Question about Kenmore 95592 / 95594 / 95595 / 95599 Electric Kitchen Range
Kenmore electric range malfunction
I have an electric kemore range model 7909651001.
When the oven is not in use it will work the lock mechanism to lock and unlock the door all by itself. When it is in use it will try to do the same or turn itself off with no warning.
What may be causing this, is it expensive to repair?
  • 310 Answers
SOURCE: Kenmore electric range 911.9369181
F8 Failure of Electronic Range Control (ERC) Replace Electronic Range Control/Clock (ERC)
Posted on Jan 01, 2008
SOURCE: oven door won't unlock
I had this same issue and consulted the owner's manual. Once on self clean it takes up to 3-4 hours for it to automatically unlock. It is a built in safety feature of the oven.
Posted on Feb 14, 2009
  • 51 Answers
SOURCE: Kenmore oven model 665, oven temperature goes up
need to check oven sensor probe located inside of oven will be in left or right hand corner. the tech sheet should still be on the back panel of oven it will have instructions how too...
Posted on Oct 01, 2009
  • 189 Answers
SOURCE: Kemore gas range model #790: oven does not get
Hello- Sounds like lower burner ignitor is bad. Resistance should be more than 4ohms. across ignitor. Parts available locally at app. parts store for 50-75$. Fairly easy to install. - Hope this helps. Thanks- ED
Posted on Feb 28, 2010
Testimonial: "Thanks!"
  • 15935 Answers
SOURCE: Kenmore Electric Self Cleaning Range
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 23, 2010
Oven door is locked out - Sears no help
      1. Step 1 Read the display on the electronic oven controls, where the clock and timer normally appear. If the display reads "CLN" while the "Door Locked" light is on, the Kenmore range is in self-clean mode. When the Kenmore range is in self-clean mode, you must stop the cleaning process before the door will unlock.
      2. Step 2 Stop the self-cleaning process by pressing and holding the "Stop/Clear" button for three seconds. The oven lock should disengage after three seconds. In some cases, a malfunction between the control panel and the locking mechanism prevents the door from unlocking.
      3. Step 3 Hold the light switch for several seconds if the "Stop/Clear" button fails to unlock the range door. Engaging the light switch for several seconds resets the entire locking mechanism and overrides the "Stop/Clear" button.
Jul 03, 2015 | Kenmore 30" Freestanding Electric Range...
I have a electric kemore stove model # 7909231001 the front left buner sparked out I brought a new coil but it still does not work what do I do
test equipment and brain required. Either start chasing wires, current, and voltage or find a skilled individual who can. 25320272-zwfykd1k4rtzjgfuoehmn00z-5-0.jpg
Dec 13, 2014 | Kenmore Sears Electric Range Stove Oven...
Kemore gas range model #790: oven does not get hot, but stove top and broiler both work
Feb 27, 2010 | Kenmore Kitchen Ranges
Husband removed oven door when fully open instead of when 1/4 open as the manual suggests, now the door clicks a couple times as it is nearly closed, model number 95592 Kenmore electric smoothtop range...
Try removing and refitting it a few times otherwise you will probably have to get new door latching mechanisms. You may just be lucky that they have been dislodged but they are most likely to have been broken. The clicking is the door interlock mechanism trying to lock and unless it succeeds the oven will not work.
Oct 24, 2009 | Kenmore 95592 / 95594 / 95595 / 95599...
Hi i have a kemore gas range that the bake ingiter or broil won`t
The igniter in the oven does not spark. It heats up and glows red hot until enough current opens the safety gas valve to the burner. It is not associated with the stovetop burners. Replace the oven igniter itself.
Aug 11, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kenmore 790 Oven Locking mechanism problem
hold down the stop/clear button for 3+ seconds
Jan 13, 2009 | Kitchen Ranges
Stovetop locked
look closely at the control panel there will be abutton marked, control lock, yuoll need to hold it down for 3 -5 secs, its achild lock feature, youre manual will explain if you still have it
Dec 07, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Aug 12, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
I had the same problem. Open the oven door. Press and hold the light switch. You will hear the door lock move back into the correct position. Hope this fixes your problem. This has happened to me twice and holding the light switch always works.
Jul 14, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Error F5 on a kenmore electric range Model 911-469-8812
f-5 stands for faulty oven control called the EOC youll have to replace the control to fix problem
Nov 19, 2007 | Kenmore 95822 / 95824 / 95829 Electric...
Kenmore 95592 / 95594 / 95595 / 95599 Electric Kitchen Range Logo
37 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
