Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Philips 60 inch rear projection model number 60PP920217F
Probally a simple solution to this but I have had this rear projection for 5 years and worked great until the other day. Now the picture is starting to separate around the top and bottom and look almost like it is displaying the picture on a curve, thinner in the middle and wider on the edges. Also words and simple images like lines,Etc. seem to duplicate its self in the color of red and green. Please help! Thanks ! Sounds like the convergence IC but how do I fix it? And Where is it?
  • 1 more comment
  • rudedawg Dec 03, 2007
    I appreciate the honesty and I guess I need to find a dealer to work on it. Thanks!
    I was kinda bummed that it was not an easy fix, but thanks for taking the time to add your solution because when it comes to rear projection teleisions I have no clue!
    Thanks again!
  • Anonymous Feb 01, 2009
    I can't find anything about convergence adjustments in my manual, and I can't find it on the tv menu either. I know it's there, I've done it before. HELP! It's almost game time!!!
  • 934 Answers
What you have there is a PTV835 chassis and the convergence amps are two STK392-110 Sanyo built Ics mounted on a large aluminum heatsink on the signal board... It could very well be the amps and it could also be the protect fuse 1008 (2a 250v), fuse 1007 (1a 250v) and a 1a mylar cap at location 2055, all of those are located on the upright digital convergence board.
This is not an easy job in this particular unit and not one that I could write-out in a step-by-step set of instructions, too many varibles. The short version would be to strongly suggest that you take this to a qualified shop and have them do it..
I would also suggest that you ask them to replace the amps with the STK392-150's for greater reliability. In fact you could purchase them yourself from acme in Florida and save a few bucks. Also, take the unit to them don't pay the pickup delivery and you'll save a little and always get a written estimate first before any work is done...
Hope this helps!
Bill
PS: A job like this in my shop is approximately 425 - 500 dollars plus tax including parts.
Posted on Dec 02, 2007
SOURCE:
I have a Philips 60"
The set will need a convergence repair kit. Or to turn the red CRT off you can turn the screens down on the red CRT untill it shuts off, But the set will have a very blue or green picture and will not be very good to watch. A convergence repair kit is the best way. You can get the repair kit with instructions from www.tvrepairworld.com
May 05, 2011 | Philips 60PP9202 60" Rear Projection...
We have a philips projection tv 60PP920217F we can not alighn the blue color the picture is concaved on bottom and top
This is a convergence problem and can be repaired by replacing the two STK-392-120 convergence chips and adjusting the set with the original remote control
I have specific instructions for this repair from start to finish.
SD TECH
Feb 16, 2010 | Philips 60PP9202 60" Rear Projection...
Broken Screen Phillips 60PP920217F
go to phillips.com/parts they should have them there
Aug 31, 2008 | Philips 60PP9202 60" Rear Projection...
My 65 Philips inch rear projection TV picture went out. Makes a chirping noise
Whats the model number, as thats usually a bad HOT transistor or flyback the causes that. Please respond to this same post with your model number and I will try to assist you with the problem.
Jul 08, 2008 | Philips 60PP9202 60" Rear Projection...
COLOR PROBLEM ON MY PHILIPS 60IN MOD#60pp920217F
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 13, 2007 | Philips 60PP9202 60" Rear Projection...
Philips 60 inch rear projection t.v. model number 60PP9363H/17
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Oct 26, 2007 | Philips 60PP9352 60" Rear Projection...
Philips 60pp920217f Blinking Power Light
Call a technician. If fixed it is worth it for ~$200.
Jun 14, 2007 | Philips 60PP9202 60" Rear Projection...
Owner's Manual
go to http://www.usasupport.philips.com then click on search, look for owners manual go to product support page enter 60pp9202 and see what you need as they have an operations manual and a quick start manual.
Sep 06, 2006 | Philips 60PP9202 60" Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
184 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
