Question about GE GSL25JFR Brushed Steel Side by Side Refrigerator
Side by side stopped working but clicling noises every second two.
2005 GE Side by Side stopped working today. It Is getting power. Circuit board is making a clicking noise about every second or two. Also clicking by what I believe is the compressor(Metal obect at bottom mounted w/ rubber dampners.). Actual clicking happening at Electrical componet attached to compressor. Disconnected wires from module attached to compressor and checked connections. Every time the clicking happens the fan attached to motor moves slightly. Seems like the refrigerator clicking is happening to get compressor or motor started but it is just not starting. Looked for a reset switch or blown fuse but couldn't find anything. No other noises happening. Did all basic checks, adjusted temp controls, checked breakers, Hit compressor to get it started :) nothing worked. Any help would be greatly appreciated My side by side stopped working (not cooling) lights work, and making clicking noise. It had stopped cooling before, I unplugged for a couple of hours, and plugged it back in. It started working fine. About two weeks later, same thing. This time, more clicking and no cooling. Help please.
  • 447 Answers
Ok the motherboard is malfunctioning. Ive observed this exact problem before. Replace the board and all will be normal again. If you keep lettig it click and click it may finally kill that relay that you descibed to me or even worse the compressor itself.
Posted on Dec 02, 2007
  • Mr. Cage
    Mr. Cage Dec 13, 2013
    I fixed my motherboard.
  • Mr. Cage
    After a careful inspection, i replaced both 470uF x 25V capacitor (c29 and c30, i guess - near the 7805 regulator)
    New Friend:
    Problem Solver:
  • 8 Answers
Board WKKT Model 0158-00-04
Board GEA Part 200D4854G013
I replaced both 47uF x 400V capacitors - one of them was bulged. The bad one was open, and the other still had it's nominal value.
I tryed to make the refrigerator work, to no avail.
After a careful inspection, i replaced both 470uF x 25V capacitor (c29 and c30, i guess - near the 7805 regulator). Both had around 0.5% of their original value, and i belive it was the source of the problem.
Everytime the processor tried to start the relay, the power level dropped and the motherboard "rebooted"... and thus the cycles and clicks from the relay.
The refrigerator got back to life!
There was a recall by GE on November, 2006.
Call GE at 18003861215, option 3. Mention the recall and maybe it's still valid a free replacement.
Posted on Dec 17, 2013
Get a new refrigerator. Mine has done the exact same thing twice in 28 months. I'm donating mine to charity and getting another brand of Refrigerator.
Posted on Apr 21, 2008
SOURCE:
My GE Side by Side refrigerator stopped making ice and dispensing water.
Check out the solenoids and power to the water solenoids for ice maker and door water.
Aug 22, 2017 | Refrigerators
Not getting any water out of the dispenser, but its making ice
The water dispenser on my GE profile fridge stopped working for a couple days. The refrigerator and freezer temperatures have fluctuated over the past several months causing fridge items to periodically freeze and freezer items to periodically thaw. GE tech came today identified a bad circuit board, which he replaced for a cool $300. Ouch. Fridge is only three years old. Oh yeah, the icemaker also has a broken tab which causes it to jam every couple weeks. We have GE Profile appliances throughout our kitchen and they all work great except for the fridge :-( I hope GE engineers read this post. If so, get to work! LOL
Feb 03, 2010 | GE Profile PSW26P Stainless Steel Side by...
GE Model GSH25JSRF SS is clicking non stop, the click comes from a small panel on the back right of the fridge. Started out that the water and ice dispenser didn't dispense. Then the clicking just came...
Is it still cooling? I had an issue where there was a clicking noise from the back panel and the fridge did not cool. Pulling off the panel the noise seemed to from a box on the circuit board. Turns out there was a problem with the controler board and after some research I found that the board was covered under a recall. GE ended up sending a guy out to replace the board at no charge. Pretty cool being that if was after the warranty had expired; but I guess it makes sence since there was a recall. Good luck.
Dec 10, 2009 | GE GSH25JFR Side by Side Refrigerator
My refidgerator & freezer stopped getting cold. It is running but no cold air on both sides. (It was making a clicking noise that was coming from the circuit board on the back of the unit) but that has...
Replace the mother board. (it's the board you heard clicking) The only thing you hear running are fans. Check your model and serial number with your parts supplier, as you may be able to get the board free. (only certain models / serial numbers qualify)
Nov 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The circuit board is making a clicking noise... I
Sounds like you have a GE side by side, replace the mother board. Common problem. Once you replace then check to make sure the evap fan is running and condenser fan are working.
Sep 30, 2009 | Refrigerators
My NEW GE side by side fridge died today!
The display off because your power board is faulty. (Under gaurentee i hope. Need to call the warrenty repair guy out.
Sep 21, 2009 | GE Energy Star PDS22SIS Stainless Steel...
GE GSL25JFR Brushed Steel Side by Side Refrigerator Logo
529 people viewed this question
Top Refrigerators Experts
Brad Goodale
R.A. Ellis
R.A. Ellis
Darrin P. De May
