Question about Mustek Plug-n-Scan 1200 UB Plus Flatbed Scanner
Scanner i put my driver instaling cd in the driver instalation welcom screen does not apear i click start click run then type in "driver:run and nothing happens
  • bobby blue Dec 05, 2007
    thank you once again do you only do problems for mustec products
  • JLLC Jan 02, 2008
    JUST GOT NEW COMPUTER NOW WITH WINDOWS XP, TRIED TO INSTALL SCANNER INSTALLATION CD ,COMES UP ON SCREEN AS WINDOWS 98 AND WILL NOT INSTALL BECAUSE I HAVE UPGRADED MY COMPUTER TO WINDOWS XP
  • 383 Answers
Http://www.mustek.com/supportdrivers.asp...
Make sure you follow the instructions listed on the page; pay particular attention to the part about unplugging the scanner from the computer before installing the software.
This is with out your cd above, but if ya want to re-down load with your CD again :
You have to go in to add and remove programs and remove all ready what u have down loaded on your computer for the scanner. Mkae sure u look for the programas pertaining to the scanner and re-move and than re-boot the computer and start all over again with your cd , let it run its course Should be fine now for ya.
Posted on Dec 02, 2007
  • sheila skaggs Dec 11, 2007
    I work on other products as will.
    Merry Christmas / glad its going for ya........thank you for the Vote.
SOURCE:
Blue screen of death
Run the recovery console and type chkdsk /r
Insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
Boot from the CD
When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
If you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
Then type the chkdsk /r command
Let that run through and then restart the machine after it finishes.
If that doesn't fix it, run the Windows XP Repair Installation. You can find a walkthrough here - click here
Mar 28, 2011 | Computers & Internet
Lost software to printer
You can download software from HP website, I will give you the link
Aug 26, 2008 | HP Officejet 5610 All-In-One InkJet...
Printer is not scan but some problem she has. Error in scannor Turn off scannor and follow instructions ni manual. Scannor drive will closed. Code : 61,213,0 I want to new setup Canon PIXMA MP160...
  1. Select 'Program' (for Windows 2000/Me/98), or 'All Programs' (for Windows XP) from the Start menu.
  2. Select the name of the printer model to remove and select 'Uninstall.'
  3. When the MP Drivers Uninstaller window is displayed, click 'Perform.'
  4. When the confirmation window is displayed, click 'Yes.'
  5. When the Uninstallation Complete window is displayed, click 'Complete.'
  6. Reinstall the drivers.
Reinstall the Drivers
Note:
  • The MP drivers can be installed using Easy Install or Custom Install.
    Easy Install automatically installs the software which is in the CD-ROM.
    This method is recommended for first-time users.
    Custom Install allows you to select the software programs from MP Drivers, Application Software, and On-screen Manual.
  • Login as a user with Administrator privileges to install on WindowsXP/2000.
  • Close any antivirus software that may be running prior to installing the drivers.
  1. Turn off the printer and disconnect the cable connecting the computer and the printer.
  2. Insert CD-ROM in the computer. (The CD-ROM will start automatically and the following window will be displayed on the screen.)
    1. If setup does not start automatically, click 'Start' and then 'Run'.
    2. At the Run window, type x:\msetup4.exe (where x is your computer's CD drive) in Open box and then click 'OK'.
  3. At the main installation window, click 'Easy Install' or 'Custom Install'.
    When selecting Easy Install:
    (A) Click 'Easy Install'.
    (B) Click 'Install' in the following window.
    * Display varies according to the printer model.
    When selecting Custom Install:
    (A) Click 'Custom Install'.
    (B) When the following window is displayed, click 'MP Drivers' and the application software to be installed, and then click 'Next'.
  4. When the License Agreement window is displayed, read the content carefully and click 'Yes'.
  5. The installation will start.
    Messages may be displayed during the installation of the application software.
    Follow the instructions on the window and continue the installation.
