Question about Creative Labs Zen Neeon MP3 Player
Zen Neeon 2 1GB
I had transfered MP3 files to my player and after safely removing it from the USB drive, it suddenly gone dead. I thought the battery had just been drained so I charged it, but even just connecting the charger it won't... I had tried to reset it and walah, it turned on, so i just thought it only got frozen.. i went to browse the mp3s, photos and videos I had there for more than 6 mos and to my suprise, none left as in empty... so I panicked and thnking i accidentally deleted the files. To my surprise when i checkd the system, all i had left was 123MB and used all the remaining of 1GB.. so where had it gone, no files but memory used up? Please help... i'm pissed off with this player now, if only i had listened to my friend...sad....
  • Anonymous Mar 05, 2008
    i had transfered MP3 files to my player and after safely removing it
    President:
  • 4,402 Answers
Try hitting the reset button
it sounds like something is really wrong with its file system or the hard drive is bad. Have him boot into Recovery Mode and do a disk cleanup and see if that solves the problem. If not, then reformat the drive.
if you do get it working download the latest firmware.
Posted on Dec 06, 2007
SOURCE:
After i format my Creative Zen Neeon
After i format my 'Creative Zen Neeon', the program file seem to have been erased and i cant play songss with it anymore.HOW? help me! anyone can send me information and the program files for the MP3?
Jul 08, 2009 | Creative Labs Zen MicroPhoto MP3 Player
Stuck on the logo zen neeon 2
remove music and reformat then put music again
Jun 23, 2009 | Creative Labs Zen Neeon MP3 Player
MP3 un plugged properly and it crash
OK all is well just....Allow unit to run dead.recharge battery.turn on and push reset(small paper clip in reset hole).turn off and back on .should now work.if not format and download new soft ware at http://support.creative.com/kb/ShowArticle.aspx?sid=8451.RICHARDM69
Sep 09, 2008 | Creative Labs Zen Neeon MP3 Player
Zen Neeon Frozen - USB Display
we have the same problem
but there is 1 way to solve it
wait for the battery to drain and charge it
hope it helps you : )
Jun 01, 2008 | Creative Labs Zen Neeon MP3 Player
My Computer Won't Read It!!!
These symptoms points to a bad hardrive. Replace the hardisk and reload the latest firmware.
If your out of warranty with your Neeon, open it up. Loosen the 2 screws at the bottom of the player and remove it. Then carefully pry open the back plate using a small flat screw driver and remove the battery (it has a mini connecter on the top left, inline with the USB connector).
Remove the front cover. You'll find the hardisk on top of the board below the LCD. Remove it carefully from the connector. on its right side.
If you got a new HD, replace the old one and reassemble your Neeon.
Next download the latest Neeon Firmware Upgrade here:
http://sg.creative.com/support/downloads/download2.asp?MainCategory=213&Product=12214&dlcentric=9534&Product_Name=ZEN+Neeon+5GB%2F+6GB&OSName=Windows+XP
Firmware above is for Windows XP. You can download a version of the Firmware at Creative site in your region for your specific OS requirement...
Before
To install this firmware upgrade:
1. Press and hold the Play button while connecting your player to your computer's USB port.
2. Continue to hold the Play button for 10 seconds after connecting your player to your computer.
3. Release the Play button when the Find New Hardware dialog box appears on the screen.
4. Follow the instructions on the screen to install recovery drivers for your player.
5. Download the ZenNeeon_PCFW_LF_1_011_FM.exe file into your local hard disk.
6. Double-click the firmware upgrade file and follow the instructions on the screen.
I found the above instructions with other Neeon's forum here:
http://forums.creative.com/creativelabs/board/message?board.id=dap&message.id=176728
You'll have the option to format and reload firmware. Choose that option. Wait for the upgrade progress to finish.
When it's done, your player will connect and recognized by your computer. If it shows in MY COMPUTER as removable drive, then your in luck!
Proceed by drag and drop method of transfering your music files or using the CREATIVE MEDIA SOURCE ORGANIZER.
I'm currently looking for a way to hack the Neeons Hard Drive and replace it with a CF card just like what I did with my Zen Micro. Unfortunately the first CF card I bought (1 Gbyte) did not work on the Neeon, the XP wont recognize the player.
But I'm not giving up, I had to find a better replacement that match the compatibility requirements of the Neeon. I'll try different brands and speed. The CF card is much more robust and shock free. It reads faster with no hang-ups.
I'll post my results in the future if I succeed.
Sep 26, 2007 | Creative Labs Zen Neeon MP3 Player
Zen Neeon frozen completely
Leave it alone for a while, then try reinstalling the Zen Program, then plug it in, then rest it, then try to switch it on. It worked for me
Jul 27, 2007 | Creative Labs Zen Neeon MP3 Player
Player can't charge
This has happened to me before,you might want to try using a different usb cable.I did this and it worked fine since then.
Jun 16, 2007 | Creative Labs Zen Neeon MP3 Player
Same problem ...not able to switch on .. :((
well have you tried a new battery or it could be a faulty wire ! hope it helps ...
Jun 01, 2007 | Creative Labs ZEN SLEEK MP3 Player
Unable to clear non music files from mp3?
I'm a bit confused by your description, but you ARE talking about non music files... Is it possible at all that you deleted system files from your player? If so it really wouldn't respond. Try going into Recovery Mode; remove battery, hold power switch to ON, replace battery, release power switch when the Recovery Mode screen appears on the screen. Run Option 1 CleanUP, after it completes run Option 4 Restart. You will get a Rebuilding Library screen when it reboots, that's normal, then it should go back to your startup screen. Another thing to try is recovering you system files through a firware upgrade/install. I'm not sure it will work, but would you mind being a guinea pig? let us know how it turned out. Good luck
Jun 26, 2006 | Creative Labs Zen Neeon MP3 Player
Creative Labs Zen Neeon MP3 Player Logo
95 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Ekse
Marvin
Marvin
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
