Question about Olympus FE-210 Digital Camera
FE 170 OLYMPUS digital camera
When i turn on the camera the screen would be blank and it immediately goes off and the lences do not go back into the body of the camera
when i turn my camera on, the camera makes a beep and then the screen turns off. the lens doesn't retract. i've replaced the batteries multiple times and let it rest. nothing has worked
  • 2 more comments
  • Anonymous Dec 14, 2007
    When I turn my camera on, the camera makes a beep and then the screen turns off. the lens doesn't retract. i've replaced the batteries multiple times and let it rest. nothing has worked
  • Olympusnut Jan 21, 2008
    Battery compartment door clip is easily released and leads to faulty startup and the lens retracting, battery indocator indicator on screen shows RED = No battery, while the batteries are actually 100%
    Frustrating..
  • Anonymous Apr 05, 2008
    SAME PROBLEM =[
Lense error,bad gears ? if the servo is bad it will not offer any image on lcd probably not worth the cost of fixing. try getting a more durable camera next time
Posted on Dec 15, 2007
Its fucked up olympus sux i bought a sony cybershot 4000000 times better than that trash fe-210.
i trashed it destroyed it mutilated it till it begged for mercy
Posted on Dec 03, 2007
SOURCE:
When trying to take pictures outside the screen goes blank.
Try to manually make it so that it is set to outdoor settings. Or maybe try low brightness and no flash.
May 12, 2008 | Olympus FE-190 Digital Camera
I recieved an Olympus digital camera for my birthday ,a FE-170/X-760. It is supposed to have a USB cable included, it does not. How can I optain one?
They can be purchases at Walmart, Kmart, Radio Shack, etc. They are pretty generic...the plug that goes into your camera is the only difference...take your camera with you to get the correct size.
Sep 28, 2009 | Olympus FE-170 Digital Camera
Morning. I have an Olymous FE-170 Digital Camera.
Sounds as if this may be a repair issue with the camera. You may want to call Olympus customer service to discuss their repair policy. Their telephone number is 800-622-6372 option 2 and then option 3.
Mar 10, 2009 | Olympus FE-170 Digital Camera
No sound recording during video recording with olympus fe 170
To my knowledge, an Olympus FE-170 has no audio recording capability and records the video on 15FPS.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 30, 2008 | Olympus FE-170 Digital Camera
Olympus FE 170 Digital problem
power issue... you may want to try lithium AA or send camera to repair
Sep 22, 2008 | Olympus FE-170 Digital Camera
Broken Lcd panel
Broken LCD screen is quite easy to replace on the FE-170 and FE-210. I have purchased cameras with bad lens but good LCDs on ebay pretty cheaply( compared to having Olympus repair camera).
Mar 01, 2008 | Olympus FE-170 Digital Camera
Lence problem and taking picture mode
Lens mechanism needs to be replaced. Probably has broken gears inside not allowing lens to extend completely or far enough to click sensor on. Expensive to repair by Olympus repair shop. Pretty tricky and delicate to repair on your own.
Nov 30, 2007 | Olympus FE-170 Digital Camera
The lens need to be replaced or repaired. It is not fully extending. It may be that one or more of the plastic gears or plastic rods that hold the gears in place, are broken. I repaired two plastic rods in my lens, by drilling holes for new plastic rods,(I cut plastic rods from a plastic toilet bowl chain!!! It fit inside the gears perfectly), and super glue the rods in place. Replaced gears, put camera back together and BAM in worked! Nothing like a perfectly working refurbished rig job. Camera takes great pictures to this day.
Nov 27, 2007 | Olympus FE-170 Digital Camera
Olympus FE-210 Digital Camera Logo
205 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
