When your Epson printer's print head is clogged , then the red light for your ink and paper out is blinking. In this movement, the printer print head is blocked due to foreign objects or jammed paper.
Epson printer blinking different lights. The different lights blinking has different meaning and solutions. When the Epson printer red light blinking that means ink cartridge of your printer is out of ink. And when your printer green light blinking that means paper gets jammed inside the printer.
You can fix the Epson printer lights blinking error using following steps:
·Fix the paper jammed ·Check empty or damaged ink cartridge ·Clean the dirty print head or replace missing or failed print head
Open your printer paper feeder. Then look inside it. There is plastic roll inside it. That is the curlprite. Try to open it. at the last stage you may see a spring that usually is in the plustic rollar's holle. Remove it and re assemble carefully. That's ok.
I think you will be relive from your printer problem.
Thank you.
The lights continually flashing indicate a paper jam or the printer being out of ink. Check/clear any paper jam and verify the ink cartidge is set correctly.
Gently pull any jammed paper out from the output tray or sheet feeder.
If paper is stuck inside, open the printer cover and remove the jammed paper, including any torn pieces. Then close the printer cover.
If paper remains near the sheet feeder, press the paper feed roller lever inside the paper feeder to release the jammed paper, then carefully pull it out.
Load the paper correctly.
Press the stop button to resume printing.
If the printer continues to jam or misfeed paper, and you are certain that there are no foreign objects lodged down inside the paper feed area, your printer may require service. Please call Epson technical support for further assistance.
Sorry - no solution, except to perhaps agree with the guy who says throw it out the window. I only wish I wasn't just on the first floor. This thing does more jamming than printing. It claims a jam when there is none. Infuriating.
Turn off the printer and then open the scanner unit. Cancel the print job.
See Canceling Printing
Remove all of the paper inside, including any torn pieces.
Close the scanner unit and then turn on the printer.
When a paper jam occurs during printing for some reason, the printer
beeps, displaying the message <PAPER JAM> in the display. When
a paper jam occurs, remove the jammed paper using the following
procedure, and then resume the job. If the message that indicates the
paper jam does not disappear even after removing the jammed paper
following the procedure, there is a possibility that torn pieces of
paper are still left inside the printer. Inspect each part of the
printer again, and completely remove all pieces of jammed paper.
I have the same exact problem of paper half torn removed but I can not see the other half anywhere. The printer has hardly worked for at the most six pages and now showing paper jam error. How do I fix it?