  6. When the Printer Connection window appears, connect the printer to the computer and power on the printer.
    Note: If the installation cannot proceed even after 2 minutes, stop the installation by following the procedures below and start from the beginning again.
    1) Click 'Cancel' at the Printer Connection window then click 'Start Over' at the Installation Failure window.
    2) At the window to install the driver / applications appears, click 'Back' then click 'Exit'.
    3) Restart the computer.
    4) Install the printer driver again.
  7. For Windows XP, at the Welcome to the Found New Hardware Wizard dialog box, confirm Install the software automatically (Recommended) is selected, then click 'Next'.
    Note: The Welcome to the Found New Hardware Wizard dialog box may be behind the Printer Connection window.
    In this case, click 'Found New Hardware Wizard' button on the task bar to display the window.
  8. After the files are copied automatically and the dialog box Completing Found New Hardware Wizard window appears, click 'Finish'.
  9. If the Welcome to the Found New Hardware Wizard dialog box appears again, click 'Finish' again.
  10. At the Print Head Alignment window, click 'Execute'.
    Note:
    * The Execute button may not appear for all models. In that case, skip to step 13.
    * The Print Head Alignment can also be done after the installation of the printer driver.
  11. When the Start Print Head Alignment window appears, load one sheet of A4 or letter size plain paper in the sheet feeder and click 'Print Head Alignment'.
  12. At the Do not start another operation until current one has finished dialog box, click 'OK'.
  13. When the pattern is printed, click 'Next' at the Print Head Alignment dialog box.
  14. At the Installation Results dialog box, check the content then click 'Next'.
  15. At the Installation completed successfully dialog box, click 'Exit'.
    Note: When the Restart button appears, confirm that Restart the system now (recommended) is checked then click 'Restart'.
Dec 04, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Try to connect with laptop
Make sure that your laptop have the printer software/driver installed in it, Printer needs driver that allows it to communicate with your computer/Laptop. Sometimes drivers need to be updated.
But before installing driver you need to uninstall previous version installed in your laptop then after restarting laptop you can re-install new driver. Visit this link to install driver for Lexmark X2670. Go to download & start downloading.
Thanks...!!
4 thumbs rating keep us motivated to answer more free questions.
Oct 01, 2010 | Lexmark X2670 All-In-One Printer
I had lost my cd program to install my scanner hp Deskjet F 4180
Hi ,
Not an issue you would be able to download it from the hp website type this URL in the address bar :www.hp.com/support then ?select the country ? the put in the model number for the scanner that is Hp Deskjet F4180 and click on the arrow next to it ?click on software and driver downloads?select the operating system?in step 2 click on the + sign nest to DRIVER(3) then click on the link that says Deskjet full feature software and drivers?click on download ?click on save once the file download page opens up ?save it on the desktop and run it .
all the best
May 19, 2010 | Computers & Internet
Doesn't display HP as scanner
Part of your installation is not finished.
Better run again your CD installer.
Or browse your CD installer and look for scanner driver. Try to install it.
You can also try to add Scanner
On control panel, double click Scanners and Cameras
Click "Add Imaging Device" to start scanner installation.
Click "Next" and select "Have Disk" button
Browse the scanner driver on your CD installer
Select the file with "inf" as an extension.
Press "Open" and click "OK"
Each time i turn on my computer my printer re-installs
Step one: Uninstall the software
Even if the HP software did not install successfully, there might be elements of the software installed on your computer. Use your product software CD to remove the HP software. If you no longer have the product software CD, skip to Method two: Uninstall the software without the product software CD .
Method one: Uninstall the software with the product software CD
1.
Insert the product software CD into the computer's CD drive.
2.
If the Welcome to HP screen opens, click Cancel or Exit .
3.
On the Windows taskbar, click Start , click My Computer , right-click the CD drive, and then click Open .
NOTE: If you double-click the file, the HP Installer launches. Click Exit , and then right-click the file to open.
4.
Double-click the Util folder, and then double-click the ccc folder. A list of files on the software CD displays.
5.
