Question about Refrigerators
My ice freezes together!
My ice maker makes ice, but it has a leak. Water freezes from the ice maker to the tray. It will make several blocks of ice, but when I try to get the ice out it is all frozen together. I was wondering if anyone knew where the water was coming from or if something could be loose. I would like to try all possibilities before I purchase a new ice maker. Thank you! My ice is one big block in the corner.  But the ice machine still works and there are still several loose cubes in the other areas in the bin.  But the corner is a block of ice.  Strangely, there's also always a little brown spot that develops on the ice.  As if oil is dripping.  I have no idea what that's about.
  • 1 more comment
  • chessie1629 Feb 19, 2008
    I have the same problem and I can see that the ice tray is twisted so that when it fills water to one of the cubes runs into the dispenser. This then freezes into a block. I would like to get a new tray or an adjustment to stop filling so high.
  • Tasker35 May 03, 2008
    I have the same problem. After the ice tray fills with water, a trickle of water drips into the left rear corner of the ice bin and freezes most of the cubes todether. I can't tell if the tray is overfilling or if there is a leak. The refrig is 18 months old. I attempted to level the ice tray but that didn't help.
    You would think that with the years of problems SubZero has had with malfunctioning ice makers, they might get a clue and redesign one that works. Friends that purchased similar units have also had problems with their icemakers, but not leaks.
  • TGunter3 Jun 26, 2008
    I am also having the same problem with the ice maker in my LG. It makes ice just fine, the bin is full but when you try to dispence it it can't because the bottom of the ice bin is frozen solid. And yes it does seem to start out in the back on the left side. My ice tray seems to be warped. Can it be spilling the water from the lowest part of the tray into the bin? If so can I replace the tray? HELP ME PLEASE I MISS MY ICE DIPENCER!!
HVACRH20
  • 237 Answers
SOURCE: My ice freezes together!
Do you mean the ice cubes are too large to be individual cubes and come out as a lump? The water is filled by a timed fill so if the fill solenoid stays open a little and drips water into the cube tray it will have more water than normal. I guess I'm not sure if you mean the ice cubes are stuck together in the tray or are they sticking together in the holding bin area?
Posted on Jan 31, 2007
  • 1073 Answers
SOURCE: Ice cubes melt together
check the fill cup on the rear of the icemaker to see if any ice is frozen in the fill cup if so remove the ice
Posted on May 06, 2008
SOURCE: ice maker will not eject ice cubes in GE Profile gss25tswass
Empty all ice from the bin and from the "Drill" like Ice shaper spinning unit. Let the unit make some new ice and see if that works.
Posted on Feb 14, 2009
  • 531 Answers
SOURCE: ice maker not making ice- water leaking or cubes melting
icemaker have problem
Posted on Apr 06, 2009
Maytag317
  • 1136 Answers
SOURCE: Ice cubes are frozen but will not eject into the ice bin. I need to know how to get them out.
HI, You can use a hair dryer to the bottom side of the ice maker and it will let the cylce finish and remove the cubes. Can you tell if the cycle has started?
Please let me know if I can assist you further.
Thanks
Vic
Posted on May 18, 2009
Ice maker won't make ice
most times I see the tray and fill tube ice up its due to a leaky fill valve , this valve should close tight after filling tray , but sometimes they leak just slightly then everything freezes up in a block of ice
fill valves on most all units is located in back lower left corner , just follow the water line in the back of unit
Jan 15, 2016 | True Refrigerators
How do I stop my ice maker water filler hose from freezing - which stops water from filling the tray?
This problem is caused by a defective water control valve that does not stop leaking water like a dripping faucet. This causes water to freeze in the water fill tube thus blocking fill of ice tray. Replace water control valve.
Appliance 911 Sea Breeze
Sep 19, 2015 | LG Refrigerators
Ice keeps getting stuck in ice maker # fsc23r505b2
Most icemakers have a low voltage defrosting element wrapped around the ice shute to prevent the ice from freezing and jamming up. Carefully have a look for any disconnected wires or damage to the heating element. If the ice is getting "glued" together in the ice box itself, its likely that the water tray is overfilling and causing water to run down into the ice box. When it freezes, it freezes all the ice blocks together. In this case, you may need a new ice maker tray or ice maker water valve.
