Question about Dell Inspiron 2200 Notebook
One day, i found the working conditioned LAPTOP DELL PP19L did not function i.e. the input voltatage 19.5V DC did not enter the board from adopter. because, somewhere, it is found that there is a short circuit of +ve and -ve voltage. To the result, the glowing LED in the adopter did not glow and stopped when the power socket of adopter is connected to the LAPTOP. So, it is simply assumable that there must be some short circuit of voltage somewhere.
Also, the adopter is removed and switched on the battery pack, ispite of this, laptop did not get on. Then, when checked the battey pack with multimeter, it is in fully charged condition.
But, i don't know why it is not working. Kindly help me to troubleshoot the problems and suggest me the guidelines to rectify the problems occured.
thanking you,
with regards,
krishnamurthy d
radio ham VU2DJM
  • frankie c Jan 01, 2008
    the laptop is frozen and the mouse attached is not showing the red light
Thanks for the response. But i have to state that I have already obtained the support link web, as u have pointed it now. When going through that manual, I can only get how to get the set dismandled and with only a few guidelines, it has been described, without any circuit diagram and tracing methods and guidelines to the point, it is required; now.
So, if you will kindly further guide me to trouble-shoot it by seeing the circuit diagram of the particular portion in the PCB, step by step, it will be easy to trace the error and rectify it positively. Kindly oblige with further guidelines.
thanking you,
with regards,
krishnamurthy, d
Posted on Nov 08, 2008
  • 1,601 Answers
Sounds like the charging circuitry is faulty. I was looking at the service manual and it looks like it is on the motherboard.
Here is the online manual, see what you think.
Posted on Dec 02, 2007
Invertomatic victron imv ups
Malfunction of input circuit: voltage delivered is too low. The batteries may
be faulty or depleted. Wait for a few hours, leave the UPS switched on
If absence of input power (utility failure, maintenance work) is expected to last longer than a few hours, switch
off the UPS to save battery power. If the UPS input power is absent for several days and the UPS remains on
under no-load conditions, the batteries can be discharged very deeply, resulting in a short battery life time
Apr 22, 2014 | Computers & Internet
Dell pp19L
FixYa can't help you if you don't specify a problem.
Nov 03, 2013 | Dell Inspiron Mini 10 10v 1010 1011 PP19S...
What does codes 64 63 11 09 and 21 0n 2005 dodge stratus mean
CODE 11 No distributor referene signal detected during engine cranking....Check circuit between the distributer and the pcm.
CODE 12 Problem with battery connection.Direct battery input to pcm disconnected within the last 50 ignition key-on cycles.
CODE 13** Indicates a problem with map sensor vacuum system.
CODE 14** map sensor voltage to high or to low.
CODE 15** Problem with vehicle speed sensor signal.No vss signal detected during road load conditions.
CODE 17 Engine is cold to long.Engine coolant temp stays below normal operating temp(check thermostat).
CODE 21** Problem with oxygen sensor signal circuit.Sensor voltage to computer not fluctuating.
CODE 22** Coolant sensor voltage to high or to low.Test coolant temp sensor.
CODE 23** Indicates that the air temp sensor input is below the minimum acceptable voltage or sensor input is above the acceptable voltage.
CODE 24** Throttle position sensor voltage to high or low.Test the tps.
CODE 25** Idle air control (IAC) valve circuits.A shorted condition is detected in one or more of the IAC valve circuits.Or a vacuum leak has been detected.
CODE 27 One of the injector control circuit output drivers does not respond properly to the control signal.Check the circuits.
CODE 31** Problem with canister purge solenoid circuit.
CODE 32** An open or shorted condition detected in the EGR solenoid circuit.Possible air/fuel ratio imbalance not detected during diagnosis.
CODE 33 Air conditioning clutch relay circuit.An open or shorted condition in the compressor clutch relay circuit.
CODE 34 Open or shorted condition in the speed control vacuum or vent solenoid circuits.
CODE 35 Open or shorted condition detected in the radiator fan low speed relay circuit.
CODE 37** Open or shorted condition detected in the torque converter part throttle unlock solenoid control circuit.
CODE 41** Problem with charging system.An open or shorted condition detected in the generator Field control circuit.
CODE 42 Fuel pump relay or auto shutdown relay (ASD) control circuit indicates an open or shorted condition.
CODE 43** Multiple cylinder misfire detected.Peak primary circuit current not achieved with the maximum dwell time.
CODE 44 Battery temperature sensor volts malfunction.Problem with the battery temperature voltage circuit in the pcm.
CODE 46** Charging system volts to high>Computer indicates that the battery voltage is not properly regulated.
CODE 47** Charging system voltage to low.Battery voltage sense input below target charging voltage during engine operation and no significant change in voltage detected during active test or alternator output.
CODE 51** Oxygen sensor signal input indicates lean air/fuel ratio condition during operation.
CODE 52** Oxygen sensor signal input indicates rich air/fuel ratio during engine operation.
CODE 53** internal pcm failure detected.
CODE 54** No camshaft position sensor signal from distributer.Problem with the distributer synchronization circuit.
CODE 55 Completion of fault code display on check engine lamp.this is end of message code.
CODE 62 Unsuccessful attempt to update EMR mileage in the controller EEPROM.
CODE 63** Controller failure.EEPROM write denied.Check the PCM
Dec 12, 2012 | 1995 Dodge Stratus
My dell laptop doesnot work proberly if we power on a dell laptop. adopter let should be off then remove from the lap power will be on. whats the problem
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Aug 16, 2011 | Computers & Internet
My dell D820 laptop is shorting out the power adapter. Whenever I plug in the adapter, it shuts down via short circuit protection. I verified that the adapter is good. I have stripped down the laptop and...
It is most likely the DC connector. Take it off the system board and clean the solder joints, then replace it.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 13, 2010 | Dell Latitude D820 Notebook
Hi, the battery seems to be flat there is no charging light, even when input jack is moved about. would this be the charging circuit at fault? Thanks
1.Remove ,the battery and adopter from your machine.
2.And then press the power button form 36 Second.
3.And then refix your battery and adopter to your machine.
4.boot your system
5.if you will get the same problem again means suspected issue with main board.
Nov 16, 2010 | Acer TravelMate 2303LCi Notebook
I have a Nissan Frontier with accelerator & throttle problems. I have sensor codes p2122 & p2138. How do i fix this problem? Is it a self fix problem? HELP!
Throttle/Pedal Position Sensor/Switch "D" Circuit Low
P2122 - APP Sensor 1 Low Input
Probable Causes:
1 - Failed APP Sensor 1
2 - Open or short circuit condition
3 - Poor electrical connection
P2138 - APP Sensor Performance Condition Fault
Probable Causes:
I hope this helps you and thank you
Feb 14, 2010 | Nissan Frontier Cars & Trucks
Dell Latitude D800
You have a short circuit. Try powering up but with the battery out.
Sep 06, 2007 | Dell Latitude D800 Notebook
Dell Inspiron 2200 Notebook Logo
389 people viewed this question
Alun Cox
