Question about Philips 60P8341 60" Rear Projection Television
Help me please..
My phillips is loosing it's volume. I have a blury green vision screen. when i try to turn it off it takes a few seconds before it acutually turns off but then it turns back on. When i try to chang the channels it goes blank and the power light lifgt stays on.
  • 934 Answers
Monalisa,
An all too common problem with that unit is the Ssb or (small signal board, Philips p/n# PH3912725871 located just behind the tuner. It's actually a simple fix for a shop, what we call a plug & play repair but the part isn't so cheap. Last one I did thursday I bought from Vance Baldwin $267.82 plus shipping and core. You get the core back when you return the old part.
You might call a few shops like you know what you're doing and ask what they charge for changing the Ssb in your unit.
Have a great day!
Bill
Posted on Dec 02, 2007
SOURCE:
Double vision screen
This is most certainly a display problem, as in, a problem with the LCD panel. I used to fix 4 or 5 LCD's a day and had a few with the same problem. It can be fixed by being replaced.
Jan 06, 2014 | Computers & Internet
Xo vision xtab factory reset
I had been trying to locate how to access the recovery options for the XO Vision XTAB tablet as well. Mine would show the XO Vision logo on start-up and then show a cursor in the upper left corner for a few seconds and then showed "ANDROID" a little further down and to the right of the upper left hand corner with a flashing cursor right behind it.
I was finally able to get into the recovery options press HOME, VOLUME UP, & POWER at the same time and hold for about 6 seconds or so. You need to let go before the XO Vision logo goes away. Wait until the logo goes away and a cursor should display in the upper left hand corner and then you'll get to the recovery / update options screen.
Use the VOLUME UP / DOWN keys to navigate the menu and then you'll press MENU to select the option. After that let it run through its processes until it completes. My attempt was unsuccessful at a factory reset and I'm still not sure how to fix it, however, you may have better luck.
Apr 08, 2013 | XO Vision Xtab Android Ebook Reader
My philips big screen tv is blury with double vision on words
Convergence, Convergence!
see attached photos--if looks like that it needs two chips and/or a few resistors replaced--total parts cost at say SUBURBAN ELECTRONICS under 25 dollars.
look at the photos here=look anything like your problem?
Mar 27, 2012 | Philips Televison & Video
Our tv is blury, double vision with whites going
There seems to be two problems with the unit. The first symptom indiates your convergence IC's needs to be replaced. The second symptom coud be a several things, 1. Bad connections on the Crt board of the green tube, 2. The 200v screen bias voltage supplied by the flyback could have bad connections on it. Seems you have intermittent cold solder joints. Check the D board around the Flyback area for bad connections, or old grey looking solder connections all should look shiny. 3. The Green Crt maybe going faulty, the lines going thru the picture are scan lines and indicates that the Screen controls are to high. But i know you have'nt adjusted these so i would suspect the Green Crt is Faulty. But check solutions 1&2 first, One way to find out if its bad is to unplug the green crt board from the tube and turn the set on if it stays on and does'nt shut down then it is faulty, also while turning on look at the crt's neck for sparks which indicates arching in the tupe and will need to be replaced. Replacing the Convergence IC's will solve the distorted pic issue.
Nov 17, 2009 | Sony KP-51WS500 51" Rear Projection...
Picture is green and blury
turn the tv off then turn the tv on the green on light blinks on and off for a few seconds . it must be some kind of reset, picture is ok again
Oct 20, 2009 | Sony Televison & Video
Phillips tv , double vision,
You have bad convergence IC's. Replace both the red and blue drive chips. They are easy to spot. They are mounted to large, finned heat sinks. The # on the chips starts with "STK-" and then there are numbers following. Both red and blue use the same part. There are 20 or so pins to unsolder\solder. These parts are available to the consumer from tritronicsinc.com. Good Luck!!
barneyluc
Oct 03, 2008 | RCA R52WH73 Projection Television
My 20" phillips flat tv does not work, the stand by light when switched on turns green but then just flickers, no sound or vision, tv is only 18 months old-pls help
minnieheer,
some televisions are under warranty for up to 2 years, so please check that first.
Second, unplug your television until you can complete some internal repair.
If you feel comforatable completing the repair yourself, our experts can walk you through it. You will need assistance through our premium service.
Also, we can help you find a local repair service through our search engine located on this page.
Jun 28, 2008 | Philips Televison & Video
Docked word on my screen player
Reset first. If fails, Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Mar 26, 2008 | Creative Labs ZEN Vision:M Digital Media...
Philips 60P8341 60" Rear Projection Television Logo
73 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
