Question about HP PSC 2175 All-In-One InkJet Printer
Page is dark
The page is darkened. Of course, each subsequnet printing will make the page darker.Can someone help?
Copy darker
go into the menu and look for copy/print settings. you should see an option to lighten or darken the copy. It should look like a ascending /descending slider. tap to the left for lighter or to the right for darker
Nov 27, 2013 | HP Officejet 5610 All-In-One InkJet...
Workcentre 275....customer supplied multi page pdf's all of which contain a signature. When printed from the 275 a lot of background noise appears in and around signature, prints fine to various other...
Hi Paul.
I don't have a Xerox, but my previous HP and Samsung and current Samsung have on-screen Windows-configurable settings for adjusting darkness etc.
Open Start>Control Panel>Printers and Devices
Right-click the XEROX icon and choose Settings.
Browse through the menu pages until you see a page with similar to the screenshot.
May be called Advanced.
Darkness should be normal, or if still showing, try light.
ECO mode should be On.
That fact that other printers are not printing the noise means that the current user-settings of your XEROX are too dark, thus reproducing the pixels of the signature graphic.
If you selected a pixel near the signature and analysed it in MS Paint, you'd probably find that the 24-bit RGB value is not pure white 255.255.255 but maybe a few steps darker, say 254,254,254.
To the human eye this would be hardly noticeable, but the printer may be darkening the pixels even more, causing the noise.
I wish you luck in your noiseless quest.
Clive.
Nov 18, 2017 | Xerox Office Equipment & Supplies
Even with new ink cartridge printer prints light
Double click Control Panel.
Double click Printers and Faxes.
Right click your printer and select properties. Now on General tab select "Printing Preferences".
Now select the basics tab and click "Advanced features" found on the right of the page.
Here you will be able to adjust the amount of ink that is used to print a page. Side the bar to the right to increase/darken the print.
Now click OK, followed by Apply.
Take care!
damnor01
Jun 07, 2012 | Office Equipment & Supplies
I have a Sharp AR M-165. If I try to do more than 20-30 continuous copies or prints I get a darkening of the top 40mm of the copied page which gets gradually darker and darker the more pages that are...
are u using a compatible toner or branded.this problem might be occurring due to toner .try to change the toner and developer .both at the same time because if u change the toner then the toner in developer module will get mixed with new one and u will have a problem
May 24, 2011 | Sharp Office Equipment & Supplies
Ink lines darken the entire page
sounds like the toner cartridge is failing, try another one
Mar 07, 2009 | Samsung ML 1710 Laser Printer
MFC-6800 prints very very dark as printer gets warmer
It sounds to me that you are not using paper that is for Laser printers. Sounds like you have what is called thermal paper. If you hold a piece of this paper over a light bulb and it turns dark then it is thermal paper. Try using paper for laser printers only.
hope this helps
Jan 12, 2009 | Brother MFC 6800 All-In-One Laser Printer
Samsung ml-2010 printer prints vertical lines on the page
it may due to scearch on roller. check the roller for any scearch mark.
Dec 23, 2008 | Samsung ML 2010 Laser Printer
Printer is dark
Go to Start > printers and faxes> right click on the laserjet4 icon>
properties > click on printing preferences on the first page > click advance on the next page > under Graphics, you will see print quality. Change it to either 600x600 or 1200x1200. The higher the number, the darker the print.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 26, 2008 | HP LaserJet 4 plus Printer
Weird toner issues
Hi Kelli.i would replace the drum unitand toner!
Mar 31, 2008 | HP LaserJet 2420dn Printer
HP PSC 2175 All-In-One InkJet Printer Logo
24 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
