I have just changed the relay k46. It is running again for now. Time will tell. I have just changed the relay k46. It is running again for now. Time will tell.
Found the problem, it was a broken wire in the harness. Black with a white trace to the ecu.In the harness that runs along top of engine that starts above air filter. Found the problem, it was a broken wire in the harness. Black with a white trace to the ecu.In the harness that runs along top of engine that starts above air filter.
You can't post conmments that contain an email address.
Hi the van keeps cutting out when driving and is scary when ur stearing locks at the same time wot is wrong it only dose it at dunctions or round abouts it is a 2011 1 mounth old
Hi, Had the same problem, just found the fault,it was a brcken wire causing relay109 to drop out. It was in the upper of the two harnesses on the bulkhead above the air filter, if you pull back the outer sleave and check the thin black/white wire for a break I think you will find your problem. You should have 12v between it and positive. Good luck.
Hi, It was a broken wire in harness
