cable to the Z5. Now it will upgrade the firmware under USB power. DO NOT DISCONNECT THE USB UNTIL THE UPGRADE FINISHES. After finishing the upgrade, new firmware will be started automatically.
(12) Check the version information in the "Settings > System Info > Version" tab.
Now you can turn on the UMS only option.
Settings / System Info / UMS Only = On
Doodles1
Dec 31, 2007 | Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
Brother MFC-210C All-In-One Printer Logo
James Cagle
James Cagle
Jim Keysor
ctnozil
