Daewoo dwf-6094r wont spin on spin cycle
Washing machine does all other cycles apart from spin
  • boycie Dec 03, 2007
    the last time this happened that did fix the problem but this time it hasn't.the agitator spins but the tub doesn't in the spin cycle. can you offer any more advice please
  • Anonymous Mar 15, 2014
    My washing machine model Daewoo DWF 806 MF does not hold water with any program and wash sign blinks. How can I fix the problem?
    President:
  • 1,294 Answers
You need to clean out your outlet filter;(which is accessible thru the front bottom right side of machine, small push door, or plastic screw) this needs to be done periodically - according to your usage. If this does not solve your problem check out your outlet pump. Plug off the wall first before you do the jobs. The machine will not drain water if the outlet is clogged. For the pump, tubes, etc you hav to open up behind the machine. Be prepared for water to come flowing out.......
And rate me pl, if the solution has worked......
Posted on Dec 02, 2007
  • prem mathew Dec 03, 2007
    Afraid not for the moment........
  • prem mathew Dec 04, 2007
    Check your door switch - loose wire............
I have a Daewoo DWF-1150P top loader, but once the water has been added it's not washing
Check to see if the motor is running? How about the drum belt - is it on the pulley? Is it slipping?
Aug 12, 2015 | Daewoo Washing Machines
I have daewoo dwf 200 le and it not taking the water from the pipe outlet what to do to fix the problem
Assuming you have mains water running to the inlet tap and the tap i is open, the most likely cause is inlet hose connector filter is blocked or the inlet valve inside the washer is faulty.
Hopefully you are able to select the wash program and start the wash cycle. Otherwise the problem could not be in the water inlet or elsewhere.
Refer page 21 on this manual and also check the part number and location of the inlet valve.
http://www.daewoo.cl/sta/manuales-tecnicos/DWF-312W%20Manual%20Tecnico.pdf
Aug 17, 2014 | Daewoo Washing Machines
My Daewoo does not want to spin, any suggestions?
first does all of the water pump out when wash cycle is done? if not then check your drain lines and see if pump is coming on. if it is not then it wont let the washer spin,
Jun 03, 2014 | Daewoo Washing Machines
My Daewoo DWF 806 MP doesnt dry/spin after washing and rinsing and shows LE error. When drying starts some sound comes and then LE error apperas
my Daedwoo DWF-806 MP machine when i swith on shows figure 49 and not figure 0, and it also making noise like Buzz in between when the machine is ON. Can anybody help me to resolve this defect
thanks
Nov 01, 2013 | Daewoo Washing Machines
I need parts for my daewoo dwf-6094r where can I go to find parts like filters for example
Any parts store should be able to order these. You can also try and find a Daewoo owners club online to assist with parts locating.
Jul 12, 2012 | Cars & Trucks
LE CODE WHAT MEANS. DAEWOO WASHING MACHINES MODEL: DWF-772W
LE error code refers to the door mechanism. Usually there is a locking switch that senses when the door is closed, allowing the wash cycle to start. If your door is closed and you are still getting the LE error, it is probably this switch that is faulty.
Apr 20, 2011 | Washing Machines
Daewoo nano silver dwf-170mp
This Daewoo top load washing
Machine is the worst washing machine ever. Tried to call their maintenance many times still the problems coming back. Water flowing non stop, i need to spin it first to work properly. They repair it but the problem coming back always and its not abyer yet. My advice dont ever buy this machine again.. Its a full waste of money
Oct 17, 2010 | Washing Machines
Washing Machines Logo
319 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
