Question about Samsung DVDR120 DVD Recorder
Samsung DVDR 120 SYS ERROR
My Samsung DVD Recorder did this a couple of time then did record but now evry time I put a Blanc DVD and start recrod I get system error. Can I fix it by firmware or cleaning. Can some one give me help on how to fix it. Thanks
  • 2 more comments
  • gmanisa3 Jan 09, 2008
    won't record or play burned dvds sometimes. Have tried different disks but some in the same batch will work and some won't!!??
  • transitonal Apr 14, 2008
    my samsung dvd r120 does not write to the maxell or the tdk like it used to
  • socialbutter Jul 28, 2008
    system error 0507
  • Mitchell Dec 26, 2018
    I just took all apart and cleaned the lens and now it will record. I had the problem of not recording but played dvds
    Scholar:
    New Friend:
  • 61 Answers
You have an early unit and need to install the firmware upgrade. Download it from Samsung and burn to a CD. Insert the CD in the DVD player and the upgrade will be performed.
Posted on Aug 07, 2009
SOURCE:
I have a Magnavox MRV700VR. I can record on a DVDR, but when I try to record on a DVDRW it tells me "disc error". Why?
It will be either that you have not formatted the disc or that you are using the wrong type of disc. You will need a DVD+RW on a + machine or DVD-RW on a - machine. Most recorders will playback the other type but not record on it.
Jan 28, 2013 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Samsung R150 DVD recorder system error and freezing.
go to menu, select formate, formate disk in V mode not VR.when finished recording finalize disk. you can then play on any dvd player.
Jul 10, 2009 | Televison & Video
I have a dvdr3380 lately when i put in disc it says disc unrecord
Test the created DVD with TMPGEnc v4.0 Xpress here is the free trial link It has a read source function that will fail if the DVDR has not been authored correctly.
If this works and scans in the full DVDR then I suggested that you buy a branded DVD+R like Philips who created the format, if this still fails I think you DVDR 3380 will need a service.
LOL
Mar 15, 2009 | Philips DVDR3380/05 DVD Recorder
Samsung dvdr-128 no disk?
most of the time u will need to change the motor
Nov 26, 2008 | Panasonic DMR-E55 DVD Recorder
Samsung DVD recorder
check the compatability of the blanks does recorder work with dvd disc you are using dvdr+, dvdr-, rewritable?
Jul 30, 2008 | Televison & Video
Samsung DVD-SH855 DVD Recorder 250GB HDD playback freezes
Samsung dvd sh-855 i have the same problem wiht freezes when recording on timer mode.Recording in timermode with TV on is OK. But only connected whit HDMI cable, Component is OK in all modes!!!
My recorder is a XXE model = scandinavian.
Do anyone have a solution Please
Apr 20, 2008 | Samsung DVD-HR720 DVD Recorder
Similar problem as you helped me solve before.
OK, I think I see the problem there.
The aerial lead from the DVDR to TV should be removed.
You should have it setup the same as the other Freeview - VCR - TV
Nutshell time:
Main aerial to Freeview input.
Loop aerial from freeview output to DVDR areial input (all this does is allow you to watch freeview, or standard both out of the DVDR)
So..
Scart from Freeview to DVDR input
Scart from DVDR output to TV
Set DVDR to AV input mode.
Set TV to AV (whatever number you need for that..you now won't get anything on screen unless you have the right input selected)
If you can now see the Freeview picture on the TV and change the channels with the Freeview remote then you should be set for recording.
Having the aerial and a scart lead both going to the TV is not needed.
Apr 14, 2008 | Philips VR550 VHS VCR
Samsung dvd recorder
Make sure you have finalised the disk, otherwise it won't play back on other players. Also there are two standards that you can use to record onto disks, video mode or VR mode. Video mode was the original standard but it wouldn't let you edit or add anything to the recording afterwards but it is more compatible with other players. VR mode allows you to edit the recording but is less compatible for playback on other players.
Mar 28, 2008 | Televison & Video
Recording from cable dvr
You have to hook up an AV cable from the box to the DVDR.. Out on the cable box to IN on the DVD player.
Then put your DVD player on AV1 - ( you can do this by pressing the INPUT SEL button on the DVDR remote)
Then put the Cable box on whatever channel you want to record. And press the record button on the DVDR and you will record whatever channel the cable box is on
If you can't get to AV1 then you have to disable cable box control (menu>setup>system>cable box control>off
Jan 12, 2008 | Samsung DVD-VR357
Samsung dvdr-120
try checking on the recording mode of the DVD. V recording mode produces more compatible DVD disc. Stay away from VR mode. You may refer to your manual.
Jul 26, 2007 | Samsung DVDR120 DVD Recorder
Samsung DVDR120 DVD Recorder Logo
1,028 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