Double-click the Uninstall_L2.bat file. The Run window opens again, with the path to the Uninstall_L2.bat file displayed.
6.
Click OK to start the software removal, and then follow the on-screen instructions.
If you do not have the product software CD, you can download the software from the HP Web site, and then use the downloaded file to perform the uninstall procedure.
1.
Open a new window to browse to the Select Software and Drivers page:
1.
Right-click this link, Support and Drivers download page , and then select Open Link in New Window .
2.
If prompted, type your product number. You might also need to click it in a list of similar products.
3.
Select your operating system. The Select Software and Drivers page opens.
2.
In the Driver section, click the Full Feature Software and Drivers option.
3.
Click Download only . This option allows you to install the software at any time after the download completes.
4.
The File Download - Security Warning window opens. Click Save , and then browse to the location on your computer where you want to save the file. Consider saving the file to your desktop for easy reference later in these steps.
5.
Click Save . The software downloads to your computer.
6.
When the file downloads, double-click the icon for the downloaded file.
7.
When the installation screen launches, click Exit .
8.
On the Windows taskbar, click Start , and then click Search .
9.
Under What do you want to search for? , click All files and folders .
10.
Type Uninstall_L2 in the first search box, and then click Search .
11.
Double-click the Uninstall_L2.bat file. If there is more than one file in the search results, expand the In Folder column, and look for the file that is located in the Temp folder with 7zXXX.tmp in the filename (XXX varies by driver version). The HP uninstaller opens.
NOTE: If the Welcome to HP screen opens, click Cancel or Exit
12.
Follow the on-screen instructions to complete the software removal.
Step two: Delete all temporary files
1.
Click Start , and then click Run .
2.
In the Open box, type %temp% , and then click OK . The Temp folder opens, displaying the Temp files.
3.
Click Edit , click Select All , and then press the Delete key to delete the files.
NOTE: Do not highlight or delete the Temp folder. Delete only the files in the folder. If an Access Denied message displays on the screen during the delete process, click OK to close the error message and then continue deleting the remaining files.
Step three: Temporarily turn off startup programs
Follow these steps to turn off the Terminate and Stay Resident (TSR) programs running in the background on the operating system. These programs activate computer utilities like antivirus software, but are not required for the computer to function. Occasionally, TSRs prevent the product software from installing correctly. In Windows XP, the MSCONFIG utility prevents TSR programs and services from starting.
1.
Click Start , and then click Run . In the Open dialog box, type msconfig , and then click OK .
2.
Click the General tab.
NOTE: Make a note of the settings in the General tab now. You will need this information to return the settings to the original configuration.
3.
Click Selective Startup .
4.
If there is a check mark next to Load Startup Items , click to clear it.
5.
Click the Services tab, and then select the Hide All Microsoft Services check box.
6.
Click Disable All to clear all the check boxes on the list.
7.
Click Apply , and then click Close .
NOTE: If an 'Access is denied ' error message displays on the computer when you make changes, click OK , and then continue. The message does not prevent you from making changes.
8.
Click Restart to apply the changes.
Step four: Reinstall the software
Use one of the following methods to reinstall the software.
Method one: Install the software with the product software CD
If you have the product software CD, follow these steps to reinstall the software. If you downloaded the software, skip to Method two: Reinstall the downloaded software .
1.
Insert the product software CD into the computer’s CD drive. The software installer starts automatically. If the Install Wizard does not start automatically, click Start , click My Computer , and then double-click the CD drive.
2.
On the CD menu, click Install Printer Driver .
3.
Follow the on-screen instructions to complete the software installation, and then proceed to the next step.
1.
Browse to the folder where you saved the downloaded file, and then click it. The file name ends in .exe .
2.
You can accept the default location to save the files. Click Next , and then wait while the installer extracts the files to prepare for installation.
3.
When the installation screen opens, click Install .
4.
Follow the on-screen instructions to complete the installation, and then proceed to the next step.
Step five: Re-enable startup programs
1.
On the taskbar, click Start , and then click Run .
2.
