Want to convert the church's dehumidifier to a drain hose and need to know what I need and how to hook it up. Figured that the exploded diagram would give me dthe answer I needed.
If your model has a condensate (water) reservoir, there should either be a threaded hose fitting located at the bottom of the reservoir that will accept a standard garden hose, once you punch out the plug inside the threaded coupler.
If you do not have a threaded hose coupler on your unit's reservoir, remove the reservoir and look inside the area above it and there should be a small hose fitting that you can attach a standard garden hose to, to allow for constant draining without having to use and empty the condensate reservoir daily, etc.
If you don't have either of these items, you'll need to purchase a new condensate reservoir with a hose drain attachment to allow use of an auxillary drain hose. You'll need to contact Maytag customer service for the correct parts and assistance.
Maytag Customer Service 533 Benson Road Benton Harbor,MI 49022
(866)616-2601 U.S. (800)688-2002 Canada
Hope you found this Very Helpful and best regards!
Was this helpful?
Yes
No
2 people thought this was helpful
Asker's Testimonial
To VtToolman:
This gives me the opportunity to check the machine and know my next step. I believe Ii need to purchase a tube for connecting the hose
" - jkroyal
Popular Solutions for Maytag M7DH45B2A Dehumidifier
I dropped and broke the water collection bucket for my Maytag m7dh45b2a dehumidifier. Can you sell...
(More)
I dropped and broke the water collection bucket for my Maytag m7dh45b2a dehumidifier. Can you sell me a new bucket?
We have a 45 pint Maytag dehumidifer, model #M7DH45B2A. We purchased it 4-5 years ago and it has...
(More)
We have a 45 pint Maytag dehumidifer, model #M7DH45B2A. We purchased it 4-5 years ago and it has always worked great until this week. It seems to still be working, but there is a large wet spot in front of the unit which sits on carpet, so I know it is leaking somewhere, but the water bucket is still filling, and I can't see where the leak is coming from. Should we bother having it repaired or just purchase a new one. I am not sure what the life span on this item is. Has anyone had this issue?
my fedder dehumidifier m7dh45b2a makes an annoying buzzing noise when it operates. What's causing...
(More)
my fedder dehumidifier m7dh45b2a makes an annoying buzzing noise when it operates. What's causing this noise? What do I do to fix it? It's 4 years old.
has there been any recalls on this dehumidifier. if you press the shut off button and turn it off...
(More)
has there been any recalls on this dehumidifier. if you press the shut off button and turn it off you have to unplug it then turn the dehumidity level lower to get it to come back on
