Problem with Washing Machines
Clothes still damp to wet after spin cycle
1 Solution
I have a kenmore washing machine mod. 110.20802 990. it has been leaving the clothes damp to wet after the spin cycle.it also sometimes or i should say most of the time ,starts to agitate when the fill begins(only in the regular cycle not when set to the perm. press cycle.what do you think the problem is?
  • View Previous Comments...
  • avatar
    geno d washer does not have a filter.the spin cycle does not seem to come up to full speed.softener does not come out of "agitator" dispenser.is the motor possibly going.note:this is a direct drive unit-no belt.
    Dec 03, 2007
  • avatar
    geno d i looked for a filter but did not find one.i was just looking at a parts brake down and noticed a filter plate under the basket. is this the filter you are referring to.
    Dec 04, 2007
  • avatar
    Guest I have an Asko W660 front loading washer. I cleaned the pin trap of any debris but the washer does not drain the water. I get an error message on the display indicating a "water outlet fault". I hear the pump running but the water will not drain. How do I clear out the drain if it is clogged?
    Dec 08, 2008
Washing Machines Logo
  • Posted by
  • on Dec 02, 2007
2,484 people viewed this problem
  • 0 people are following this problem. Be the first!
More Insights on Fixboard
1 Solution
You need to clean out your outlet filter; this needs to be done periodically - according to your usage. If this does not solve your problem check out your outlet pump. Plug off the wall first before you do the jobs. The machine will not drain water if the outlet is clogged. And rate me pl, if the solution has worked......
  • avatar
    prem mathew What does your manual say about cleaning filters? There are machines without filters. The thing you found, is it removable to be cleaned, you shd check these things out...........
    Dec 04, 2007
  • avatar
    prem mathew Look for the kick panel in front below, 3 screws beneath. On opening you will find drain hose & filter cap. Be prepared for lots of water. Open out and clean well. Also check out your exit hose.
    Mar 28, 2009
1 Suggested Solution Relevant solutions from other related problems that we feel might be a fix.
Author image
You need to replace the Kenmore Washer Lid Switch. I had the same problem so being lazy I would just push down on the washer's lid and it would push the lid switch further down. making the water drain. after a while I just replaced the lid switch.
Source: Kenmore washing machine 80 Series 110 20802 990 Will not agitate or spin"
  • Was this solution helpful? Yes No
Add your solution
Full Name
Top Washing Machines Experts
john_cross
  • Solutions: 6277
  • Level: 3
  • Achievements: 1
blueextc3221
  • Solutions: 15935
  • Level: 3
  • Achievements: 2
D. Floyd Kolb
  • Solutions: 43495
  • Level: 3
  • Achievements: 2
Expert Badge
Are you a Washing Machine Expert?
Answer questions and help others.
Users Who Viewed This Problem Also Viewed:
See More Washing Machines Related Problems
Unsolved Problems:
Loading... Loading...