Oct 20, 2013 | Frigidaire Refrigerators
Ice maker
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
other ice maker related issues and solutions:---
Ice maker dispensing ice with black or white plastic pieces in ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-ice-with-black-or.html
After replacing ice maker assembly, ice is not getting made?
http://alltypesofpartsreplacing.blogspot.com/2011/10/after-replacing-ice-maker-assembly-ice.html
Ice maker is leaking water and causing the ice to freeze?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-leaking-water-and-causing.html
Ice maker is noisy and not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-noisy-and-not-making-ice.html
Refrigerator ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/refrigerator-ice-maker-stopped-making.html
Ice maker leaks water into ice bin causing a glob of ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaks-water-into-ice-bin.html
Amana Refrigerator leaking water from ice maker?
http://alltypesofpartsreplacing.blogspot.com/2011/10/amana-refrigerator-leaking-water-from.html
Ice maker leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaking.html
Ice maker is dumping the ice cubes out before frozen solid.
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-dumping-ice-cubes-out.html
Water overflowing ice maker?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflowing-ice-maker.html
Ice cube is getting stuck up hard in ice maker
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-cube-is-getting-stuck-up-hard-in.html
Icemaker quit working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/icemaker-quit-working.html
Quit making ice
http://alltypesofpartsreplacing.blogspot.com/2011/10/quit-making-ice.html
Water leaking into ice tray, frozen glob of ice
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-leaking-into-ice-tray-frozen-glob.html
Not making ice, and water leaking in freezer?
http://alltypesofpartsreplacing.blogspot.com/2011/10/not-making-ice-and-water-leaking-in.html
The ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice_20.html
Ice maker not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-making-ice.html
Ice maker quit working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-quit-working.html
Ice maker dispensing black pieces of plastic in the ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-black-pieces-of.html
Replaced Ice maker but its still not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/replaced-ice-maker-but-its-still-not.html
Ice maker leaked creating an ice block?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaked-creating-ice-block.html
Ice tray leaked?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-tray-leaked.html
Ice maker stopped functioning?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-functioning.html
Ice maker stop working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stop-working.html
Ice maker failed
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-failed.html
Old ice maker stopped working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-stopped-working.html
Old ice maker started leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-started-leaking.html
Ice maker not working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-working.html
Ice maker overfills and cause water to flow into ice dispenser and freezes?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-overfills-and-cause-water-to.html
Ice maker didn't make ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-didnt-make-ice.html
Ice maker was leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking.html
Ice maker was leaking after it filled up with water?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking-after-it-filled.html
These will help.
Thanks,.
Dec 21, 2012 | LG LFX25976ST - 3-Door French Door...
Not making ice
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
Sep 24, 2009 | GALAXY Microsystems 25.4 cu. ft....
Ice maker overfills and leaks into the ice bin.
I have had a similar problem several times. What I have found is that the ice tray coating has begun to flake off. Then, the ice sticks or partially dumps. Next more ice builds up and when the valve opens the water runs over the partially emptied tray and spills into the bin making "icebergs". The remedy is to replace the tray or if that is not possible, then, the whole icemaker. In fact, I have one down stairs to put in tomorrow. They don't seem to last more than about 4 years or so.
Jul 11, 2009 | Amana ARS266ZBS Side by Side Refrigerator
I have a AMA IC6 ice maker and the ice is stuck together form water running over into the catch tray.i have removed the ice maker and let it thaw then reinstalled and the same thing happened. any...
Having problemAMA IC6 Icemaker. Water leaking into tray as it is making cubes causing previous cubes to freeze together and to the bottom of the container. Trying to defrost to see if that helps. Any suggestions appreciated.
Jun 09, 2008 | Amana Refrigerators
Ice Maker Freezing Up and Ice not dispensing
Check your ice cube tray to see if it is warped. Mine was. I took the tray off and dipped it into boiling water and remoulded it to the original shape and re-installed it. So far no problems. The tray gets warped because of the ice cube release mechanism. The tray is rotated around until it meets a block on one corner which creates the twisting motion we used to do on manual trays. Over time it tends to warp the tray. Good luck
Nov 26, 2007 | LG LRSC26925 Side by Side Refrigerator
Jan 30, 2007 | Kenmore 74172 / 74174 / 74179 Top Freezer...
Refrigerators Logo
150 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
