Question about Mitsubishi WS48511 48" Rear Projection Television
Mitsubishi WS-48511 Device Screen Will Not Go Away
We have the Mitsubishi WS-48511 for about three years and have had no issues until just recently. The select device screen is open and has the yellow box jumping between devises but is stuck on the screen.
The remote controlled seems to not be working. I can press the reset button on the TV and get a turn off with green flashing light then I can turn on the set from the TV but NOT the remote. When we power on we have the device windows open and the yellow box dancing about.
We can play the VCR/DVD and see the picture but the select device window,audio window and the TV/VCR select window stay on the screen.
I have called Mitsubishi and had no success with them. The two referral they gave me to call did not even return my phone calls.
Any suggestions on a fix?
Need help in Mammoth Lakes, CA There is no service for me with in 100 miles!
Regards,
David
  • Mammoth Dave Dec 02, 2007
    Bill you are the GURU. Fixed in ten seconds!
    If I can help you with real estate in Mammoth, CA just ask!
    Warm Regards,
    Broker Dave
  • sailor2b Jan 07, 2008
    I have a similar problem in that my remote will not work and when I go to the set to manual control I cannot change anything either. I can bring up the device manager manually at the set but, thats all it will do. I have reset the the tv but this has not helped.
  • 934 Answers
David,
Let's start with unplugging the set from the wall power for 15 minutes. This will hard reset the micro... While that's unplugged inspect the buttons on the front panel of the Tv to see that none are stuck in a pushed-in condition. Plug the unit back in, power it up and if all works okay you're back in business... If not, let try a keyboard unlock. Press and hold the "menu" button on the front panel for 10 seconds. You won't see any on-screen changes but then try to select an input from the buttons on the front of the Tv.
After you've done these drop me a note and if we haven't solved it will try some other things..
Bill
Posted on Dec 02, 2007
  • William Rayburn
    William Rayburn Dec 02, 2007
    Mammoth Lakes, you guys have a pretty decent golf course there - Snow something I believe.
    Glad to hear you got it.. Have a great day and happy holidays!
    Bill
    Premium Technologies
    PO Box 442
    Long Beach, WA. 98631
    360-642-4993
    [email protected]
SOURCE:
Tip
Mitsubishi WS-55711 Manual Download
Download Mitsubishi WS-48511 HDTV Manual
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Have you misplaced your Mitsubishi WS-55711 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-55711 HDTV Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
__________________________________________
Reset Mitsubishi WS-55711 VChip Password
Bypass Mitsubishi WS-55711 Front Lock
on May 03, 2010 | Mitsubishi WS-55711 55" Rear Projection...
Need replacement screen for Mits. WS-48511
The other site i am associated with has used screens for mitsubishi you just have to post the measurements of your screen top to bottom and side to side dont include the frame size as we allow 1/4 inch for fitting in the frame just need the size of the screen to the frame edge.
Mar 31, 2008 | Mitsubishi WS48511 48" Rear Projection...
Replacement Parts - Rear Proejction TV Mits. WS-48511
Visit http://www.vstore.ca for used lenticular and fresnals. They will size to fit.
Mar 31, 2008 | Televison & Video
Tip
Bypass Mitsubishi WS-48511 Front Button Lock
Would you like to bypass, defeat or reset your Mitsubishi HDTV WS-55711 Front Button lock?
If you have misplaced your remote control, and have engaged the Mitsubishi WS-55711 HDTV Front Button Lock, you can bypass the front button lock by pressing and holding the MENU button on the front panel for more than 8 seconds.
I hope that helps.
Tip
Bypass Mitsubishi WS-48511 Front Lock
Would you like to bypass, defeat or reset your Mitsubishi HDTV Front Button lock?
If you have misplaced your remote control, and have engaged the Mitsubishi HDTV Front Button Lock, you can bypass the front button lock by pressing and holding the MENU button on the front panel for more than 8 seconds.
I hope that helps.
Reset Mitsubishi WS-48511 VChip Password
Mitsubishi WS-B55 Manual Download
on May 03, 2010 | Televison & Video
Tip
Bypass or Reset Mitsubishi WS-48511 HDTV V-Chip Password Lock
Would you like to bypass, defeat or reset your Mitsubishi HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password.
When your passcode is requested, press the number 9 and the QV button on the original TV remote control at the same time. This process temporarily unlocks your TV.
When you enter the V-Chip Lock menu, pressing the number 9 and the QV button on the original TV remote control at the same time will delete your old password and prompt you to enter a new passcode. Pressing HOME at this time will cancel the entire passcode.
I hope that helps.
Mitsubishi WS-48511 Manual Download
Tip
Have you misplaced your Mitsubishi WS-48511 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-48511 HDTV Users Guide?
I hope that helps.
Tip
I hope that helps.
on May 03, 2010 | Mitsubishi WS48511 48" Rear Projection...
Tip
I hope that helps.
Tip
I hope that helps.
Mitsubishi WS48511 48" Rear Projection Television Logo
144 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