In the Open dialog box, type msconfig , and then click OK . The System Configuration Utility window opens.
3.
Click the Startup tab.
4.
Select the check box next to programs that should run when the computer is turned on (refer to the notes that you took earlier in this document).
CAUTION: Do not disable any Microsoft services.
5.
If no changes should be made to startup programs or services, click the General tab, and then select the Normal Startup check box.
6.
Click Apply , click OK , and then click Exit without restart .
Step six: Install the HP software update
1.
Right-click this link, HP Critical Update , and then select Open Link in New Window .
2.
Thoroughly review the information on the download information page, and then follow the on-screen instructions to download and install the software.
3.
Restart the computer and the product.
Nov 18, 2009 | HP Photosmart C4280 Aio Printer
I Have a Hp Deskjet F380 ALL-In-ONE Printer-Scanner-Copier,I Need Know How to install a print driver for my Hp Deskjet F380 Printer.Thank You, I Need Help????
How do I download and install the software? To download the software, do the following:
  1. Click here to go to the Software and Drivers page for your product.
  2. Click your operating system.
  3. In the Driver section, click the appropriate software driver.
  4. Follow the instructions on the page that appears to download and install the software.
How do I install from the CD? Two installation options are available when installing the software and drivers from the product CD. The recommended install installs everything your device requires to work, including a suite of software recommended for your installation. The custom install allows you to choose what software to install. The recommended install is designed to work for most users. Use the custom install only if you have one of the following reasons:
  • Low hard disk space on the computer.
  • You do not want the additional software.
  • Errors occur during the recommended installation. NOTE: If errors occur during the recommended install, fix them before doing a custom install.
Recommended install Complete the following instructions to install the software: CAUTION: Do not connect the USB cable until prompted to do so during software installation. HP recommends using a USB cable that is less than 10 feet (3 meters) long. NOTE: Choose unblock or accept on all firewall messages or the install will fail.
  1. Insert the software CD into the CD-ROM drive of the computer. The software installer starts automatically. NOTE: The User Account Control screen might display. Click Continue .
  2. Click Install on the Thank you for purchasing from HP! screen.
  3. Click Next on the Welcome to the Install Wizard... screen.
  4. Click Next on the Do Not Block HP Install Wizard Processes screen.
  5. Select Yes or No on the Automatically Check For Updates screen and then click Next .
    • Choose the Yes (recommended) option to check for updates through an Internet connection.
    • Choose the No option if you do not want to check for updates.
  6. Select Recommended on the Installation Options screen, and then click Next .
  7. Follow the instructions on the screen that displays to finish installing the software.
Custom install CAUTION: Do not connect the USB cable until prompted to do so during software installation. HP recommends using a USB cable that is less than 10 feet (3 meters) long. NOTE: Select unblock or accept on all firewall messages or the install will fail.
  6. Select Custom on the Installation Options screen, and then click Next .
  7. Select which software to install by selecting or clicking to clear the check box next to each item on the Custom Installation screen. Click an item to see its description and the required disk space. NOTE: You must install the drivers and the HP Imaging Device Functions for the buttons on the front panel to be functional.
  8. Follow the instructions on the screen that displays to finish installing the software.
Aug 19, 2008 | HP Office Equipment & Supplies
Canon DR-121OC
Uninstal all the software for the scanner. Install the correct ISIS?TWAIN Drivers from the following link. http://software.canon-europe.com/products/0010336.asp. Install CapturePerfect.
(Incase you did not know, the ISIS/TWAIN Driver is to connect the Computer to the scanner and CapturePerfect is purely 'Scanning Software', just to facilitate easy scanning.)
S. Mohan, India
Jul 14, 2008 | Canon DR-1210C Scanner
Mustek Plug-n-Scan 1200 UB Plus Flatbed Scanner Logo
69 people viewed this question
Top Mustek Office Equipment & Supplies Experts
Mike
gggg
Are you a Mustek Office Equipment and Supply Expert? Answer questions, earn points and help others
